ebinmaine 80,085 #1 Posted February 9, 2025 I was chewing my way through pushing the snowbank back and broke through a layer of ice into the leaves. FOOOP! Down she goes. Right to the frame. 1 1 18 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #2 Posted February 9, 2025 If that would have been an 8 speed you could have left it in low range reverse and walked away and let it eat itself out....or dig a couple holes to plant some trees this spring So did the dig out work or did the green rig get some recovery fun? 1 2 Share this post Link to post Share on other sites
ebinmaine 80,085 #3 Posted February 9, 2025 5 minutes ago, OutdoorEnvy said: If that would have been an 8 speed you could have left it in low range reverse and walked away and let it eat itself out....or dig a couple holes to plant some trees this spring So did the dig out work or did the green rig get some recovery fun? Definitely would've been tree planting holes. 🕳 She set right down in there fast as could be an' STUCK. We took turns shoveling. Just a few minutes it was out. 5 Share this post Link to post Share on other sites
JCM 11,342 #4 Posted February 9, 2025 (edited) Don't feel bad . It happens. Inquisitive minds like we both have can sometimes lead us to say, why did I do that ? Knowing full well beforehand it was NOT a good idea. You know how I know we think alike, I got the 5000 lb JD off the beaten path trying to get over the brook headed to the house from the Cabin 2 hours ago plowing out back. I was almost out of options then I realized I had a small pedal to engage the diff lock and by golly it got me out. Had it in 4 wheel drive as well. How did you make out Bro ? We got an additional 8'' of snow. Just read the outcome. Edited February 9, 2025 by JCM 4 1 Share this post Link to post Share on other sites
ebinmaine 80,085 #5 Posted February 9, 2025 11 minutes ago, JCM said: Don't feel bad . It happens. Inquisitive minds like we both have can sometimes lead us to say, why did I do that ? Knowing full well beforehand it was NOT a good idea. You know how I know we think alike, I got the 5000 lb JD off the beaten path trying to get over the brook headed to the house from the Cabin 2 hours ago plowing out back. I was almost out of options then I realized I had a small pedal to engage the diff lock and by golly it got me out. Had it in 4 wheel drive as well. How did you make out Bro ? We got an additional 8'' of snow. Just read the outcome. Diff lock would be wicked handy. I've thought several times about changing this transmission to a Limited Slip Differential but I really like the brute strength of the 8 pinions. 10" of light fluff here. 2 Share this post Link to post Share on other sites
ri702bill 12,696 #6 Posted February 9, 2025 That is a tough scenario. That straight pass with the blade centered leaves precious little wiggle room to get it free. Low range in reverse and a tug from one of the others in the herd works. That is why all of ours have a hitch with either a ball or eyebolt.... 1 Share this post Link to post Share on other sites
ebinmaine 80,085 #7 Posted February 9, 2025 6 minutes ago, ri702bill said: That is a tough scenario. That straight pass with the blade centered leaves precious little wiggle room to get it free. Low range in reverse and a tug from one of the others in the herd works. That is why all of ours have a hitch with either a ball or eyebolt.... This is far and away the heaviest tractor in our Herd. Over 1400 lbs with me on it. There's nothing we have that'll tug that. And it was STUFFED in the two rear tire holes. When I get stuck I do it well !!! 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,002 #8 Posted February 9, 2025 So... Simple question: Would a chain break pulling you out if the wind was calm and there was no reason to believe asking that question would result in a 50 page back and forth on the static vs dynamic load limits of fruit if the loom underwear size 3x??? Asking for a friend... 7 Share this post Link to post Share on other sites
ebinmaine 80,085 #9 Posted February 9, 2025 17 minutes ago, SylvanLakeWH said: So... Simple question: Would a chain break pulling you out if the wind was calm and there was no reason to believe asking that question would result in a 50 page back and forth on the static vs dynamic load limits of fruit if the loom underwear size 3x??? Asking for a friend... I dunno.... @Pullstart ya wanna field this one for me? 3 1 Share this post Link to post Share on other sites
adsm08 4,903 #10 Posted February 9, 2025 31 minutes ago, SylvanLakeWH said: So... Simple question: Would a chain break pulling you out if the wind was calm and there was no reason to believe asking that question would result in a 50 page back and forth on the static vs dynamic load limits of fruit if the loom underwear size 3x??? Asking for a friend... 42 3 1 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 2,084 #11 Posted February 9, 2025 22 minutes ago, adsm08 said: 42 That answer is correct everywhere in the universe. 3 2 Share this post Link to post Share on other sites
