ebinmaine 72,379 #26 Posted July 11, 2024 1 hour ago, AlexR said: Those are great recommendations, but I think a transmission rebuild is probably in store for it a couple bearings are worn. Have you been into a manual transmission? Easy peasy. Tear it apart. You'll have plenty of good help here. 56 minutes ago, AlexR said: That is definitely a interesting angle haha. I will probably tackle mine when I tear the transmission apart. Fortunately mine isn't at a angle, I will have to see how messed up the threads are when I get into it. If your thread bore is straight but just pulled out you may be able to go up a thread size in half-dog set screw and call it a day. 1 Share this post Link to post Share on other sites
AlexR 1,805 #27 Posted July 11, 2024 4 minutes ago, ebinmaine said: Have you been into a manual transmission? Easy peasy. Tear it apart. You'll have plenty of good help here. I've been into the hydro transaxles recently, But actually I have been in the wheelhorse manual transmission when I was about 13 or 14 years old, which was about 16 years ago. I will probably look around in the forums a bit and may ask some questions when I get into it. 6 minutes ago, ebinmaine said: If your thread bore is straight but just pulled out you may be able to go up a thread size in half-dog set screw and call it a day. It is straight, so yeah I am probably going to drill and re-tap. 1 1 Share this post Link to post Share on other sites
ebinmaine 72,379 #28 Posted July 11, 2024 @stevasaurus has some very informative videos on the gears, disassembly and reassembly. I made a couple about how I split the case apart. I learned everything from this site. Take your sweet time pulling the hubs. I've had one fight me for two WEEKS. Otherwise it's common sense nuts n bolts work. 2 Share this post Link to post Share on other sites
AlexR 1,805 #29 Posted July 21, 2024 Getting the engine back together from getting the exhaust valve unstuck and cleaned up, set the clearances on the valves. Got new coil, new spark plug, new air filter. New gas lines shutoff and filter. All that's left to get it started up is the wiring. I did get the exhaust out used bunch of pb blaster after that I heated it up, then I used a 10' galvanized 2" steel pipe on a pipe wrench. Just letting the weight of the pipe do the work. I am leaning towards doing a lowered custom the whole front axle spindles and steering are all loose. My other Wheelhorses aren't tight but this one is worse. So I am thinking of doing a custom front suspension and possibly front brakes. I'll see once I get it running, I'll drive it around a bit see how everything is doing as is. Then make a decision from there. 4 Share this post Link to post Share on other sites
AlexR 1,805 #30 Posted July 23, 2024 Its a runner now. I neglected to take photos while it was out. I just did a quick wiring job to get it running. And got stainless steel pipe for the exhaust. Before I even tried starting it I cleaned and set the points at .020 But it wasn't starting checked the spark and no spark. Ended up changing out the points with another used set that I had and that fixed it. Tried starting again and it pretty much started right up. I have a little bit of sputtering, I tried adjusting the carb a little bit and got it better but I haven't touched the carb other then taking the bowl off to make sure it wasn't all cruddy and then blasted it with some carb cleaner. So that will need some more work. I had the belt come off the idler pulley when driving it around took the belt guard off and got that back on but everything is so shot on this machine the idler is bad, there is no lining on the brake band. But the brake pulley is shot too it has a bad lip on the outside of the brake. And the steering is awful too. The good is the transmission goes in all the gears (hi and low) and it seems smooth enough. And the engine seems to be ok as well. 5 Share this post Link to post Share on other sites
ebinmaine 72,379 #31 Posted July 24, 2024 Excellent when a new member of the herd runs and drives. Good save on that one. All easy fixes on the Idler carb brakes steering etc. 1 Share this post Link to post Share on other sites
AlexR 1,805 #32 Posted November 19, 2024 (edited) This tractor has just been sitting this whole time, I haven't forgotten about it. But it will be sitting for a while longer at least until spring, but it is in a dry safe place. I have decided to do a restoration on it, instead of hot rodding it. Not a completely full blown one as I am still planning use it as a worker. I want to get it mechanically working well again and get a full repaint, I will try to do a fairly good rattle can job, might even sand the primer haha. We will have to see how carried away I get. I would love to get a loader for it, but it would have to be the right price which I know is hard to come by. I might build one but that is definitely a down the road project. So that might mean I do some different stuff to the front end since it's all pretty loose right now. Edited November 19, 2024 by AlexR 2 Share this post Link to post Share on other sites
AlexR 1,805 #33 Posted May 30 Still haven't forgotten about this tractor its in so much better of a place then it was before, dry and completely out of the elements. Been so busy with other things I just haven't been able to do anything yet. 2 Share this post Link to post Share on other sites
