Handy Don 17,735 #51 Posted October 11, 2024 20 minutes ago, Scott from ontario said: No I did not I’m in Ontario Dang, that spring looks like it was pilfered from a retractable ball point pen! Share this post Link to post Share on other sites
Scott from ontario 3 #52 Posted October 25, 2024 Hello everyone who has helped me out with the transmission. What can I use to replace the choke and throttle cables with the handle ends are original and I was going to put a electric fuel pump on it since the manual one does not work anymore just not sure on the fuel pump pressure 1 Share this post Link to post Share on other sites
953 nut 70,656 #53 Posted October 25, 2024 An electric low pressure fuel pump (around 2 psi) located lower than the outlet of the fuel tank is a big plus. There have been lots of threads on here recommending various brands, read them over and decide. https://www.wheelhorseforum.com/search/?&q=electric fuel pump brand&search_and_or=and&sortby=relevancy 2 hours ago, Scott from ontario said: replace the choke and throttle cables with the handle ends are original We are still talking about the 953, correct? I have had success carefully opening the stamped metal clamps that hold the cable conduit in place and replacing the entire thing using universal cable from any big box store. Set the cable conduit where it needs to be and carefully clamp it back in place. Share this post Link to post Share on other sites
Scott from ontario 3 #54 Posted October 29, 2024 Good afternoon everyone so I tried a pen spring with the 1/4 inch ball bearings and that does not work for the 953 tractor I have no idea on how long the spring should be and the amount of pressure to compress it anyone have information on the spring ? Share this post Link to post Share on other sites
Handy Don 17,735 #55 Posted October 30, 2024 4 hours ago, Scott from ontario said: Good afternoon everyone so I tried a pen spring with the 1/4 inch ball bearings and that does not work for the 953 tractor I have no idea on how long the spring should be and the amount of pressure to compress it anyone have information on the spring ? My comment about the pen spring was intended as a joke. Sorry if it confused you. The actual spring in the transaxle is heavier and stronger, I know @stevasaurus has posted the dimensions and might kindly do it again! Share this post Link to post Share on other sites
stevasaurus 23,892 #56 Posted October 30, 2024 @Handy Don , I know I measured that spring, but I can not find my notes or where I might have posted it. Shynon's post in post #48 is correct. MacMaster Carr should have a spring that should work...3/16 to 1/4" outside diameter & 1 1/4 to 1 1/2" long. Springs have 2 purposes...1. to pull something 2. to push something You want a spring that looks like the spring in a ball point pen...ie...it pushes the detent balls into the notches in the shift rails. Scott, try calling Lincoln at A to Z. I can't believe TORO does not have these in stock. Share this post Link to post Share on other sites
