953 nut 69,341 #26 Posted September 9, 2025 9 hours ago, kpinnc said: Vanguard too. What is the Zinc content on these oils? The Shell Rotella T is high in zinc and that is why it is used in the "K" and "M" series Kohler engines. The later Command engines and your Vanguards don't benefit from the zinc like the older ones do. Share this post Link to post Share on other sites
Anderson-310-8 5 #27 Posted September 9, 2025 @953 nut already have that and a few other items in my cart on wheel horse parts 😂 a good bit of the rubbers are going bad I’m noticing so gonna get a full cart of most of the issues/parts to fix it all in one go instead of ripping it apart 10 times 1 Share this post Link to post Share on other sites
953 nut 69,341 #28 Posted September 9, 2025 4 minutes ago, Anderson-310-8 said: fix it all in one go instead of ripping it apart 10 times Sounds like we will be hearing from you a lot the next few months. Any questions that may come up please post them here so we can help. Share this post Link to post Share on other sites