WHX?? 51,690 #34 Posted May 30 42 minutes ago, AlexR said: Been so busy with a damned barn... There fixed that Just caught this thread ... good work! 1 3 Share this post Link to post Share on other sites
AlexR 1,805 #35 Posted May 30 Just now, WHX?? said: There fixed that Just caught this thread ... good work! Thanks! I should probably make myself a goal of using this tractor as the plow mule at Pullstarts plow day next year. That might happen 3 1 Share this post Link to post Share on other sites
WHX?? 51,690 #36 Posted May 30 3 minutes ago, AlexR said: using this tractor as the plow mule at Pullstarts Why does turning a tractor into a plow mule always come first to my mind too... 1 1 1 Share this post Link to post Share on other sites
AlexR 1,805 #37 Posted May 30 19 minutes ago, WHX?? said: Why does turning a tractor into a plow mule always come first to my mind too... Because it's the best excuse to put tri-ribs and ag tires on them 2 1 1 Share this post Link to post Share on other sites
ebinmaine 72,379 #38 Posted May 30 6 hours ago, AlexR said: Because it's the best excuse to put tri-ribs and ag tires on them Ain't no plowable fields here but I love the look of "proper" tractor tires!! 1 Share this post Link to post Share on other sites
AlexR 1,805 #39 Posted May 31 Got some more rim options picked these 4 wheels and tires up today. These rims are a inch wider then what's on there. 3 1 Share this post Link to post Share on other sites
Easton Rich 621 #40 Posted May 31 2 minutes ago, AlexR said: Got some more rim options picked these 4 wheels and tires up today. These rims are a inch wider then what's on there. Nice 1 Share this post Link to post Share on other sites
AlexR 1,805 #41 Posted Tuesday at 12:00 AM I am getting closer to blowing this tractor apart just trying to fix a few things on the simplicity I got. But got these front wheel weights today feels like 25 pounds a piece maybe more 6 Share this post Link to post Share on other sites
ebinmaine 72,379 #42 Posted Tuesday at 08:42 AM 8 hours ago, AlexR said: these front wheel weights I have a set of those I picked up from @PWL216. They were the REAR weights on a Wheelhorse smaller model that had 10" wheels. I hadn't thought of seeing if they'd fit a front wheel. 1 Share this post Link to post Share on other sites
AlexR 1,805 #43 Posted Tuesday at 09:47 AM 1 hour ago, ebinmaine said: I have a set of those I picked up from @PWL216. They were the REAR weights on a Wheelhorse smaller model that had 10" wheels. I hadn't thought of seeing if they'd fit a front wheel. These seem to be made for the 8 inch front wheels, it fits well in the rim. 1 Share this post Link to post Share on other sites
ebinmaine 72,379 #44 Posted Tuesday at 09:52 AM 3 minutes ago, AlexR said: These seem to be made for the 8 inch front wheels, it fits well in the rim. That definitely makes sense because the ones I have were inside of a 10 inch wheel so they would set nice and even at the outer lip of an 8 inch wheel. Do the holes in your wheels line up nicely with the holes or notches in the weights? 1 Share this post Link to post Share on other sites
AlexR 1,805 #45 Posted Tuesday at 07:14 PM 9 hours ago, ebinmaine said: Do the holes in your wheels line up nicely with the holes or notches in the weights? Yes they line up perfectly with the holes in the weight. Here is a picture of the rear side of the weight. 1 Share this post Link to post Share on other sites
Pullstart 66,594 #46 Posted Tuesday at 10:59 PM Very cool project! 1 1 Share this post Link to post Share on other sites
AlexR 1,805 #47 Posted Wednesday at 06:53 PM So I have these rear weights that I got with the simplicity that look like Cub cadet weights. I think I will use those on the rear of the tractor. Not sure if I will double stack them on the left side or mount them on the inside the rims or one on each side.. So I will get deestone tri-ribs for the front of the tractor, I am trying to figure out what to do on the rear. I am having a hard time wanting to pay for the tru-powers, and I am thinking of getting the BKT TR-315 tires, but I would like some recommendations from you guys on some 23x10.5-12's that are actually 10.5 or close to it wide. I have the wider rims that I got, so I don't want to get the small deestones on this one. 2 Share this post Link to post Share on other sites
Handy Don 13,972 #48 Posted Wednesday at 08:02 PM (edited) 1 hour ago, AlexR said: Do the holes like up with the mounting holes in the WH wheels? Edited Wednesday at 08:04 PM by Handy Don 1 Share this post Link to post Share on other sites
AlexR 1,805 #49 Posted Wednesday at 08:05 PM 2 minutes ago, Handy Don said: These were for four-bolt wheels. You may need some sort of adaptor plate to get them secured to your WH. I can verify, but I believe these will bolt right up to the rear rims. 1 Share this post Link to post Share on other sites
ebinmaine 72,379 #50 Posted Wednesday at 10:09 PM 2 hours ago, Handy Don said: Do the holes like up with the mounting holes in the WH wheels? 2 hours ago, AlexR said: I can verify, but I believe these will bolt right up to the rear rims. Yes. Trina's Military Tribute Tractor has em. 1 1 Share this post Link to post Share on other sites
