ebinmaine 80,656 #1 Posted April 20, 2024 @PWL216 Has been FAR too kind to me lately. Here we have a 1971 Bronco. Model number 1 0420 6 Interesting coincidence... today's date is this tractor's model number!! Needs pretty standard repairs. Clean-up. New cables. Wiring is a shambles. Good solid bones overall though. And a good bonus, excellent contender for the old ugly seat contest!! Question now... this has the front attach-o-matic. First year? Or PO installation? 3 4 1 Share this post Link to post Share on other sites
ri702bill 12,992 #2 Posted April 20, 2024 Nice! But the seat cover looks like a 'Bear" trap..... 1 5 Share this post Link to post Share on other sites
Kenneth R Cluley 704 #3 Posted April 20, 2024 Moss and ferns in seat cushion always a nice touch. 1 3 Share this post Link to post Share on other sites
ebinmaine 80,656 #4 Posted April 20, 2024 2 minutes ago, Kenneth R Cluley said: Moss and ferns in seat cushion always a nice touch. It's the rare "live seat" option. 2 4 Share this post Link to post Share on other sites
pfrederi 21,145 #5 Posted April 20, 2024 1969 WHs had the first generation Mule Drive. They were not around long. I would imagine by 1971 current version was in use. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #6 Posted April 20, 2024 4 minutes ago, pfrederi said: 1969 WHs had the first generation Mule Drive. They were not around long. I would imagine by 1971 current version was in use. I had a 1970 Charger 2 or 3 years ago. That had the old style frame with "horns" off the front holding the hood on. Share this post Link to post Share on other sites
squonk 48,084 #7 Posted April 20, 2024 43 minutes ago, ebinmaine said: I had a 1970 Charger 2 or 3 years ago. That had the old style frame with "horns" off the front holding the hood on. Is this the style of hood mount you're talking about Eric? This is off of my 1267 with the modern mule drive adapter 3 Share this post Link to post Share on other sites
19richie66 17,932 #8 Posted April 20, 2024 I have a 71 Bronco 14. It’s the last one of my dad’s and will get a full rebuild. One day. 1 Share this post Link to post Share on other sites
kpinnc 18,940 #9 Posted April 20, 2024 I love Broncos! Nice save! Definitely upgraded to newer tach-a-matic up front and on the belly. And it even has the electric clutch! 2 Share this post Link to post Share on other sites
Pullstart 71,218 #10 Posted April 20, 2024 Me likey those front tires! 1 Share this post Link to post Share on other sites
Sodaking27 1,349 #11 Posted April 20, 2024 Nice. I have a Bronco 14. It was my father in law’s. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #12 Posted April 20, 2024 1 hour ago, squonk said: Is this the style of hood mount you're talking about Eric? This is off of my 1267 with the modern mule drive adapter No sir. These pics are a touch vague but I think you'll be able to see. Share this post Link to post Share on other sites
ebinmaine 80,656 #13 Posted April 20, 2024 54 minutes ago, kpinnc said: I love Broncos! Nice save! I figured you'd like this one. 54 minutes ago, kpinnc said: Definitely upgraded to newer tach-a-matic up front and on the belly. But ya know.... the whole setup is different from the 1970 I had. The axle mount and everything would have been changed. Maybe this one's been frame swapped?? 54 minutes ago, kpinnc said: And it even has the electric clutch! I'm hoping that works but we have several setups for a manual clutch anyhooo. 36 minutes ago, Pullstart said: Me likey those front tires! Me too but they're pretty cracked up. Might be usable with tubes?? 1 1 Share this post Link to post Share on other sites
Pullstart 71,218 #14 Posted April 20, 2024 I’ve been pretty cracked up but I still work. Not even tubed yet! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,328 #15 Posted April 20, 2024 Those fronts sure look like 1045 front tires!! 1 Share this post Link to post Share on other sites
ebinmaine 80,656 #16 Posted April 21, 2024 12 hours ago, Sparky said: Those fronts sure look like 1045 front tires!! I'd had that same thought. One of the reasons I like this rig. These tires are HUGE in comparison to a 1045 tire though!! The front wheels have been swapped at some point. They're closer to the width of maybe an 80s 300/400 type. Probably twice the width of the 60s "Dot" tires. 1 Share this post Link to post Share on other sites
peter lena 10,047 #17 Posted April 21, 2024 @pfrederi the simplicity of basic build strength , on that , only needs the lubrication detailing build , to make it very solid . found that to be the common fault of original set ups . kept basic idea , definitely re greased / replaced bearings , spring tension pully arm , green grease , its the COMBINATION OF COLLECTIVE DRAG , thats the typical killer of attachments. note how mount holes , WALLO OUT ? thats the bearing lube failure , handing it off to the next , MOVEMENT STAGE , MAKE SENSE ? doing some functional detailing , firming up , sloppy areas / washers / connective joints , have found , effortless , motion use . added , angular HEIM joints to a number of lever / rod connection points . the movement ease difference , is dramatic . they also hide in plane sight . just my take on similar , CHRONIC repairs . pete 1 Share this post Link to post Share on other sites
Lee1977 7,764 #18 Posted April 21, 2024 (edited) 17 hours ago, squonk said: Is this the style of hood mount you're talking about Eric? This is off of my 1267 with the modern mule drive adapter The type EB is talking about you have to saw off to install a late model mule drive; Edited April 21, 2024 by Lee1977 2 Share this post Link to post Share on other sites
ebinmaine 80,656 #19 Posted April 21, 2024 1 hour ago, Lee1977 said: The type EB is talking about you have to saw off to install a late model mule drive; Good picture Lee. @squonk that's what my '70 frame looked like. So does anyone know what year was the first for the Attachomatic? Maybe this '71 frame was cut at the front to retrofit((??)) Share this post Link to post Share on other sites
squonk 48,084 #20 Posted April 21, 2024 7 minutes ago, ebinmaine said: Good picture Lee. @squonk that's what my '70 frame looked like. So does anyone know what year was the first for the Attachomatic? Maybe this '71 frame was cut at the front to retrofit((??)) 72 they started the front mule drive but used the side swivel drive also. Might have been a mid year change 1 Share this post Link to post Share on other sites
