Bar Nuthin 1,172 #26 Posted April 30 5 hours ago, ebinmaine said: After a series of "delay in game".... I'm getting back to this soon. I'm interested to learn how you make out on the shims. That's the one item I don't have - and NOS seem expensive for what they are. I'm contemplating using washers or trimming a small piece off the end of a stainless machine screw. 1 Share this post Link to post Share on other sites
ebinmaine 73,593 #27 Posted April 30 1 hour ago, Bar Nuthin said: I'm interested to learn how you make out on the shims. That's the one item I don't have - and NOS seem expensive for what they are. I'm contemplating using washers or trimming a small piece off the end of a stainless machine screw. I'm reasonably sure I won't be needing new shims for my operation because I (should have) a set of the required parts in my own '70 Charger pump or the '78 C141 parts tractor. Share this post Link to post Share on other sites
ineedanother 1,686 #28 Posted May 1 This thread is timely...I just moved hydro lift from a spent, abused, '75 c-160 to a '73 Electro 12 with a manual lift but a 10 pinion L/S differential. I moved the K341 too because it was smokeless and I don't really care about the fuel consumption. The point is that the '75 c-160 with the 1140 didn't have any shims. Everything moved right onto the 1136 and is working fine. 2 1 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #29 Posted May 1 1 hour ago, ebinmaine said: I'm reasonably sure I won't be needing new shims for my operation because I (should have) a set of the required parts in my own '70 Charger pump or the '78 C141 parts tractor. It sounds like there's a chance no shims are needed at all - othewise add one at a time. I guess I'll cross that bridge when I get to it. 2 Share this post Link to post Share on other sites
gt14rider 960 #30 Posted May 1 Have to get back to my list, and notes.not good with computers, pick and search, pick and search. Got most of it written down, just have to type it in. 2 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #31 Posted May 1 8 minutes ago, gt14rider said: Have to get back to my list, and notes.not good with computers, pick and search, pick and search. Got most of it written down, just have to type it in. For not being good with computers, you've certainly shown a lot of fortitude to research, document, and collect all of the parts! Mad respect! 1 1 Share this post Link to post Share on other sites
ineedanother 1,686 #32 Posted May 2 23 hours ago, Bar Nuthin said: It sounds like there's a chance no shims are needed at all - othewise add one at a time. I guess I'll cross that bridge when I get to it. ...and beyond that, what exactly are these rather pricey shims? Neither one of my hydros has them so I've never seen them but images don't show them to be anything that couldn't be duplicated in a shop pretty easily IMO. What says the brain trust who has experience with the "shim set"? 2 Share this post Link to post Share on other sites
ebinmaine 73,593 #33 Posted May 14 Messing around with the 1978/79 C141 Hydro parts chassis this evening. Previously I'd removed a few things. Tonight I got the gas tank out and removed the rear hydro hoses. Also pulled the valve out with 3 of 4 hoses connected. 1 Share this post Link to post Share on other sites
ebinmaine 73,593 #34 Posted May 14 1978/79 C141 hydro WITH hydro lift. This pic is a tad fuzzy but gets the point through. Per above posts I removed the top two plugs. Behind each plug is a spring which is pushing in on a cone. The cones appear identical but I didn't measure them. The heavier spring came out of the back socket that faces the fuel tank. 1 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #35 Posted May 14 58 minutes ago, ebinmaine said: 1978/79 C141 hydro WITH hydro lift. This pic is a tad fuzzy but gets the point through. Per above posts I removed the top two plugs. Behind each plug is a spring which is pushing in on a cone. The cones appear identical but I didn't measure them. The heavier spring came out of the back socket that faces the fuel tank. And ne'r a shim in sight! 1 Share this post Link to post Share on other sites
ebinmaine 73,593 #36 Posted May 14 14 minutes ago, Bar Nuthin said: And ne'r a shim in sight! No... and I even waggled a magnet in there so I could extract both cones. 1 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #37 Posted May 15 (edited) 3 hours ago, ebinmaine said: No... and I even waggled a magnet in there so I could extract both cones. Maybe we can get one of the Admins to change your title to "Magnet Waggler"! Edited May 15 by Bar Nuthin 1 Share this post Link to post Share on other sites
ebinmaine 73,593 #38 Posted May 15 6 hours ago, Bar Nuthin said: Maybe we can get one of the Admins to change your title to "Magnet Waggler"! Hi. My name is Bear. I've been a Magnet Waggler for many years. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 1,789 #39 Posted June 2 As the recent recipient if the 78 C141 donor, now I’m trying to put it back together. If the heavier spring is supposed to go in the rear facing the gas tank for a hydraulic lift do they get swapped if there isn’t one or it’s mechanical? Share this post Link to post Share on other sites
