ebinmaine 71,774 #26 Posted January 4 9 hours ago, Easton Rich said: What would be the correct offset? They vary a little over the years. I believe you'd need a backspacing around 1 3/8" to MAYBE 2". That might be too deep. Depending on Class Rules you MAY be able to use wheel spacers like my workers have. For performance parts there's another company to look at called Midwest Super Cubs. 1 Share this post Link to post Share on other sites
Easton Rich 601 #27 Posted January 4 I’ll check my rules 1 Share this post Link to post Share on other sites
Easton Rich 601 #28 Posted January 4 What kind of spacer would I need with these? https://vogelmanufacturing.com/vmtt23-tires-on-vm-wheels.html Share this post Link to post Share on other sites
ebinmaine 71,774 #29 Posted January 4 1 hour ago, Easton Rich said: What kind of spacer would I need with these? https://vogelmanufacturing.com/vmtt23-tires-on-vm-wheels.html They're available in two different spacing sets. With the larger of the two you'd need multiple spacers per side. With the 4 / 6 spacing I don't know if that's a reversible figure. If so, a 2" spacer might work. I'd offer caution and awareness on these for several reasons: 1. Shipping could be EXTREMELY expensive. 2. Your racing class might not allow them. 3. You will have another $100 or so into the spacers. By the time you buy the two tires and all needed parts plus freight you could easily go at or over $1000. I'd be willing to bet there's a much less expensive option to get wide AGs. Like stock sized 520H wheels with BKT TR315 Trencher tires. Share this post Link to post Share on other sites
TonyToro Jr. 1,846 #30 Posted January 4 17 hours ago, Easton Rich said: @TonyToro Jr. I saw you talked about Vogel Manufacturing, are their tires or engine parts any good? @Easton Rich Thanks for the shout! Vogel makes very good parts. Engine parts are very good and shipped fast. Rims are good. Tires it all depends on what you’re pulling. Stone boat or transfer sled? Also what class are you planning on? Bone stock? Share this post Link to post Share on other sites
Easton Rich 601 #31 Posted January 4 No stock -modified 1 Share this post Link to post Share on other sites
Easton Rich 601 #33 Posted January 4 Ok I’m not real savvy with that kind of thing @ebinmaine 1 Share this post Link to post Share on other sites
Easton Rich 601 #34 Posted January 4 What should I do? 1 Share this post Link to post Share on other sites
ebinmaine 71,774 #35 Posted January 4 2 minutes ago, Easton Rich said: Ok I’m not real savvy with that kind of thing @ebinmaine No worries. You'll learn. I don't pull in competition but my tractors use some of the same principles. We move some rugged loads here. Share this post Link to post Share on other sites
ebinmaine 71,774 #36 Posted January 4 2 minutes ago, Easton Rich said: What should I do? Nice clean careful cleaning is your first order of business. Then you can see what you're working with. Share this post Link to post Share on other sites
TonyToro Jr. 1,846 #37 Posted January 4 When we built the engine for my Economy stock this year out of and K series 14. Had about 18 hp with Midwest super cubs Piston, Rings, and Connecting rod. Then ordered a Vogel cam and valves and got 28hp out of it. So I’m happy with their stuff. 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,846 #38 Posted January 4 9 minutes ago, Easton Rich said: No stock -modified Ok. Could you post up the rules for your club? Is there any speed limit in that class? 1 Share this post Link to post Share on other sites
Easton Rich 601 #39 Posted January 4 I am going to have my local machine shop shave the head 0.050 over and I’m thinking about a cam Share this post Link to post Share on other sites
ebinmaine 71,774 #40 Posted January 4 2 minutes ago, TonyToro Jr. said: When we built the engine for my Economy stock this year out of and K series 14. Had about 18 hp with Midwest super cubs Piston, Rings, and Connecting rod. Then ordered a Vogel cam and valves and got 28hp out of it. So I’m happy with their stuff. You have access to a dyno or is that experience knowing/ estimates? What RPM? Share this post Link to post Share on other sites
Easton Rich 601 #41 Posted January 4 @ebinmaine I’m very limited to what I can do, it like 10 out right now. Share this post Link to post Share on other sites
Easton Rich 601 #42 Posted January 4 How do you clean your engine internals? Share this post Link to post Share on other sites
Easton Rich 601 #43 Posted January 4 Just learning others ways 1 Share this post Link to post Share on other sites
ebinmaine 71,774 #44 Posted January 4 3 minutes ago, Easton Rich said: @ebinmaine I’m very limited to what I can do, it like 10 out right now. 🥶 Share this post Link to post Share on other sites
ebinmaine 71,774 #45 Posted January 4 6 minutes ago, Easton Rich said: How do you clean your engine internals? The area you can see around the valves and piston can be done carefully with a light duty wire brush AND A VACUUM. Same for rest of the outside of the block. Share this post Link to post Share on other sites
peter lena 9,184 #46 Posted January 4 @Easton Rich are you talking paint patina / vintage ? of recovery ? my typical look at a long neglected tractor or any used to be painted anything is the OPPORTUNITY to retain that with an oiled look , IRONICALLY YOUR FRONT AXEL ENDS are showing you what a lubrication soak , starts . personally would NOT REMOVE ANY OF THAT PAINT IN ANY WAY / knock r loose , penetrant , is a good spray down and let it sit , till the moisture soak in , then rub it down , with more penetrant , let soak , or mineral oil , like a clean soft cloth , any paint that lightly pulls out with an deeper oil look would be perfect on that . BTW first thing I do on any old painted finish , is to get a lube spray down going on , your clean oiled cloth rub down will show you how its going . my paint recoverys , on just starting a fade , usually buff right out , would let that paint absorb , lubricant first , used 6 " electric palm buffer , cleaner wax to pull these out , yours would be darker OILED PATINA , good fit for era, pete Share this post Link to post Share on other sites
TonyToro Jr. 1,846 #47 Posted January 4 23 minutes ago, ebinmaine said: You have access to a dyno or is that experience knowing/ estimates? What RPM? Yes we had access to a dyno. It was at 4000 RPM 2 1 Share this post Link to post Share on other sites
ebinmaine 71,774 #48 Posted January 4 3 minutes ago, TonyToro Jr. said: Yes we had access to a dyno. It was at 4000 RPM Very cool Share this post Link to post Share on other sites
ebinmaine 71,774 #49 Posted January 4 29 minutes ago, Easton Rich said: I am going to have my local machine shop shave the head 0.050 over and I’m thinking about a cam Double check with the machine shop or piston supplier to understand where the piston top will be at full RPM and Top Dead Center. A stock setup will likely be lower than the engine block but an aftermarket piston could come up higher. That changes your spacing for valves and cylinder head. Remember that the camshaft is literally the controller of your engine and it's scope of breathing. Be aware of the RPM potential and its limitations. The stock rod and flywheel should NEVER be pushed past 4000. Share this post Link to post Share on other sites
TonyToro Jr. 1,846 #50 Posted January 4 1 minute ago, ebinmaine said: Be aware of the RPM potential and its limitations. The stock rod and flywheel should NEVER be pushed past 4000. In our club this is the last class that can have the stock flywheel. All the others need to have aftermarket usually billet flywheels 🤑🤑🤑 1 Share this post Link to post Share on other sites
