87 416-8 horse 430 #26 Posted April 8, 2024 6 minutes ago, ebinmaine said: I went just a hair bigger, AND with a tighter lobe separation angle for a more rowdy idle... but I'm "special". When you get it installed you’ll have to post a video of it running! 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #27 Posted April 8, 2024 21 minutes ago, 87 416-8 horse said: When you get it installed you’ll have to post a video of it running! Oh I will... But it won't likely be this year. Share this post Link to post Share on other sites
rjg854 13,046 #28 Posted April 8, 2024 6 hours ago, ebinmaine said: Oh I will... But it won't likely be this year. Is Colossus taking up to much of your time 1 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #29 Posted April 8, 2024 12 minutes ago, rjg854 said: Is Colossus taking up to much of your time It will be but that's not the reason for me waiting on the cam installation. There are many other things we want to do to th truck before the cam. When I get to that point it's possible I'll get a new cylinder head as well. Screw in studs and better valve springs. I may even go nuts and get a CNC Ported head from Promaxx. Share this post Link to post Share on other sites
87 416-8 horse 430 #30 Posted April 9, 2024 4 hours ago, ebinmaine said: It will be but that's not the reason for me waiting on the cam installation. There are many other things we want to do to th truck before the cam. When I get to that point it's possible I'll get a new cylinder head as well. Screw in studs and better valve springs. I may even go nuts and get a CNC Ported head from Promaxx. You could have your head ported and install some Chevy inline 6 rockers and get some more lift ( if you have clearance for them) And pair that with a 4 barrel intake. https://www.jegs.com/i/Offenhauser/750/6019-DPK/10002/-1 If you want to get real fancy then throw a Holly sniper on it! You should check out Engine power’s video about their 600 hp turbo charged inline 6. Summit racing sells the kits to build it. 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #31 Posted April 9, 2024 5 hours ago, 87 416-8 horse said: You could have your head ported and install some Chevy inline 6 rockers and get some more lift ( if you have clearance for them) And pair that with a 4 barrel intake. https://www.jegs.com/i/Offenhauser/750/6019-DPK/10002/-1 If you want to get real fancy then throw a Holly sniper on it! You should check out Engine power’s video about their 600 hp turbo charged inline 6. Summit racing sells the kits to build it. You can BET I've watched all those videos!! Excellent stuff! I already have a full spectrum of parts for my engine build along with a full rebuild of the rear axle with an Auburn cone Limited Slip Differential and many many other various things. I'll get a list together and update my own thread. 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #32 Posted April 15, 2024 I picked up this crusty old Ferd today for only $300. It’s pretty much identical to my other one except for it has a/c and cruise. I’ll also have some other parts I need and some extras. I’m going to part it out and keep the engine for later. It’s past saving. 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #34 Posted April 15, 2024 The chrome trim, wheels, and that whole front grill has value too. Share this post Link to post Share on other sites
87 416-8 horse 430 #35 Posted April 15, 2024 5 hours ago, ebinmaine said: The chrome trim, wheels, and that whole front grill has value too. Everything on the front is good. The rims are perfect but every piece of the trim has drywall screws in it. Here’s some more pictures of the rust. I forgot to mention that the engine is extremely seized. It’s been off the road since 2017 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #37 Posted April 15, 2024 18 minutes ago, 87 416-8 horse said: engine is extremely seized Likely rebuildable anyway. Another 300 inline 6? Share this post Link to post Share on other sites
87 416-8 horse 430 #38 Posted April 15, 2024 7 minutes ago, ebinmaine said: Likely rebuildable anyway. Another 300 inline 6? Yep. I’m going to look in the cylinders and check if it’s just rust or if something came apart or if there is a crack in the cylinder. I have some knocker lose soaking in there now. 1 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #39 Posted April 17, 2024 I found it why the engine was stuck in the parts truck. When I got it I thought it had 143k miles judging by the body but I think it’s 43k because it still has the cross haching and no ring ridge! 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #41 Posted April 17, 2024 Niiiiice! 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #42 Posted April 18, 2024 Got the 2 cylinder all cleaned up for now. I hit them with some sandpaper and a ball hone. It spins nice and smooth now. They’re not perfect but I’m not too worried because it will probably get bored out in the future. 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #43 Posted April 18, 2024 Did you find the cause? Share this post Link to post Share on other sites
87 416-8 horse 430 #44 Posted April 18, 2024 (edited) It was the two rusted cylinders. Edited April 18, 2024 by 87 416-8 horse Share this post Link to post Share on other sites
ebinmaine 78,854 #45 Posted April 18, 2024 11 minutes ago, 87 416-8 horse said: It was the two rusted cylinders. Just from exposure to something? Or was there a bad cylinder head gasket or otherwise? Share this post Link to post Share on other sites
87 416-8 horse 430 #46 Posted April 18, 2024 (edited) 1 hour ago, ebinmaine said: Just from exposure to something? Or was there a bad cylinder head gasket or otherwise? I think it sat for quite a while with the hood open and the air cleaner off because the carb is stuck and the ports in the head are a bit rusty. Someone pulled the plugs a while back and put some ATF in them but I don't think they got the water out. Edited April 18, 2024 by 87 416-8 horse 1 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #47 Posted April 18, 2024 8 minutes ago, 87 416-8 horse said: I think it sat for quite a while with the hood open and the air cleaner off because the carb is stuck and the ports in the head are a bit rusty. Someone pulled the plugs a while back and put some ATF in them but I don't think they got the water out. Ahh.... 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #48 Posted April 25, 2024 The interior and cab are stripped out and off the frame! All the wiring is out. All I have left to do to the cab is cut the fire wall out and send it off to scrap. Next up is striping the frame down. Pull the engine, trans, and transfer case. This truck has a 3.08 limited slip diff that I’ll rebuild and throw In my truck. And pull the front gears for a spare set. 1 Share this post Link to post Share on other sites
ebinmaine 78,854 #49 Posted April 25, 2024 Fair amount accomplished !! 1 Share this post Link to post Share on other sites
adsm08 4,472 #50 Posted April 25, 2024 On 4/5/2024 at 4:40 PM, JimSraj said: Those inline 300 ci six cylinder engines were nearly indestructible if you just kept the oil changed. I’ve had 4 of them, mostly with 5 speeds behind them. Good on you for keeping one on the road. You didn't even really have to do that. I've heard stories of the Cash4Clunkers era where those 300-6s would run for an hour or more with no oil and just the sodium cilicate in the crank case. 2 Share this post Link to post Share on other sites
