ebinmaine 80,279 #1 Posted July 24, 2024 Is there an aftermarket replacement for the bushings that go in the pedals of 60s and 70s Wheelhorses? I believe this is a 3/4 ID by maybe 1/4 long flange bushing?? Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted July 24, 2024 You MAY have better luck using NYLON bushings. I found some at NADA for the rock shaft on mine. 3/4" ID x 1/4 or 3/8. Had to gently tap them in place with a soft mallet. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #4 Posted July 24, 2024 @gt14rider Now you see that's less expensive than any of the others I've found. 13 bucks a piece plus tax. We replace between one and four of those on every tractor that we take apart and rebuild. That adds up quick. I would buy them in bulk if I could find something usable that was a lot less expensive. Share this post Link to post Share on other sites
peter lena 10,014 #5 Posted July 24, 2024 @ebinmaine https://us.misumi-ec.com/vona2/mech/M0100000000/M0107000000/M0107080000/?gad_source=1&gclid=EAIaIQobChMIvISXruK_hwMVpmJHAR3yWgEQEAAYASAAEgL11PD_BwE&curSearch= just snoopin around , thought of your issue , pete 1 Share this post Link to post Share on other sites
gt14rider 1,278 #6 Posted July 24, 2024 Mcmaster carr, thay have other material to choose from. You can grind to width. At 1.04 ea I'd make it work 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #7 Posted July 24, 2024 3 minutes ago, gt14rider said: Mcmaster carr, thay have other material to choose from. You can grind to width. At 1.04 ea I'd make it work Now that's what I'm talking about! Do you have an item number? 1 Share this post Link to post Share on other sites
pfrederi 21,046 #8 Posted July 24, 2024 2938T53 1 1 Share this post Link to post Share on other sites
gt14rider 1,278 #9 Posted July 24, 2024 Paul beat me to it. 1 1 Share this post Link to post Share on other sites
peter lena 10,014 #10 Posted July 24, 2024 @ebinmaine glad a collective view , has given you an answer , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #11 Posted July 24, 2024 4 hours ago, pfrederi said: 2938T53 4 hours ago, gt14rider said: Paul beat me to it. That's awesome! Thanks guys. I looked yesterday but I was using a different flange thickness because that's what I took off. No way an extra thick flange is a negative issue in this situation! 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #12 Posted July 24, 2024 Since you guys are on such a wicked roll... Any idea what the diameter is on the roll pins used in the clutch pulley idler shaft on the old eight speeds? I couldn't decide if it was 9/64 or 5/32. Or should I just get the 5/32 and expand the shaft bore hole with the right drill bit if needed??? Share this post Link to post Share on other sites
Handy Don 17,316 #13 Posted July 24, 2024 Believe it or not, I saw these in packs of two in the Hillman bins at a Lowes in different sizes for about $2 each 2 Share this post Link to post Share on other sites
gt14rider 1,278 #14 Posted July 24, 2024 Pic of a 73 no name 1 Share this post Link to post Share on other sites
gt14rider 1,278 #15 Posted July 24, 2024 Pic of 856 1 Share this post Link to post Share on other sites
peter lena 10,014 #16 Posted July 24, 2024 @gt14rider @ebinmaine another brain fart on that , why not get that 1/8x 1, 1/4 in a longer length , possible $ saving , and use a cutting wheel to make what you want ? https://www.amazon.com/Spring-Pins-1-8-Hardware/s?rh=n%3A16410401%2Cp_n_feature_ten_browse-bin%3A19044679011, regularly look at a problem , for related , similar issue . BTW that schematic lay out , also makes me think of detail tweaking for effortless function, done a lot of that , good talkin , pete 1 Share this post Link to post Share on other sites
squonk 47,887 #17 Posted July 24, 2024 I can't say I've ever had top replace pedal bushings. 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #18 Posted July 24, 2024 52 minutes ago, squonk said: I can't say I've ever had top replace pedal bushings. We've had some REALLY ROUGH tractors here as restorations. Share this post Link to post Share on other sites
Lee1977 7,750 #19 Posted July 25, 2024 On 7/24/2024 at 9:57 AM, pfrederi said: 2938T53 You know your not suppose to feed bears. You let them find there own. 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #20 Posted July 25, 2024 Just now, Lee1977 said: You know your not suppose to feed bears. You let them find there own. Now now now. Let the boys help. In all seriousness. I did look. It's just that I was looking for the wrong size flange. What I had here was thinner and I couldn't find those for less than 6 or $7 a piece. I can't begin to imagine a little extra width is going to make that much difference and probably will be better. 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #21 Posted August 6, 2024 (edited) On 7/24/2024 at 2:52 PM, ebinmaine said: Since you guys are on such a wicked roll... Any idea what the diameter is on the roll pins used in the clutch pulley idler shaft on the old eight speeds? I couldn't decide if it was 9/64 or 5/32. Or should I just get the 5/32 and expand the shaft bore hole with the right drill bit if needed??? @gt14rider You were correct on the 1/8 pins. Thanks! I ordered a bag of 1/8 and knowing there was a broken pin with a worn oval shaped hole I also ordered a bag of 5/32 and two good drill bits. Turns out a Previous Owner had already done the oversized bore to the clutch pedal lever/rod connection!! Edited August 6, 2024 by ebinmaine Correct autocorrect 1 Share this post Link to post Share on other sites
