Easton Rich 1,296 #1 Posted November 22, 2024 I decided that since I was putting all of my restoration info under wh tractors I might get called out. So this is the restoration of my 1976 B-80 8-Speed 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #2 Posted November 22, 2024 I also have a question, why is my rear end leaking out of the top left bolt hole where it mounts to the frame? I split them and it’s leaking like a siv 1 Share this post Link to post Share on other sites
oliver2-44 11,847 #3 Posted November 22, 2024 We love restorations, no matter where you post them. The transmissions 4 frame mounting holes are drilled and tapped all the way into the case. So gear oil can easily pour out of them once removed. Screw a bolt back into the holes to reduce leaking. If you plan to drain it, now is a good time. 2 Share this post Link to post Share on other sites
kpinnc 19,107 #4 Posted November 22, 2024 (edited) 2 hours ago, oliver2-44 said: The transmissions 4 frame mounting holes are drilled and tapped all the way into the case. Yep. Gear drives are drilled all the way through. Hydros are not, at least not into the sump. Edited November 22, 2024 by kpinnc 1 Share this post Link to post Share on other sites
ri702bill 13,394 #5 Posted November 22, 2024 So, a B80 8-speed?? Nice!! Sounds like the dis-assembly has begun already. A couple of pointers - Pictures... take lots of pictures from different angles as you go. Particularly of the "little" stuff. Wire routing, linkage for carb, etc. The stuff that drives you crazy at re-assembly. Organization - bag & tag fasteners as you go. You will need a clean area at least 4x the footprint of the tractor for work & storage. Remove the engine and Unidrive (they can stay intact, for now) Bare frame - DO inspect the "F" plate on the frame mounts the Unidrive for cracks around the 4 bolt holes. If it is damaged, NOW is the time to fix it. Inspect anything that moves for wear. Front axle joints, clutch & brake linkages, upper & lower steering. Decide to repair or replace accordingly. "Do it once, do it right" Bill 1 3 Share this post Link to post Share on other sites
953 nut 70,656 #6 Posted November 22, 2024 10 hours ago, Easton Rich said: why is my rear end leaking Oh, the opportunities to make an off color remark on that quote are endless. When you put the tractor back together use a dab of blue loctite thread locker on the bolts. 9 Share this post Link to post Share on other sites
Easton Rich 1,296 #7 Posted November 22, 2024 2 hours ago, 953 nut said: Oh, the opportunities to make an off color remark on that quote are endless. When you put the tractor back together use a dab of blue loctite thread locker on the bolts. I didn’t even see this 1 4 Share this post Link to post Share on other sites
ri702bill 13,394 #9 Posted November 22, 2024 4 hours ago, rjg854 said: Yep.... 2 Share this post Link to post Share on other sites
Easton Rich 1,296 #10 Posted November 24, 2024 I will get some when I make more progress tomorrow 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #12 Posted November 24, 2024 Putting the tins away for the winter after I prime them due to me not having a temp controlled paint booth 3 Share this post Link to post Share on other sites
Easton Rich 1,296 #13 Posted November 24, 2024 During the winter I will plan to flush the transmission and clean the motor up 4 Share this post Link to post Share on other sites
Easton Rich 1,296 #14 Posted November 25, 2024 Has anyone seen or own a C series snow cab in eastern Kansas or Western Missouri? If so I’d be glad to pay a fair price for it. 1 Share this post Link to post Share on other sites
rjg854 13,454 #15 Posted November 25, 2024 @Easton Rich you should place an ad in the Wanted's of the Classifieds section. 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #16 Posted November 25, 2024 Ok, thank you 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #17 Posted November 26, 2024 Any thread I could read on how I could hook up a led light bar instead of headlights? Anything appreciated 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #18 Posted November 26, 2024 40 minutes ago, Easton Rich said: Any thread I could read on how I could hook up a led light bar instead of headlights? Anything appreciated We use a few LED lights. I wire them directly to the battery instead of through the original circuits. 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #19 Posted November 26, 2024 Do you wire in a toggle switch or are you saying they are constantly on? 2 Share this post Link to post Share on other sites
Handy Don 17,735 #20 Posted November 26, 2024 31 minutes ago, Easton Rich said: Do you wire in a toggle switch or are you saying they are constantly on? For 312 and 518++ we simply replaced the headlights with LEDs and branched the same switched circuit (comes off the A terminal at the ignition switch) to a rear-facing work light. bar that has its own switch (headlights must be on for work light to get juice). @ebinmaine’s direct-to-battery setup lessens the chance that he'd see flicker in the illumination. LEDs react much, much more quickly to power fluctuation than those “heated wire” incandescent lamps. Tractors with without voltage regulators (i.e. plain diodes) are more susceptible to this. It shouldn’t be an issue with the higher AC output and voltage regulators on the 10hp and up recent tractors (C’s and the 00’s). Note that LEDs are polarized, unlike incandescents. The battery source must go to the “+” terminal and the “-“ to ground. Backwards? No light at all! 4 Share this post Link to post Share on other sites
ebinmaine 81,282 #21 Posted November 26, 2024 7 hours ago, Easton Rich said: Do you wire in a toggle switch or are you saying they are constantly on? We do wire in a switch. @Handy Don Excellent explanation! 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #22 Posted November 26, 2024 That makes much more sense. Mine never had headlights or taillights but there is wiring ran for the taillights. Would a 7in bar be good? 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #23 Posted November 26, 2024 3 minutes ago, Easton Rich said: Would a 7in bar be good? Likely. Yes. But like many things nowadays the quality of LED lights VARIES WIDELY. On the back of my plow tractor I have a NOS 6 lamp LED that was a $70 light in the old days. It's extremely bright. On the front I have some interesting little flat fillers in the original headlamp case along with a couple of I think four and LEDs at the sides. Vision isn't an issue. 1 Share this post Link to post Share on other sites
Easton Rich 1,296 #24 Posted November 27, 2024 Dang you’re lighting up the world 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #25 Posted November 27, 2024 12 minutes ago, Easton Rich said: Dang you’re lighting up the world Here's the beast... 6 Share this post Link to post Share on other sites
