Donavon1
Engine for my 1054 (black Betty)
Donavon1
Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
Donavon1
Have fun searching I’ll send you updates
oliver2-44
Do some searches on here for “%Diesel”. There have been several retrofits over the years.
ri702bill
A "Grease Buggy"!! Nice. You will most likely need TWO fuel tanks - one with straight diesel to start it and the second that smells like french fries to run it.
We had a guy at work that did the conversion on his diesel VW Jetta. (We also made the OE switching valve to choose the tank.)
ebinmaine
@Achto has one.
Interesting that you'll be "burning the leftovers".
I like that.
Pullstart
I ran a 2001 Ford Powerstroke 7.3L for a few years on used oil, transmission fluid, fryer grease, etc.  I filtered it all down to 5 microns with a barrel pump in my garage and dumped it in the main tank.  It ran great, and the fry grease always smelled the best!  I made no changes to the engine or fuel system on the truck.
Achto
If you make up 5gal of used fuel oil, you should have enough to run a single cylinder diesel for a year.:thumbs2:
There are plenty of Yanmar knock off's out there at a low price. There was one of these at @WHX??'s plow day this year, seemed to run strong with no issues all day.
https://www.amazon.com/Air-Cooled-Cylinder-Machinery-Starting-186F/dp/B07YC7283C/ref=asc_df_B07YC7283C?mcid=3f2e28a82cfb3f19b67a26fa846f7c71&tag=hyprod-20&linkCode=df0&hvadid=693366125660&hvpos=&hvnetw=g&hvrand=5171939549114843075&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019452&hvtargid=pla-889349596270&psc=1
I have a Hatz diesel in Radpferd. High quality engine with a high end price. This engine burns about 1Qt of diesel per hour pulling a 10" Brinly plow. Very good engine,  if you can find one.
Kohler also has their hat in the ring with small diesels. They are very proud of their engine as well.
https://www.northerntool.com/products/kohler-horizontal-4-stroke-diesel-engine-9-1-hp-model-pa-kd440-2101c-107938?srsltid=AfmBOooXic9eavAu_mVWbnHxtRayb8fvj9KUwBbDL4qfShloDad93J_N1e4
Make sure that you are filtering your used oil properly, injector holes clog up easily.
Personally, I would go with a Yanmar knock off. If you end up having issues with the used oil, you will only be out hundreds not thousands.:twocents-twocents:
WHX??
Wow their giving them away ..maybe I should build one  ...  plenty of carcasses to start with here. Course havta grow a new arm for those pull starts... :lol:
  • Haha 2
Achto
Handy Don
3 hours ago, Achto said:
And the cure for that.:thumbs2:
And add a battery!
Edited by Handy Don
Donavon1
Good idea I was thinking about getting a yanmar knock-off but they don’t come with a starter
Donavon1
4 hours ago, Handy Don said:
And add a battery!
Got one 75$ at oreillys
Achto
Pullstart
Sissy :lol:
  • Haha 2
Donavon1
1 hour ago, Pullstart said:
Sissy :lol:
Nah that’s what kids are for :lol:
  • Haha 1
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • DevonianHorse
      By DevonianHorse
      Hi all, on a 1977 Wheelhorse C-100 (Belgium made), I have a question
      My Wheelhorse hood opens really far- it does eventually stop but I don't think it is meant to go this far and that there's a piece missing.
      In this photo, there's a hole you can see (near the middle of the pic, 1/3 down) and the same on the other side of the hood mounting part of the frame- I assume some sort of bar is meant to go between them that the hood latches at the base will catch on and this stops the hood dropping further when opened? If this makes no sense sorry- I have simply always assumed that the hood is meant to open at a right angle from the front, but having seen videos, I can see most stop before that.
      Does anyone know the part I need, or would two bolts, one on each side, do the job? Mine has never had one, so I am unsure.
      Thanks!!
    • sjoemie himself
      By sjoemie himself
      You know those people that have too many projects?? Yeah me neither!
      Another tractor added to the heard. Case International 585 with canopy/sunroof.
      It's a 60-ish horsepower tractor with very limited electronic gimmicks. Has a nice tight turning radius. It was built in Doncaster from 1985 to 1990 and the hourmeter says it has ran 4700 hours since then, I'll take that with a grain of salt though.
      Plan is to use it for all kinds of jobs around the house and barn/stable for my gf's horses.
      Ofcourse it is not a new machine so there are things that will need looking after but all the basics are there.
      Pictures you say? Sure!
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • PWL216
      By PWL216
      I have for sale a 1984 C-105 with deck and Snowblower. I got this as part of a package. There’s no battery and I haven’t tried to start it. I’m selling it as a project. The deck has one spindle out, but with it, as prior owner claims bearing was replaced. The snowblower has the flag and looks to be in very good condition. All but 1 tire holds air. The mower is complete. Includes mule drive. The extra hood (c-175) you see in the picture can go with the tractor for an additional $50. Thx for looking.
