Gettysburg Axel 22 #1 Posted June 22, 2025 Hi I have a question about the gt14 transmissions. Are you able to use them in other tractors. I have a commando 800 I swapped an automatic transmission from a b100 but I’m looking to add a hydraulic lift for it. I know you can swap in the parts to add it. could you use the parts from a gt transmission or would it be easier to swap the gt transmission in to it. I have two spare transmissions from different gt tractors. I know they have the larger axle diameter but they should be the 1 1/8 inch axles the same as a spare 8 speed transmission I have also. So I’ll have the 5 lug hubs to keep my current tires I have on it. Any help or advice would be appreciated. I added a picture of the 800 in question as well as my other current projects 2 Share this post Link to post Share on other sites
Achto 31,898 #2 Posted June 22, 2025 I am not familiar enough with the GT14 to answer your question. Someone should be along who knows though. Share this post Link to post Share on other sites
953 nut 66,551 #3 Posted June 23, 2025 The gear ratio on theGT-14 is not toe same as a B-100 and would be slower with 12" tires as a result,. @daveoman1966 can fill you in on the parts to swap from the GT-14. 1 Share this post Link to post Share on other sites
Pullstart 70,096 #4 Posted June 23, 2025 @19richie66 is fairly familiar with these hydro swaps as well. Cool projects and Share this post Link to post Share on other sites
19richie66 17,892 #5 Posted June 24, 2025 13 hours ago, Pullstart said: @19richie66 is fairly familiar with these hydro swaps as well. Cool projects and Just to clarify, I have very little experience with the gt14 transmission. If you recall mine was trash. So everything I own has an Eaton 1100 in it. 😁 1 Share this post Link to post Share on other sites
gt14rider 1,201 #6 Posted June 24, 2025 (edited) Good morning, I have a manual on hydraulic lift, but can't figure out how to move it here. Hope this helps. It has some part #s and picture of insulation. Edited June 24, 2025 by gt14rider Share this post Link to post Share on other sites
gt14rider 1,201 #7 Posted June 24, 2025 Get yourself a copy of a sundstrand manual. Part 4 has hydrogear info. 1 Share this post Link to post Share on other sites
