Gabe 32 #1 Posted October 18, 2024 I’m currently restoring my wheelhorse 314A I’m looking to find rear tires 22-7.50-12 can’t seem to find new ones, can anyone guide me to other compatible sizes? 4 1 Share this post Link to post Share on other sites
ri702bill 13,394 #2 Posted October 18, 2024 Check the width of your rims - a 22-8.50-12 should mount up fine. Check the recommended rim size with the Mfg'r first... 1 1 Share this post Link to post Share on other sites
Bill D 3,213 #3 Posted October 18, 2024 4 hours ago, Gabe said: I’m currently restoring my wheelhorse 314A I’m looking to find rear tires 22-7.50-12 can’t seem to find new ones, can anyone guide me to other compatible sizes? Welcome! I see you're a local. If those tires aren't cracked I'd just polish them up and run them. 22x7.50-12 isn't made made anymore from what I understand. Share this post Link to post Share on other sites
Gabe 32 #4 Posted October 18, 2024 It may have some small ones, they still have some tread life, I was thinking about some agricultural tires as well. Thanks for the reply , I still have a ways to got , it all started by replacing a fuel line lol Share this post Link to post Share on other sites
Gabe 32 #5 Posted October 18, 2024 5 hours ago, ri702bill said: Check the width of your rims - a 22-8.50-12 should mount up fine. Check the recommended rim size with the Mfg'r first... Ok , I did see the 8.50 on line, going. To see if I can find and agricultural tire size that fits also. Share this post Link to post Share on other sites
953 nut 70,656 #6 Posted October 18, 2024 23 X 8.50 - 12 is a much more commonly available size. https://www.google.com/search?q=23+X+8.50+-+12+tires&rlz=1C1JZAP_enUS981US981&oq=23+X+8.50+-+12+tires&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTIyMTMzajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 2 Share this post Link to post Share on other sites
ri702bill 13,394 #7 Posted October 18, 2024 Just now, Gabe said: Ok , I did see the 8.50 on line, going. To see if I can find and agricultural tire size that fits also. Be careful - ATV tires may BE listed as that size, but most likely be different in OD and width from your present tires. 1 1 Share this post Link to post Share on other sites
Gabe 32 #8 Posted October 18, 2024 14 minutes ago, 953 nut said: 23 X 8.50 - 12 is a much more commonly available size. https://www.google.com/search?q=23+X+8.50+-+12+tires&rlz=1C1JZAP_enUS981US981&oq=23+X+8.50+-+12+tires&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCTIyMTMzajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 Thanks for the welcome and info. Share this post Link to post Share on other sites
c-series don 12,752 #9 Posted October 18, 2024 23x8.50-12’s will work just fine. With the correct rim you could go as wide as a 23x10.50-12. 1 Share this post Link to post Share on other sites
Ed Kennell 47,946 #11 Posted October 19, 2024 to the Gabe. Those tires should clean up and look great with some tire shine. Nice shop BTW. 1 1 Share this post Link to post Share on other sites
Bill D 3,213 #12 Posted October 19, 2024 On 10/18/2024 at 8:01 AM, Gabe said: It may have some small ones, they still have some tread life, I was thinking about some agricultural tires as well. Thanks for the reply , I still have a ways to got , it all started by replacing a fuel line lol If you're interested in a second project tractor send me a PM. 1 Share this post Link to post Share on other sites
Gabe 32 #13 Posted October 20, 2024 Need to weld the mount points of the seat pan bar, slowing me down lol. Share this post Link to post Share on other sites
Gabe 32 #14 Posted December 22, 2024 Well she is up and running, just have to order the decals, clean up the rear wheels and tires, attach my plow (need to get weights and chains though and a seat). I got an estimate of $200 to redo the factory seat. 4 Share this post Link to post Share on other sites
Bar Nuthin 3,645 #15 Posted December 22, 2024 2 hours ago, Gabe said: I got an estimate of $200 to redo the factory seat. With the price of decent aftermarket seats , $200 isn't unreasonable at all. 1 Share this post Link to post Share on other sites
Gabe 32 #16 Posted December 23, 2024 I agree, but not a comfortable lol. 1 Share this post Link to post Share on other sites
kpinnc 19,107 #17 Posted December 24, 2024 Your tractor looks to be off to a good start for sure. On your rear wheels: 23x8.50-12 will fit just fine. That size ag cleats look very good on a 300-series machine. You can also go as wide as 10.50 with turf tires. Ag tires on your 7.5 rims can be tricky due to the bars forcing all the flex to the sidewalls. The tires in the pic below are 10.50 turfs on 7.5 wide rims. 2 Share this post Link to post Share on other sites
Brockport Bill 2,553 #18 Posted December 24, 2024 fyi -------- my wh original brochure from 1989 ---- shows the 312 having 22x9x12 - the 310 model had 22x8x12 1 Share this post Link to post Share on other sites
oliver2-44 11,847 #19 Posted December 24, 2024 (edited) 23 x 9.5 -12 will also work just fine on the original rims. I run that size with the original tire which were full size. With the new tires being one to two sizes undersize this size is the smallest I would go. Edited December 24, 2024 by oliver2-44 1 Share this post Link to post Share on other sites
Gabe 32 #20 Posted December 26, 2024 Thanks for all the advice gents, @kpinnc what seat manufacturer is that, it looks comfortable. Share this post Link to post Share on other sites
peter lena 10,125 #21 Posted December 26, 2024 @Gabe nice set up you have there, was noticing all the opportunities you have to lay in a solid , 5/16 steel brake line or similar plastic fuel hose , secured into the upper inside frame bend , totally out of sight , and also removing a lot of fuel hose break down , debris , the end points to fuel tank / filter and carb / filter could be clear vinyl , went after fuel hose breakdown years ago , and changed over to STA BIL in all my fuels , most interesting thing about positive effects , is ZERO DEBRIS IN FILTERS OR CARB BOWLS , NOTHING . figured that would be the true test to its effects , my fuel tanks are also clean / clear , like to experiment on chronic issues , my stand by generator also has 1, 1/2 oz of sta bil in the tank , clean / clear , sits for months , starts right up , zero rubber hose break down in filters . always look at a similar tear down stage , as a reference to what I have tried , experimented with problem area . have a good day , pete 1 Share this post Link to post Share on other sites