squonk 47,741 #12 Posted February 9, 2025 Had something similar happen today: We only got a couple of inches of snow but we had a bunch of ice/snow the other day and I was out scraping down the front walk with HHHOOOWWWAAARRRDDD!!!. My next door neighbor has all driveway about 8 cars wide but an entrance like 2 cars wide. My side walk meets his parking area. At the entrance there is a large deep storm drain which is the only drain on my street. Another neighbor was shoveling his drive way and had the snow piled up in the wrong spot near that drain. I came over and moved that pile very carefully because I knew that drain was there. I was just about done but decided to make 1 more pass. FOOOP! The RF wheel sank into the drain. I was able to leave it in rev and push it back out but had to scramble to stop it once it was out. 2 5 Share this post Link to post Share on other sites
rjg854 13,269 #13 Posted February 9, 2025 @squonk we really need a video of that. 3 1 Share this post Link to post Share on other sites
squonk 47,741 #14 Posted February 9, 2025 Did the same thing with the Power King years ago but used the loader to pick the wheels out of the drain. 2 Share this post Link to post Share on other sites
Pullstart 71,004 #15 Posted February 10, 2025 I mean… it looks well parked to me… 3 1 Share this post Link to post Share on other sites
AlexR 3,083 #16 Posted February 10, 2025 Should have given it a slap and said that ain't going nowhere. Ohh wait!! That's when you need it to stay 3 Share this post Link to post Share on other sites
adsm08 4,903 #17 Posted February 10, 2025 I did something like that to my dad's 310-8 years ago. Our yard was the drain field for an entire hillside above the house. Soil is red clay less than 12 inches down, so it gets a bit swampy. I dug the rear in until it was resting on the deck. Took the truck to drag it out. 1 Share this post Link to post Share on other sites
siebenaler 114 #18 Posted February 10, 2025 Holy crap wish we had that much snow. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,902 #19 Posted February 10, 2025 Wow I now what you mean. I did that on a hill in the back yard full of leaves. What a day. Glade you got it out. 1 Share this post Link to post Share on other sites
ebinmaine 80,085 #20 Posted February 10, 2025 9 hours ago, Mark siebenaler said: Holy crap wish we had that much snow. No worries. We have more coming this week. I can package some up and send it down... 13 hours ago, squonk said: FOOOP Two FOOOPs in the same storm!!!!! Share this post Link to post Share on other sites
Pullstart 71,004 #21 Posted February 10, 2025 Here’s a two fooop too. A week or two ago there was a car in the ditch pretty bad at the end of our road. I went to go help, and began by planning to plow the road a bit and make a clearing to pull. Well, I miss calculated the ditch. Fooop! 2 2 1 Share this post Link to post Share on other sites
rjg854 13,269 #22 Posted February 10, 2025 3 minutes ago, Pullstart said: Here’s a two fooop too. A week or two ago there was a car in the ditch pretty bad at the end of our road. I went to go help, and began by planning to plow the road a bit and make a clearing to pull. Well, I miss calculated the ditch. Fooop! That looks stuck 1 2 Share this post Link to post Share on other sites
Pullstart 71,004 #23 Posted February 10, 2025 (edited) 8 minutes ago, rjg854 said: That looks stuck Between my truck, Mrs. P’s 550 hp Suburban and the lifted Dodge, it took 12 wheels turning and over 1,000 hp to get me out! I was up to the top of my passenger fender in the ditch, and the plow was buried too. My little military shovel got quite the work out! We also lowered the cylinder on the plow and shortened the chains about 8”, getting it some extra and much needed clearance. *I won’t mention how many times we snapped the 4” yank strap, but Mrs. P managed to do this to the bolt I had in her her hitch… Edited February 10, 2025 by Pullstart 6 Share this post Link to post Share on other sites
SylvanLakeWH 32,002 #24 Posted February 10, 2025 "No chains were broken in the retrieval of this vehicle..." 1 2 Share this post Link to post Share on other sites
lynnmor 8,970 #25 Posted February 10, 2025 24 minutes ago, Pullstart said: Here’s a two fooop too. A week or two ago there was a car in the ditch pretty bad at the end of our road. I went to go help, and began by planning to plow the road a bit and make a clearing to pull. Well, I miss calculated the ditch. Fooop! No good deed will go unpunished! 1 2 Share this post Link to post Share on other sites
