AlexR
The Lone Raider
WHX??
22 hours ago, ebinmaine said:
On the two I've done I drove the gear's shaft right in to the block.
Can one put the shaft back in from the outside to plug the hole?
Easton Rich
Maybe find a freeze plug or pipe plug that size?
AlexR
From what I have read people just fill it up with some silicone but I just can't make myself do that.
I would rather just leave the shafts in place.
I will mess with it a bit more see if I can get them out like @Achto said.
WHX??
Well normally I'd call him a BSer  but I seen him do it. :lol:
  • Haha 2
kpinnc
Posted (edited)
Yes, but going from the outside is hit and miss. The last two I tried- first went in easily, second stopped about half way and I wasn't willing to really hit it hard enough to go further. I just cut it off and ground it down.
Best bet is to cut the pin in half and drive the tapered end in flush.
Edited by kpinnc
ebinmaine
Yes. I've done it.
Also had this exact issue.
On an engine with no oil pressure it would probably be fine.... and I wouldn't do that either.
The stub of the shaft or as @Easton Rich said, a freeze/welch plug.
Achto
Posted (edited)
I would drive in a 1/2 freeze plug / expansion plug. That would be a permanent fix.:twocents-twocents:
https://shop.advanceautoparts.com/p/dorman-pik-a-nut-steel-cup-expansion-plug-1-2-in-height-0380-3626051/3492125-P?
Edited by Achto
oliver2-44
Just split the gears with a cold chisel and you don’t have to worry about messing with the shafts   Easy Peary.
  • Excellent 3
AlexR
She's a roller now, I got the next two days that will be really good for painting so I should get the rest of the parts painted, besides the engine block.
  • Excellent 8
ebinmaine
2 minutes ago, AlexR said:
roller
Always a great feeling during a restoration!
AlexR
Absolutely it does feel great! Get the feeling you actually might get it done soon until you realize how much more there is to do haha.
SylvanLakeWH
:eusa-clap:
that'll work perfect for holding  drinks at @Pullstart's plow day... er... I mean, um, plowing....
  • Haha 5
Pullstart
I drove the pin out, then drove it back in.
Pullstart
  • Excellent 2
  • Thanks 2
AlexR
I got that other balance gear out, I don't doubt you got yours out @Achto but there was no way I was going to get mine out without pulling the crankshaft or what I ended up doing like @Pullstart did and drove that pin out.
I decided not to precut that pin I will just cut it flush with how far in I was able to drive it.
Installed new crank seals and got it cleaned up as much as I could inside, it's very cold and windy outside today.
I'm also pretty positive this is was a replacement engine because there is gray paint that wasn't ever painted over and the only red paint on it is that same chalky paint that I stripped off the rest of the tractor.
  • Like 5
  • Excellent 2
AlexR
Getting the engine put back together and discovered this, a hole in the side of the intake port. Really glad I found that, used JB weld to fix it.
  • Sad 1
AlexR
Looking like a tractor now. Still a ways to go lots of little stuff
  • Excellent 5
ebinmaine
NIIIIICE
Easton Rich
Man it would be hard to use it!
AlexR
I left a couple runs in the paint on the foot rests and have had a couple scratches because some paint hasn't cured long enough yet. And that's ok because it's going to be used.
Achto
Looking great Alex !!! :handgestures-thumbupright:
WHX??
:text-yeahthat:Now you know why I ain't afraid to give you parts ... :thumbs2:
SylvanLakeWH
Very nice!!! :eusa-clap:
kpinnc
That thing looks nice! :thumbs:
I really like that headlight setup! Looks great!
