8ntruck 8,327 #51 Posted April 10 (edited) Assuming the cylinder walls are 1/4" thick, an operating pressure of 3000psi, you should be making about 12 tons. The valve is rated at 18 gpm. I can't read the numbers on the pump tag, but the John S. Barns web sight gives 3 possible pump sizes - 8, 11, and 16 gpm pumps. Calculated full stroke (22.5") extension times are as follow: Valve limited 18gpm gives 2.6 seconds. A 16 gpm pump gives 2.9 seconds. An 11gpm pump gives 4.5 seconds. An 8gpm pump gives 6.1 seconds. Retract time will be about .9 times extend time. Total extend and retract times: Valve limited 18gpm is 4.9 seconds. 16gpm pump is 5.5 seconds. 11gpm pump is 8.5 seconds. 8gpm pump is 11.59 seconds. The 11 and 16 gpm pumps are listed as two stage pumps, so actual times might be a bit quicker. These calculations are based on assuming the pump is operating at 3600rpm, and that there are no flow restrictions in the system. Accurate? Not exactly, but good enough for comparing proposed systems. Edited April 10 by 8ntruck 1 1 Share this post Link to post Share on other sites
oliver2-44 11,039 #52 Posted April 10 4 hours ago, ebinmaine said: Cylinder outside diameter. 3.75 Piston diameter 1.75 Stroke appears to be about 24 but the collar eliminates some of that for the auto return so it comes out about 22.5? If you cylinder has a 3.75 diameter, then you piston diameter would be somewhere in the 3” - 3-1/4”. So is the 1.75 that you are referring to the rod-shaft diameter. Look closely at you cylinder to see if it has any manufactures name and info stamped in it. 1 Share this post Link to post Share on other sites
ebinmaine 75,666 #53 Posted April 10 5 hours ago, oliver2-44 said: Look closely at you cylinder to see if it has any manufactures name and info stamped in it. Couldn't find any but there old decals and thick red paint. Share this post Link to post Share on other sites
ebinmaine 75,666 #54 Posted April 10 6 hours ago, 8ntruck said: good enough for comparing proposed systems Perfect. We'll get the splitter running soon and time the movement. Thanks. Share this post Link to post Share on other sites
ebinmaine 75,666 #55 Posted April 11 @Oldskool Mike and I have been babbling a little bit about this by text. He brought up the possibility of using an electric motor. How do I figure out how much motor I need to be able to power a 16 GPM pump? 1 Share this post Link to post Share on other sites
kwalshy 241 #56 Posted April 11 electric motor HP = ( GPM x PSI ) / ( 1714 x % efficiency) I would probably use 85% or 90% efficiency, not 100%. or lower your pump GPM from 16 to 10 or 12 to use a smaller hp electric motor. you'll want 220VAC power source, not 110VAC 1 Share this post Link to post Share on other sites
ebinmaine 75,666 #57 Posted April 11 Given those calculations that would put an electric motor way out of scale for us. No worries there... Another thought. Given the fact that we have several Horses that run and drive I'm considering bolting a hydraulic pump like above right onto the side of a Kohler engine on a tractor and running a pair of quick disconnect hoses right to the hydraulic valve. If we did that on something like my 1975 C160 Automatic it would give it a non-snow chore to do and I have no intention of using the PTO on that for anything else. Another advantage there would be that if we bolted a new pump to the side of an existing engine that runs and drives there would be nearly zero changeover time. I do have concerns that if we are trying to connect and set up any other engine/motor right onto the splitter body there could be a little engineering involved. No time for that... Share this post Link to post Share on other sites
Handy Don 15,110 #58 Posted April 11 1 hour ago, ebinmaine said: bolting a hydraulic pump like above right onto the side of a Kohler engine on a tractor More than a few splitters are made to connect to remotes on larger tractors so I’d say it is a viable solution for your situation. Might even come in handy for some other hydraulic implement like a jib hoist 1 Share this post Link to post Share on other sites
8ntruck 8,327 #59 Posted April 12 . A while back, there was a thread about accessories that would be neat for a Wheel Horse. A pto powered log splitter came up on that list. Share this post Link to post Share on other sites
Wayne0 1,417 #60 Posted April 12 With a pump on the tractor side, a 3pt hitch splitter could be cobbled into a pull behind. 1 Share this post Link to post Share on other sites
wallfish 18,774 #61 Posted April 12 More than once I've thought about doing a cone/screw type splitter for the end of that back hoe. Basically just sit in the seat and poke them logs right on the ground to split'em up. Push the splits into a pile with the loader and then get started on the next batch. You could also screw into them part way to move the big logs around 2 Share this post Link to post Share on other sites
Wayne0 1,417 #62 Posted April 12 (edited) 1 hour ago, wallfish said: More than once I've thought about doing a cone/screw type splitter for the end of that back hoe. Basically just sit in the seat and poke them logs right on the ground to split'em up. Push the splits into a pile with the loader and then get started on the next batch. You could also screw into them part way to move the big logs around I had one of those once. It worked pretty good until the log wasn't supported and became a propeller! For speed, a Kinetic splitter is the way to go. Edited April 12 by Wayne0 Share this post Link to post Share on other sites
wallfish 18,774 #63 Posted April 12 1 hour ago, Wayne0 said: I had one of those once. It worked pretty good until the log wasn't supported and became a propeller! You couldn't just push it into the ground? 1 Share this post Link to post Share on other sites
ebinmaine 75,666 #64 Posted April 13 16 hours ago, Wayne0 said: For speed, a Kinetic splitter is the way to go. I agree with that but we won't be spending several thousand dollars to get a decent one. Share this post Link to post Share on other sites
