WHX?? 53,357 #451 Posted June 12 1 hour ago, Pullhosen’s Pony Express said: ONE original barn find tombstone weight for sale. So much for taking care of your bros... Share this post Link to post Share on other sites
Ed Kennell 43,800 #452 Posted June 12 (edited) 5 hours ago, cafoose said: So far I found 1 set that's 54 inches long. The circumference of the tires are 81". The width is 6 inches. How wide are the tires Chuck? Here are some pics of some of my new sets. I have two pair of each of these. 8 link for 7-8" wide tire 6 link for 5-7" wide tire this is the best for a 6" wide tire 9 link for 7-9" wide tire Edited June 12 by Ed Kennell Share this post Link to post Share on other sites
Pullstart 68,529 #453 Posted June 13 3 hours ago, WHX?? said: So much for taking care of your bros... we’ll find more 1 Share this post Link to post Share on other sites
cafoose 3,524 #454 Posted June 13 4 hours ago, Ed Kennell said: How wide are the tires Chuck? My tires are 6 inches wide Ed. I put a string around the tread and measured the string and got 81 inches circumference around the tires. Share this post Link to post Share on other sites
cafoose 3,524 #455 Posted June 13 9 hours ago, sqrlgtr said: just let me know if I can help. Maybe if you help I'll let you try out the 953 some day 1 1 1 Share this post Link to post Share on other sites
sqrlgtr 1,345 #456 Posted June 13 Just let me swap you out of mower and you want have to worry about finding chains for traction 3 Share this post Link to post Share on other sites
Pullstart 68,529 #457 Posted June 13 @cafoose it may be worth while to load your tires too. I have found on the sickle machine, I have no weights on the right side, but double stacked weights on the left. 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,600 #458 Posted June 13 I am looking for 1 front wheel off a 520 with swept forward steering. Lmk if you have an extra. Share this post Link to post Share on other sites
Pullstart 68,529 #459 Posted June 13 Real nice 2 piece seat. It’s not perfect, but a great survivor! $175 1 1 Share this post Link to post Share on other sites
Bill D 2,442 #460 Posted June 13 6 hours ago, stevebo said: I am looking for 1 front wheel off a 520 with swept forward steering. Lmk if you have an extra. I have some 4 lug wheels if you want to do a trailer hub conversion. Share this post Link to post Share on other sites
cafoose 3,524 #461 Posted June 14 @Ed Kennell Any suggestions on what type and where I can get tire chain repair tools? I found a few sets of 2 link chains here I got from the Big Show. They are all too sort so I need to extend them and then I believe they will work. I think I got a box of tire chain parts from you Ed when I got the 953. I just need to locate them Share this post Link to post Share on other sites
Ed Kennell 43,800 #462 Posted June 14 15 minutes ago, cafoose said: Any suggestions on what type and where I have a small set like this. They work fine for these light duty chains. Harbor Freight, NAPA ? 2 Share this post Link to post Share on other sites
cafoose 3,524 #463 Posted June 14 47 minutes ago, Ed Kennell said: have a small set like this I saw that you stole the picture you posted from Ed I just bought the same ones from a guy in Hanover. I also got this to extend my chains so I think I'll be set 2 Share this post Link to post Share on other sites
Ed Kennell 43,800 #464 Posted June 14 (edited) 19 minutes ago, cafoose said: saw that you stole the picture Yeah, I was too lazy to walk downstairs to take a pic of mine. I also have an 18" long handled set, but the small set works fine. Course I get mine at the auction for a buck. Those coupling links work well. I make the inside chain the exact length and use one of the coupling links to make the connection. Then make the outside chain a couple links longer and use the cam tightener on the outside. Edited June 14 by Ed Kennell 1 Share this post Link to post Share on other sites
fast88pu 3,372 #465 Posted June 14 Set of kenda terra trac 16x6.50x8. Were mounted and took a lap around the lawn then un mounted. Still have nubs on them. $100 for the set Share this post Link to post Share on other sites
fast88pu 3,372 #466 Posted June 14 1 carlise all trail 25x10.50x12 nubs still on side wall. No holes, plugs, patches. $50 Share this post Link to post Share on other sites
fast88pu 3,372 #467 Posted June 14 Set of sunf 25x10x12 copy of the all trail. Mounted and one lap around the yard then removed. Still have the nuts. $200 Share this post Link to post Share on other sites
c-series don 10,787 #468 Posted June 14 (edited) 48” deck with good spindles, cuts fine couple of minor holes. With Powerflow bagger system. Couple of holes in the bag. $175 OBO Edited June 16 by c-series don 1 Share this post Link to post Share on other sites
clueless 3,331 #469 Posted June 14 On 6/5/2025 at 9:42 PM, Lane Ranger said: I will bring this round hood (7 inch wide frame like 701,702 , 753. Etc.) home made weight if someone is interested in it and front frame I made for this heavy weight. Front frame bolts into factory frame side bolt holes and has welded tabs on it to ride on top of frame behind front of round hood. $125 I'll take it 1 Share this post Link to post Share on other sites
Handy Don 15,219 #470 Posted June 14 (edited) 7 minutes ago, clueless said: 7 minutes ago, clueless said: I'll take it Just an FYI that this will not fit in front of an 854’s unique, one-inch-longer hood without modifying the support frame Edited June 14 by Handy Don 2 Share this post Link to post Share on other sites
fast88pu 3,372 #471 Posted June 14 Toro wheel horse seeder good condition. $ 100 obo. Share this post Link to post Share on other sites
sqrlgtr 1,345 #472 Posted June 14 Almost forgot looking for a set of Vredestein V61 Front Tires size 16X6.50-8 also.. Share this post Link to post Share on other sites
whtractors24 3,443 #473 Posted June 14 Looking for a original seat cover / backrest (860) 681-3610 Share this post Link to post Share on other sites
Docwheelhorse 2,792 #474 Posted June 14 1985 308-8 Clean... runs good, good battery, swapped on rot free 16" fronts and 23" rears. 36" deck...not silent but still very useable. Have original solid red hood and will include it. I just got a good deal on an 1848 and will pass on a deal to somebody that wants a 308. $350... no dicker sticker... Hauled to show free or pickup in Andover CT 06232 Thanks Tony SOME PICS ARE OF TRACTOR WITH THE OLD SMALLER 15" / 22" tires. It has the 16" / 23" now 1 Share this post Link to post Share on other sites
PWL216 1,134 #475 Posted June 14 4 minutes ago, Docwheelhorse said: 1985 308-8 Clean... runs good, good battery, swapped on rot free 16" fronts and 23" rears. 36" deck...not silent but still very useable. Have original solid red hood and will include it. I just got a good deal on an 1848 and will pass on a deal to somebody that wants a 308. $350... no dicker sticker... Hauled to show free or pickup in Andover CT 06232 Thanks Tony SOME PICS ARE OF TRACTOR WITH THE OLD SMALLER 15" / 22" tires. It has the 16" / 23" now Hi @Docwheelhorse I’ll take the 308 and pick it up in CT. Thx! Paul Share this post Link to post Share on other sites
