WHX?? 56,109 #26 Posted February 9, 2025 Definitely need a new plunger and something doesn't look right with the inlet seat. Correct one would not have the screwdriver slots. When rebuilding carbs ALWAYS use a Kohler kit. That one has not. The needles look pretty rough too. @ebinmaine care to add? Time for a new carb. Try https://isavetractors.com/ or yes K&B if not fond of offshores. http://www.psep.biz/index.htm used to have them best call to see if they still do. if you see them for this price it's an off shore https://www.amazon.com/labwork-Carburetor-Kohler-4685301-S-4605303-S/dp/B0719B6PD5/ref=asc_df_B0719B6PD5?mcid=349f01a53b0f344693cf781c0f2421f8&tag=hyprod-20&linkCode=df0&hvadid=693770001515&hvpos=&hvnetw=g&hvrand=4393961188063983633&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019459&hvtargid=pla-523073608488&psc=1 Personally i've not had much problems with them but others have reported bad luck. Points push rod may be found here http://www.psep.biz/store/kohler_points_condensers.htm but again best call. I don't have one apart to get a measurement on length. Share this post Link to post Share on other sites
WHX?? 56,109 #27 Posted February 9, 2025 3 hours ago, pfrederi said: Kohler used 2 different point plungers over the year. Yes I thought one was aluminum and one was steel I could be wrong. I do remember one was favored over the other. Could apply to big blocks tho. Share this post Link to post Share on other sites
ebinmaine 78,298 #28 Posted February 9, 2025 10 hours ago, WHX?? said: @ebinmaine care to add? Time for a new carb @76c12091520h Brian or @Jake Kuhn Or CALL Lincoln at A to Z Tractor in PA. I buy almost nothing from isavetractors. I like Norman as a guy but I just can't justify the cost considering I've seen two of his supposedly better than cheapo carbs worn right out after a short life. That's not good money sense. Folks seem to have better luck with small block Kohler carbs than big block carbs as far as cheapos. Personally - I’m finished running any aftermarket carb on any older engines until I can't replace the originals at all. Share this post Link to post Share on other sites
dmoore 1,024 #29 Posted February 9, 2025 11 hours ago, WHX?? said: Definitely need a new plunger and something doesn't look right with the inlet seat. Correct one would not have the screwdriver slots. When rebuilding carbs ALWAYS use a Kohler kit. That one has not. The needles look pretty rough too. @ebinmaine care to add? Time for a new carb. Try https://isavetractors.com/ or yes K&B if not fond of offshores. http://www.psep.biz/index.htm used to have them best call to see if they still do. if you see them for this price it's an off shore https://www.amazon.com/labwork-Carburetor-Kohler-4685301-S-4605303-S/dp/B0719B6PD5/ref=asc_df_B0719B6PD5?mcid=349f01a53b0f344693cf781c0f2421f8&tag=hyprod-20&linkCode=df0&hvadid=693770001515&hvpos=&hvnetw=g&hvrand=4393961188063983633&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019459&hvtargid=pla-523073608488&psc=1 Personally i've not had much problems with them but others have reported bad luck. Points push rod may be found here http://www.psep.biz/store/kohler_points_condensers.htm but again best call. I don't have one apart to get a measurement on length. That's what you get nowadays in a kit. Share this post Link to post Share on other sites
dmoore 1,024 #30 Posted February 9, 2025 11 hours ago, WHX?? said: Definitely need a new plunger and something doesn't look right with the inlet seat. Correct one would not have the screwdriver slots. When rebuilding carbs ALWAYS use a Kohler kit. That one has not. The needles look pretty rough too. @ebinmaine care to add? Time for a new carb. Try https://isavetractors.com/ or yes K&B if not fond of offshores. http://www.psep.biz/index.htm used to have them best call to see if they still do. if you see them for this price it's an off shore https://www.amazon.com/labwork-Carburetor-Kohler-4685301-S-4605303-S/dp/B0719B6PD5/ref=asc_df_B0719B6PD5?mcid=349f01a53b0f344693cf781c0f2421f8&tag=hyprod-20&linkCode=df0&hvadid=693770001515&hvpos=&hvnetw=g&hvrand=4393961188063983633&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019459&hvtargid=pla-523073608488&psc=1 Personally i've not had much problems with them but others have reported bad luck. Points push rod may be found here http://www.psep.biz/store/kohler_points_condensers.htm but again best call. I don't have one apart to get a measurement on length. $46.00 for that little points rod?? Ha! Yeah,ok....And $18.00 for the other??? Must be rare as hen's teeth! Share this post Link to post Share on other sites
WHX?? 56,109 #31 Posted February 9, 2025 Just now, dmoore said: That's what you get nowadays in a kit. Yes Mr. Moore in the offshore kits which aren't worth a hill of beans and again are dirt cheap ... 4 for 10 bucks. Ok if you are just going to use the gaskets for bowl cleanings but DO NOT use the the inlet parts they will not work. You must get the one that are in the Kohler packages --- around 15 for one! 2 minutes ago, dmoore said: $46.00 for that little points rod?? Ha! Yeah,ok....And $18.00 for the other??? Must be rare as hen's teeth! I agree Kohler parts are getting nuts but shop around ... You'll find them much cheaper. You can get the ones for big blocks and trim to length. Diameter is the same. https://isavetractors.com/points-plunger-push-rod-for-kohler-k-series-engines/?srsltid=AfmBOoos0L-Clw265Q-caDq3CbGTmOugMeqpbmPTnT2GHevfFP-d_JUik8E&gQT=2 https://www.ebay.com/itm/186557649517?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOoptpfagZ3O8U3riWmlzHizIRpFBm-rlqwlq9EfbvG6c9VglZTfUiAs&com_cvv=8fb3d522dc163aeadb66e08cd7450cbbdddc64c6cf2e8891f6d48747c6d56d2c 1 Share this post Link to post Share on other sites
pfrederi 20,271 #32 Posted February 9, 2025 Points push rod apparently changed after a point. If you google eh Kohler Kit 220506 (used on older engines) it comes with two different push rods. 4 Share this post Link to post Share on other sites
Handy Don 16,278 #33 Posted February 9, 2025 2 hours ago, dmoore said: $46.00 for that little points rod?? Ha! Yeah,ok....And $18.00 for the other??? Must be rare as hen's teeth! Low volume, low demand, significant cost of carrying stock. Share this post Link to post Share on other sites
Achto 31,590 #34 Posted February 9, 2025 On 2/7/2025 at 9:25 PM, WHX?? said: Wasn't that the McClean @Achto that went for a 30 puller to a 2 with closing the gap to 018? Yep that was on the McLean Share this post Link to post Share on other sites
dmoore 1,024 #35 Posted February 25, 2025 Brian sent me a nice restored carb. I'd love to try it but still battling no spark condition. I have another thread going under "Electrical". Share this post Link to post Share on other sites
