DeHart16 37 #1 Posted February 17, 2025 The belt for my starter generator on my 753 went flying off, I replaced it, and soon as I did I had smoke from what looked like under the carb? Drove it for 5 minutes n heard a loud pop, or bang. now I can’t get it running? Sounds like fly wheel isn’t catching? Share this post Link to post Share on other sites
pfrederi 21,278 #2 Posted February 17, 2025 Have you taken the belt cover of sounds like you may have smoked your new belt which then broke making the noise... 2 Share this post Link to post Share on other sites
ri702bill 13,299 #3 Posted February 17, 2025 My money is that the belt is the victim, not the cause. Check the S/G for ease of rotation with the belt off. It should spin freely without drag... yours probably won't. 4 Share this post Link to post Share on other sites
DeHart16 37 #4 Posted February 18, 2025 Well new belt did not break…..I am trying to post video but apparently the file is too big…. Share this post Link to post Share on other sites
pfrederi 21,278 #5 Posted February 18, 2025 Is the belt slipping on the S/G or the Flywheel Share this post Link to post Share on other sites
Achto 32,915 #6 Posted February 18, 2025 1 hour ago, DeHart16 said: I am trying to post video but apparently the file is too big Best to post it on YouTube & then post the link here. 1 Share this post Link to post Share on other sites
DeHart16 37 #7 Posted February 19, 2025 Thanks guys, here is a link to the video. There was smoke coming from. Possibly above the points area on engine prior to hearing the pop/crack…. Share this post Link to post Share on other sites
pfrederi 21,278 #8 Posted February 19, 2025 Can't see any smoke... Take the belt off the S/G push the starter button let the S/G start spinning and listen for noise..bad bearing or internal issue?? Share this post Link to post Share on other sites
rmaynard 17,636 #9 Posted February 19, 2025 It's spinning a little too fast for the S/G to be turning over an engine with compression. Take off the belt and see how freely the engine turns. I hate to say it but it sounds like something broken inside the crankcase. 3 1 1 Share this post Link to post Share on other sites
DeHart16 37 #10 Posted February 19, 2025 So knowing little to nothing about engines, I assume that would mean I need a knew one? Share this post Link to post Share on other sites
rmaynard 17,636 #11 Posted February 19, 2025 Nope, just needs to be rebuilt. 2 Share this post Link to post Share on other sites
DeHart16 37 #12 Posted February 19, 2025 Ah jeez. Anyone on here doing that kinda work? I assume it would be expensive. Or maybe a tutorial on doing it myself? Share this post Link to post Share on other sites
953 nut 70,221 #13 Posted February 20, 2025 17 hours ago, DeHart16 said: Ah jeez. Anyone on here doing that kinda work? I assume it would be expensive. Or maybe a tutorial on doing it myself? Member @richmondred01 is an engine rebuilder or you can use the thread below to do it your self. 1 Share this post Link to post Share on other sites
squonk 48,305 #14 Posted February 20, 2025 Probably broke the connecting rod. When it let go, it locked up for a second and that's why the belt flew off. 1 Share this post Link to post Share on other sites
richmondred01 2,393 #15 Posted February 20, 2025 Your rod is broken. Share this post Link to post Share on other sites
richmondred01 2,393 #16 Posted February 20, 2025 (edited) If it chipped the apron skirt you will need to sleeve the cylinder. Edited February 20, 2025 by richmondred01 3 Share this post Link to post Share on other sites
RED-Z06 2,720 #17 Posted February 20, 2025 Where was the oil level at failure? Share this post Link to post Share on other sites
Wheelhorse#1 1,998 #18 Posted February 21, 2025 9 hours ago, richmondred01 said: If it chipped the apron skirt you will need to sleeve the cylinder. @richmondred01Would it run without being sleeved if the skirt was broken ? Share this post Link to post Share on other sites
RED-Z06 2,720 #19 Posted February 21, 2025 16 minutes ago, Wheelhorse#1 said: @richmondred01Would it run without being sleeved if the skirt was broken ? If the cylinder is broken high enough that the thrust face of the piston pushes into it, or if the ring catch it, it might run...briefly, the cylinder skirt helps to stabilize the piston at the bottom of the stroke. 2 Share this post Link to post Share on other sites
richmondred01 2,393 #20 Posted February 21, 2025 1 hour ago, Wheelhorse#1 said: @richmondred01Would it run without being sleeved if the skirt was broken ? It may run for awhile, maybe not, but why do a have smacked job? Do it once and do it right. 2 Share this post Link to post Share on other sites
