stevebo-(Moderator) 8,607 #1 Posted April 11, 2025 All- My 418-8 has that “loose” steering wheel shaft cover. Anyone have a fix for it? I am not sure how it was properly attached from the factory… Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,092 #2 Posted April 11, 2025 I don't know either but this was posted recently Share this post Link to post Share on other sites
Lee1977 7,630 #3 Posted April 11, 2025 (edited) It just slides on. I used a 1 1/2" ABS pipe cut the angle, wasn't quite right sanded it on the belt sander until it fit the dash angle. Used two 6203 3/4" bearings the sanding bur stopped the bottom bearing. Cut about 1/2" of the pipe and cut 1" piece off the circle forced it inside the pipe and pushed it down to hold the top bearing. Sanded the steering shaft clean coated it with antisease and installed the bearings. The 5 ft. of 1 1/2" ABS was less the 6 bucks at Lowes and the bearing was good used ones I had. Edited April 11, 2025 by Lee1977 3 2 Share this post Link to post Share on other sites
peter lena 9,812 #4 Posted April 11, 2025 @Lee1977 GO NAVY ! PETE 1 Share this post Link to post Share on other sites
JCM 11,006 #5 Posted April 11, 2025 @stevebo Remove steering wheel, bowed washer, flat washer and slide off sleeve. K & B Has the sleeve. 2 Share this post Link to post Share on other sites
Lee1977 7,630 #6 Posted April 11, 2025 While you have it apart If you are going to keep it, "I use a 6472 flange bearing like on the lower steering shaft. 4 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #7 Posted April 12, 2025 9 hours ago, Lee1977 said: While you have it apart If you are going to keep it, "I use a 6472 flange bearing like on the lower steering shaft. I have done that too on other machines and makes a world of difference. Share this post Link to post Share on other sites
hcminis 1,762 #8 Posted April 13, 2025 @stevebo Daniel Baute just started making these as a 3D printed version. I have one if you want to try it. Give me a shout. You have my number Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #9 Posted April 14, 2025 All- I need to clarify something. I have one in good shape on my machine. Problem is that it is not attached to the dash and is just loose. How did it attach from the factory to the dash? Share this post Link to post Share on other sites
rmaynard 17,018 #10 Posted April 14, 2025 Mine was free-floating. No physical attachment. Only the angled cut keeping it from revolving. Share this post Link to post Share on other sites
oliver2-44 11,335 #11 Posted April 15, 2025 On 4/14/2025 at 7:29 AM, rmaynard said: Mine was free-floating. No physical attachment. Only the angled cut keeping it from revolving. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #12 Posted April 16, 2025 10 hours ago, oliver2-44 said: Must be something holding in place? Maybe some adhesive? Share this post Link to post Share on other sites
76c12091520h 4,129 #13 Posted April 16, 2025 They are just along for the ride, nothing holds it in place besides the steering shaft. Share this post Link to post Share on other sites
