Horse Newbie 7,405 #1 Posted June 18, 2024 I found a pic of this tractor/ Wheel Horse while on the internet surfing used tractor parts places in my area. What can you guys tell me about it ? 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #2 Posted June 18, 2024 1973 No name model. Basically a C-160 honestly. 4 Share this post Link to post Share on other sites
ebinmaine 80,755 #3 Posted June 18, 2024 Mike and I were typing at the same time. 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,384 #4 Posted June 18, 2024 Yep, what Mike said. The motion control lever is between your legs, other wise it’s the same as a C-160 Auto 4 Share this post Link to post Share on other sites
Horse Newbie 7,405 #5 Posted June 18, 2024 I’m gonna ride down Saturday and check the place out… see how much Wheel Horse “ gold” they have… 3 1 Share this post Link to post Share on other sites
Bill D 3,156 #6 Posted June 18, 2024 38 minutes ago, Horse Newbie said: I’m gonna ride down Saturday and check the place out… see how much Wheel Horse “ gold” they have… I think I see your next project, or maybe Kevin's. He's wanted a C160 for a long time. 4 Share this post Link to post Share on other sites
ebinmaine 80,755 #7 Posted June 18, 2024 57 minutes ago, Horse Newbie said: I’m gonna ride down Saturday and check the place out… see how much Wheel Horse “ gold” they have… Please keep us posted. Always good to have another vendor of pre-owned Parts when possible. 1 Share this post Link to post Share on other sites
Bill D 3,156 #8 Posted June 18, 2024 @kpinnc maybe you and Tim can take a little road trip. 1 Share this post Link to post Share on other sites
rjg854 13,370 #9 Posted June 18, 2024 Here's the one I have 1 5 Share this post Link to post Share on other sites
Wheelhorse#1 1,997 #10 Posted June 18, 2024 (edited) I have the 12 auto.Converted the motion control to the side.I found the control between the legs to be awkward. I may paint this one someday,great machine Edited June 18, 2024 by Wheelhorse#1 4 Share this post Link to post Share on other sites
rjg854 13,370 #11 Posted June 19, 2024 I don't mind where the motion lever is, actually I like the way it locks into neutral better. It doesn't drift from the vibration like the one mounted on the side does. I feel that one advantage over the my C-160. 3 Share this post Link to post Share on other sites
Sailman 1,307 #12 Posted June 19, 2024 23 minutes ago, rjg854 said: I don't mind where the motion lever is, actually I like the way it locks into neutral better. It doesn't drift from the vibration like the one mounted on the side does. I feel that one advantage over the my C-160. Agreed. My GT 14 has the lever on the tunnel and does not drift like my C series will do. 3 Share this post Link to post Share on other sites
ebinmaine 80,755 #13 Posted June 19, 2024 3 hours ago, rjg854 said: I don't mind where the motion lever is, actually I like the way it locks into neutral better. It doesn't drift from the vibration like the one mounted on the side does. I feel that one advantage over the my C-160. 3 hours ago, rjg854 said: I don't mind where the motion lever is, actually I like the way it locks into neutral better. It doesn't drift from the vibration like the one mounted on the side does. I feel that one advantage over the my C-160. Is the drift you have adjustable? My own 75 C160 Automatic will slow down if you're not holding the lever.. but my parent's tractor and our friend's GT1800 both stay where you set the lever. I leave mine that way on purpose. 1 Share this post Link to post Share on other sites
killroy 36 #14 Posted June 22, 2024 I have the 16 auto no name also. Good running strong machine 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,997 #15 Posted June 22, 2024 Mine use to drift even after adjustment and worn parts on motion control,I believe worn out pump will cause this ? I added a notched block to keep control arm stationary. 2 1 Share this post Link to post Share on other sites
Racinbob 13,193 #16 Posted June 22, 2024 The drifting could likely be just a friction adjustment. My recently acquired 314H would drift a little at first. The motion lever is supposed to take about 6# of pressure to move. I checked it and it was only about 4#. I tightened it to 6# and all tendency to drift was gone. I used a trigger pull gauge to check it. 3 Share this post Link to post Share on other sites
Horse Newbie 7,405 #17 Posted June 23, 2024 On 6/18/2024 at 12:36 PM, ebinmaine said: Please keep us posted. Always good to have another vendor of pre-owned Parts when possible. Not much to see as far as WH’s… have just about any other kind of jun… er “stuff” anyone might need… 2 1 Share this post Link to post Share on other sites
Bill D 3,156 #18 Posted June 23, 2024 (edited) Was the 16 auto in the picture sold, or did you buy it? Edited June 24, 2024 by Bill D 1 Share this post Link to post Share on other sites
John c 223 #19 Posted June 23, 2024 @Racinbob, you have a picture of what you adjusted ? I picked up a 314H in the spring and it does the same thing will drift back to slow I tightened it to 6# and all tendency to drift was gone 2 Share this post Link to post Share on other sites
ebinmaine 80,755 #20 Posted June 23, 2024 23 hours ago, Racinbob said: The drifting could likely be just a friction adjustment. My recently acquired 314H would drift a little at first. The motion lever is supposed to take about 6# of pressure to move. I checked it and it was only about 4#. I tightened it to 6# and all tendency to drift was gone. I used a trigger pull gauge to check it. I'd like that info too 1 Share this post Link to post Share on other sites
Racinbob 13,193 #21 Posted June 23, 2024 This is on a 1996 314H Eaton 11. Of course others may be different. The 6# was in the service manual. There's also an early and late Eaton 11. This one is a late. 1 Share this post Link to post Share on other sites
John c 223 #22 Posted June 23, 2024 thank you Bob so it's just a matter of tightening that bolt a bit to increase the drag on the plate huh ? Once upon a time I had a trigger pull gauge I'll have to see if I can find it, push comes to shove I'll ride around with socket wrench and tweek it as i go to find the sweet spot. thanks again 3 Share this post Link to post Share on other sites
Racinbob 13,193 #23 Posted June 23, 2024 38 minutes ago, John c said: thank you Bob so it's just a matter of tightening that bolt a bit to increase the drag on the plate huh ? Once upon a time I had a trigger pull gauge I'll have to see if I can find it, push comes to shove I'll ride around with socket wrench and tweek it as i go to find the sweet spot. thanks again That's it John. I don't see any reason an adjust by feel would be a problem. Just getting it past the drifting problem is all you're looking for. Share this post Link to post Share on other sites
rjg854 13,370 #24 Posted June 23, 2024 That adjustment has nothing to do with a 16 Auto or C160. Share this post Link to post Share on other sites
Handy Don 17,484 #25 Posted June 24, 2024 9 hours ago, John c said: thank you Bob so it's just a matter of tightening that bolt a bit to increase the drag on the plate huh ? Once upon a time I had a trigger pull gauge I'll have to see if I can find it, push comes to shove I'll ride around with socket wrench and tweek it as i go to find the sweet spot. thanks again Just don’t be tempted to put any kind of lubrication on that spot! It’s intended to run dry. 2 Share this post Link to post Share on other sites
