WHX?? 57,938 #301 Posted March 7 22 hours ago, ebinmaine said: On the two I've done I drove the gear's shaft right in to the block. Can one put the shaft back in from the outside to plug the hole? 3 Share this post Link to post Share on other sites
Easton Rich 1,260 #302 Posted March 7 Maybe find a freeze plug or pipe plug that size? 1 Share this post Link to post Share on other sites
AlexR 3,084 #303 Posted March 8 1 hour ago, WHX?? said: Can one put the shaft back in from the outside to plug the hole? From what I have read people just fill it up with some silicone but I just can't make myself do that. I would rather just leave the shafts in place. I will mess with it a bit more see if I can get them out like @Achto said. 1 Share this post Link to post Share on other sites
WHX?? 57,938 #304 Posted March 8 17 minutes ago, AlexR said: get them out like @Achto said. Well normally I'd call him a BSer but I seen him do it. 2 Share this post Link to post Share on other sites
kpinnc 18,916 #305 Posted March 8 (edited) 2 hours ago, WHX?? said: Can one put the shaft back in from the outside to plug the hole? Yes, but going from the outside is hit and miss. The last two I tried- first went in easily, second stopped about half way and I wasn't willing to really hit it hard enough to go further. I just cut it off and ground it down. Best bet is to cut the pin in half and drive the tapered end in flush. Edited March 8 by kpinnc 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,471 #306 Posted March 8 3 hours ago, WHX?? said: Can one put the shaft back in from the outside to plug the hole? Yes. I've done it. 1 hour ago, kpinnc said: I just cut it off and ground it down. Also had this exact issue. 2 hours ago, AlexR said: From what I have read people just fill it up with some silicone but I just can't make myself do that. On an engine with no oil pressure it would probably be fine.... and I wouldn't do that either. The stub of the shaft or as @Easton Rich said, a freeze/welch plug. 1 Share this post Link to post Share on other sites
Achto 32,557 #307 Posted March 8 (edited) 16 hours ago, AlexR said: From what I have read people just fill it up with some silicone I would drive in a 1/2 freeze plug / expansion plug. That would be a permanent fix. https://shop.advanceautoparts.com/p/dorman-pik-a-nut-steel-cup-expansion-plug-1-2-in-height-0380-3626051/3492125-P? Edited March 8 by Achto Share this post Link to post Share on other sites
oliver2-44 11,717 #308 Posted March 8 Just split the gears with a cold chisel and you don’t have to worry about messing with the shafts Easy Peary. 3 Share this post Link to post Share on other sites
AlexR 3,084 #309 Posted March 8 She's a roller now, I got the next two days that will be really good for painting so I should get the rest of the parts painted, besides the engine block. 1 8 Share this post Link to post Share on other sites
ebinmaine 80,471 #310 Posted March 8 2 minutes ago, AlexR said: roller Always a great feeling during a restoration! 1 Share this post Link to post Share on other sites
AlexR 3,084 #311 Posted March 8 5 minutes ago, ebinmaine said: Always a great feeling during a restoration! Absolutely it does feel great! Get the feeling you actually might get it done soon until you realize how much more there is to do haha. 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,314 #312 Posted March 8 that'll work perfect for holding drinks at @Pullstart's plow day... er... I mean, um, plowing.... 1 5 Share this post Link to post Share on other sites
Pullstart 71,168 #313 Posted March 8 I drove the pin out, then drove it back in. 1 1 Share this post Link to post Share on other sites
AlexR 3,084 #315 Posted March 16 I got that other balance gear out, I don't doubt you got yours out @Achto but there was no way I was going to get mine out without pulling the crankshaft or what I ended up doing like @Pullstart did and drove that pin out. I decided not to precut that pin I will just cut it flush with how far in I was able to drive it. Installed new crank seals and got it cleaned up as much as I could inside, it's very cold and windy outside today. I'm also pretty positive this is was a replacement engine because there is gray paint that wasn't ever painted over and the only red paint on it is that same chalky paint that I stripped off the rest of the tractor. 6 2 Share this post Link to post Share on other sites
AlexR 3,084 #316 Posted March 22 Getting the engine put back together and discovered this, a hole in the side of the intake port. Really glad I found that, used JB weld to fix it. 4 1 Share this post Link to post Share on other sites
AlexR 3,084 #317 Posted March 22 Looking like a tractor now. Still a ways to go lots of little stuff 1 8 Share this post Link to post Share on other sites
Easton Rich 1,260 #319 Posted March 22 Man it would be hard to use it! 1 Share this post Link to post Share on other sites
AlexR 3,084 #320 Posted March 22 7 minutes ago, Easton Rich said: Man it would be hard to use it! I left a couple runs in the paint on the foot rests and have had a couple scratches because some paint hasn't cured long enough yet. And that's ok because it's going to be used. 1 3 Share this post Link to post Share on other sites
Achto 32,557 #321 Posted March 22 Looking great Alex !!! 1 Share this post Link to post Share on other sites
WHX?? 57,938 #322 Posted March 22 Now you know why I ain't afraid to give you parts ... 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,314 #323 Posted March 23 Very nice!!! 1 Share this post Link to post Share on other sites
kpinnc 18,916 #324 Posted March 23 3 hours ago, AlexR said: Looking like a tractor now. That thing looks nice! I really like that headlight setup! Looks great! 1 Share this post Link to post Share on other sites
AlexR 3,084 #325 Posted April 6 One last photo before it's all completed. 1 3 3 Share this post Link to post Share on other sites