pfrederi 18,800 #40 Posted June 3 (edited) Do you have the manual? Light spring to rear no spring or valve in the front if yo do not have hydro lift. Edited June 3 by pfrederi 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 1,789 #41 Posted June 3 (edited) @pfrederi No I don’t. Thanks, for the info. I may put a hydraulic lift in it eventually, but I’d like to get it running and moving again first. Edited June 3 by MainelyWheelhorse Share this post Link to post Share on other sites
ineedanother 1,686 #42 Posted June 4 On 6/3/2025 at 9:05 AM, pfrederi said: Light spring to rear no spring or valve in the front if yo do not have hydro lift. @pfrederi , you just settled literally months of fretting over moving hydro from a donor c-160 1140 to a '73 electro 12 with an 1139 that I had already moved the k341 onto. My hydro cylinder ended up being trash so I got one from @WHX?? along with a new set of hoses from Lowell. I got everything moved over this weekend but it wouldn't lift...the difference between a light spring and a heavy spring is kinda like subscribing to this site or not. Either you fix stuff or you might not. 2 1 Share this post Link to post Share on other sites
ineedanother 1,686 #43 Posted June 4 Success! Small wins. You gotta love them. 1 1 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #44 Posted July 13 (edited) I finally found some time to install the used hydraulic lift kit on my '76 C-120. Everything went really smooth, right up to time to attach the hoses to the pump. The model number that would go with my tractor is Lift Kit 8-4113. The lift kit that I was able to pick up used is Lift Kit 8-4111. I knew the hoses going to the pump needed to be shorter than what came with 8-4111, so I picked up a pair from WHP&M. Turns out the older 8-4111 uses 5/16" (?) fittings while the newer 8-4113 uses 3/8" fittings. They fit at the pump but too large at the control. So, the old girl sits in pieces while I try and figure out if I can come up with a reducer going into the valve assembly, or if I'm going to have come up with some custom hoses. (5/16" at the control and 3/8" at the pump). Am I overlooking an easy solution? Perhaps Lowell @wheelhorseman will chime in on whether or not I'm correct on my fitting sizes (I just guesstimated). Edited July 13 by Bar Nuthin Share this post Link to post Share on other sites
ebinmaine 73,593 #45 Posted July 13 Those fittings are a standard size from back when they were new but it's mostly obsolete nowadays. @pfrederi I think? Once told me. Since the hoses are OK on one end and smaller than the other, I'd personally feel OK using an adapter that sizes up. I have the advantage of a good hydraulic repair shop locally. I took all my parts and measurements to them. 1 Share this post Link to post Share on other sites
pfrederi 18,800 #46 Posted July 13 SAE #5 ORB (O Ring Boss) smaller ones and hard to find these days SAE#6 ORB larger ones. Maybe Lowell can make you a custom hose #5 on one end #6 on the other 1 Share this post Link to post Share on other sites
wheelhorseman 3,239 #47 Posted July 13 11 hours ago, Bar Nuthin said: I finally found some time to install the used hydraulic lift kit on my '76 C-120. Everything went really smooth, right up to time to attach the hoses to the pump. The model number that would go with my tractor is Lift Kit 8-4113. The lift kit that I was able to pick up used is Lift Kit 8-4111. I knew the hoses going to the pump needed to be shorter than what came with 8-4111, so I picked up a pair from WHP&M. Turns out the older 8-4111 uses 5/16" (?) fittings while the newer 8-4113 uses 3/8" fittings. They fit at the pump but too large at the control. So, the old girl sits in pieces while I try and figure out if I can come up with a reducer going into the valve assembly, or if I'm going to have come up with some custom hoses. (5/16" at the control and 3/8" at the pump). Am I overlooking an easy solution? Perhaps Lowell @wheelhorseman will chime in on whether or not I'm correct on my fitting sizes (I just guesstimated). Yes, give me a call and we’ll figure it out. I can definitely make you what you need. 1 2 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #48 Posted July 13 1 hour ago, wheelhorseman said: Yes, give me a call and we’ll figure it out. I can definitely make you what you need. Thanks, Lowell! I think I found a solution. I hate to let two brand new hoses go to waste. Once I confirm this fix, I'll probably order the hoses going to the cylinder as well. The manual for the 8-4111 kit lists part numbers 6626 & 6627. Can you confirm what size fittings your replacement hoses use? Thanks! 1 Share this post Link to post Share on other sites
wheelhorseman 3,239 #49 Posted July 13 2 minutes ago, Bar Nuthin said: Thanks, Lowell! I think I found a solution. I hate to let two brand new hoses go to waste. Once I confirm this fix, I'll probably order the hoses going to the cylinder as well. The manual for the 8-4111 kit lists part numbers 6626 & 6627. Can you confirm what size fittings your replacement hoses use? Thanks! If you haven’t used them, you can send them back and I can make you the correct ones 2 Share this post Link to post Share on other sites
Bar Nuthin 1,172 #50 Posted July 13 1 minute ago, wheelhorseman said: If you haven’t used them, you can send them back and I can make you the correct ones You're awesome! Let me see if this cheap fix works out. If not, I'll contact you and make arrangements to get the hoses I need. These ORB sizes have my head a bit scrambled at the moment. 1 Share this post Link to post Share on other sites
