pfrederi 21,342 #1 Posted May 28, 2025 (edited) Been renovating some old school cast iron spindle units. The upper bearing were in good shape but I was planning on replacing except all I could get new was made in China. (These are the older shafts and the bearings are odd 3/4" ID 40mm OD. Later WH units used more common 17mm ID 40mm OD) So I opened up the bearings and some other used ones I had accumulated and a new China bearing. Interesting differences From left to right Pacamor (Japan) steel ball carrier 9 balls General bearing company plastic carrier 8 balls (No origin marked) Nice (USA) plastic carrier 8 balls HBC (China) (New) steel carrier 8 balls So what bearings to use???? Since eh old spindles have grease fittings into the housing I guess i should leave off the inner cover?? Edited May 28, 2025 by pfrederi 2 Share this post Link to post Share on other sites
ri702bill 13,393 #2 Posted May 28, 2025 I believe the open sides face the center, the seals to the outsides. 1 Share this post Link to post Share on other sites
Wayne0 1,666 #3 Posted May 28, 2025 I vote Japan. More balls = less wear. 2 1 Share this post Link to post Share on other sites
peter lena 10,125 #4 Posted May 29, 2025 @pfrederi see the OPPORTUNITY ? its not the bearing its the wrong / generic lubrication in them ! wide rubber side grease shields , is the saving grace ! every bearing failure I have had was ELIMINATED ,WITH A CLEAN OUT, AND LUCAS XTRA HD GREEN CHASSIS GREASE , WAL MART $ 8 , ALL MY MOWER DECKS , AND RELATED DRIVE POINTS , operate quietly , easily , no WHYINING , rate at 550 deg flash point , polyurea rated , personally buy bearings on one standard , wide rubber side shields . no noise or failures . staring right at you , pete 1 Share this post Link to post Share on other sites
oliver2-44 11,847 #5 Posted May 29, 2025 (edited) Back at work we had large hydraulic pumps. The electric motor shared a bearing with the hydraulic pump where they bolted together. The bearings had one more ball than a common bearing. This gave the bearing a higher load rating. Those bearings cost a lot more than the standard bearing. Edited May 29, 2025 by oliver2-44 5 Share this post Link to post Share on other sites
pfrederi 21,342 #6 Posted May 29, 2025 Good Info Thank you I have two of the 9 ball Pacamor bearing so I will repack them and then I am wondering new Chinese or repack the Nice (USA) bearing for number 3???? 1 Share this post Link to post Share on other sites
kpinnc 19,107 #7 Posted May 29, 2025 18 hours ago, Wayne0 said: More balls = less wear. True absolutely never... 2 Share this post Link to post Share on other sites
Wayne0 1,666 #8 Posted May 29, 2025 3 hours ago, kpinnc said: True absolutely never... More load bearing surface. Doesn't seem to be flawed logic............... 1 Share this post Link to post Share on other sites
peter lena 10,125 #9 Posted May 29, 2025 @oliver2-44 https://www.google.com/search?q=sweco+vibro-energy+separator&rlz=1C1CHBF_enUS866US866&oq=sweco+&gs_lcrp=EgZjaHJvbWUqBwgCEAAYgAQyBggAEEUYOTIHCAEQABiABDIHCAIQABiABDINCAMQLhjHARjRAxiABDINCAQQLhivARjHARiABDIHCAUQABiABDIHCAYQABiABDINCAcQLhivARjHARiABDIHCAgQABiABDIHCAkQABiABNIBCDk0MzlqMGo0qAIIsAIB8QVR5u1q4ZcrKA&sourceid=chrome&ie=UTF-8#oshopproduct=pid:6601803068765136533,oid:6601803068765136533,iid:13756036643980274501,pvt:hg,pvo:3&oshop=apv&pvs=0 we had floors of buildings with dozens of these sweco sifters running 24 / 7 , surprisingly very little bearing failures , specifically built fur hot dusty conditions , by the way the short coil spring pan support , makes a bombproof seat base on the tractor . pete Share this post Link to post Share on other sites
kpinnc 19,107 #10 Posted May 29, 2025 2 hours ago, Wayne0 said: More load bearing surface. Doesn't seem to be flawed logic............... Actually I was making fun of being 55 years old looking back at stupid stuff I've done... My grandpa's logic: the level of balls is in direct and oppositional correlation with the limit of brains.... 1 Share this post Link to post Share on other sites
Bill D 3,213 #11 Posted May 30, 2025 2 hours ago, kpinnc said: Actually I was making fun of being 55 years old looking back at stupid stuff I've done... My grandpa's logic: the level of balls is in direct and oppositional correlation with the limit of brains.... Uh oh, I'm in trouble. 😂 1 Share this post Link to post Share on other sites