ebinmaine 75,666 #65 Posted April 13 14 hours ago, wallfish said: You couldn't just push it into the ground? I've operated a Twist Splitter on a strong HAND DRILL. It was extremely difficult to control even at my personal oversized proportions. I can't begin to imagine the circular forces created by a medium sized hydraulic circuit. Share this post Link to post Share on other sites
ebinmaine 75,666 #66 Posted April 13 Looking at something like this: https://www.vevor.com/gear-pump-c_10084/vevor-hydraulic-wood-log-splitter-pump-kit-22gpm-2-stage-4000psi-aluminum-hydraulic-gear-pump-with-valve-coupling-installation-base-3-4-npt-outlet-3600-rpm-for-small-engine-mounting-log-splitter-p_010164497295 Does anyone know the mounting bolt circle on a Kohler big block? Share this post Link to post Share on other sites
Wayne0 1,417 #67 Posted April 13 3 hours ago, ebinmaine said: Looking at something like this: https://www.vevor.com/gear-pump-c_10084/vevor-hydraulic-wood-log-splitter-pump-kit-22gpm-2-stage-4000psi-aluminum-hydraulic-gear-pump-with-valve-coupling-installation-base-3-4-npt-outlet-3600-rpm-for-small-engine-mounting-log-splitter-p_010164497295 Does anyone know the mounting bolt circle on a Kohler big block? Real good price! Not sure about the durability of an aluminum pump though. No experience. 1 Share this post Link to post Share on other sites
ebinmaine 75,666 #68 Posted April 13 43 minutes ago, Wayne0 said: Real good price! Not sure about the durability of an aluminum pump though. No experience. Me either. The lower weight hanging out from an engine might be nice... Share this post Link to post Share on other sites
wallfish 18,774 #69 Posted April 13 5 hours ago, ebinmaine said: I've operated a Twist Splitter on a strong HAND DRILL. It was extremely difficult to control even at my personal oversized proportions. I can't begin to imagine the circular forces created by a medium sized hydraulic circuit. The long arm and weight of the hoe plus the tractor should be sufficient leverage and weight for the ground to be the log stop but had also thought of something if it wasn't. I realize you're not going this route but just throwing out ideas anyway. 2 Share this post Link to post Share on other sites
ebinmaine 75,666 #70 Posted April 16 Got this in the mail today. Share this post Link to post Share on other sites
wallfish 18,774 #71 Posted April 17 12 hours ago, ebinmaine said: Got this in the mail today. Perfect. I'll take 45 2x10s about 15-20 ft long and delivered this Sat. If you haven't set up a saw yet, there is a better way to sharpen/shape the chain teeth for ripping compared to cross cutting. 1 Share this post Link to post Share on other sites
ebinmaine 75,666 #72 Posted April 17 23 minutes ago, wallfish said: Perfect. I'll take 45 2x10s about 15-20 ft long and delivered this Sat. If you haven't set up a saw yet, there is a better way to sharpen/shape the chain teeth for ripping compared to cross cutting. Oh this isn't for a mill. This is the pivot point of the chainsaw for a cutting station. It'll get set up at the end of a sawbuck/horse. 1 Share this post Link to post Share on other sites
ebinmaine 75,666 #73 Posted April 25 (edited) On 4/12/2025 at 8:43 AM, Wayne0 said: With a pump on the tractor side, a 3pt hitch splitter could be cobbled into a pull behind. Trina and I were talking about the possibilities on this yesterday. I'm leaning heavily towards purchasing a new 16 gallon pump and bracket. That should get us a very good Improvement in overall speed. My latest thought might be to mount a pump at the side of a K341 such as on my 75 C160 Automatic. Have quick disconnect fittings in that pump. Run hoses down the side of the tractor past the trailer hitch and past the splitter, to the valve. I still want to add some sort of a wood catch table to the front of the splitter so that will lengthen the machine's frame. The hoses would have to be at least 12 to 16 ft long. But the tractor and splitter would remain connected for several months. Maybe 6 to 8 months at a time. 4 to 5 months a year, give or take, when I need the tractor as a snow pusher, I could pop that pump off and set it aside. Thoughts comments questions suggestions? Edited May 5 by ebinmaine 2 Share this post Link to post Share on other sites
ebinmaine 75,666 #74 Posted May 5 On 4/9/2025 at 10:42 PM, 8ntruck said: The valve is rated at 18 gpm. I can't read the numbers on the pump tag, but the John S. Barns web sight gives 3 possible pump sizes - 8, 11, and 16 gpm pumps. Calculated full stroke (22.5") extension times are as follow: Valve limited 18gpm gives 2.6 seconds. A 16 gpm pump gives 2.9 seconds. An 11gpm pump gives 4.5 seconds. An 8gpm pump gives 6.1 seconds. Retract time will be about .9 times extend time. Between getting Trina's mom moved in and dodging bad weather I've finally gotten back around to this. This past weekend I removed and rebuilt the carb so the machine is now operable again. I also moved the governor spring to the furthest point out so the RPM is higher. Still doesn't seem as high as the Kohlers but that doesn't matter right now. The numbers above by @8ntruck make more sense now. The pump has "K181" cast into the top. One could figure that's an 8 GPM pump because the single stroke movement is right around that 6 second timing. This could indicate that upgrading to a 16 GPM pump should just about double the machine's speed. 1 Share this post Link to post Share on other sites
8ntruck 8,327 #75 Posted May 5 That 6 second time is just the extend stroke? I found a website that gives more clues on your pump. For definite identification, you need the numbers stamped into the tag on the pump. Seems that John S Barnes got new ownership in 1997. The new company is Haldex Barnes Hydraulic. That website is Topkitparts. 1 Share this post Link to post Share on other sites
