ebinmaine 63,395 #1 Posted March 22 Would you folks mind taking a look at this video and yell me what's up? 1978 or 9 C121 Automatic. Bad brake band? Something else? Thanks! 1 1 Share this post Link to post Share on other sites
Pullstart 59,983 #2 Posted March 22 Huh. I’d say remove the rod and see if it’s sprung indeed. 3 Share this post Link to post Share on other sites
rmaynard 14,934 #3 Posted March 22 I think you have the wrong band. Hole should be on the left. A double hole band is needed, or try drilling another hole. 11 4 2 Share this post Link to post Share on other sites
c-series don 7,882 #4 Posted March 22 Text me tomorrow to remind me and I’ll go take pictures of the ones I have on my C - Series. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,448 #5 Posted March 22 (edited) There is an alignment issue.......rod is pushing band to the outboard side......it should be in a different Brake band, or a longer pivot...to push straightforward. There are different bands with multi holes as mentioned. My .02 Edited March 22 by johnnymag3 3 1 Share this post Link to post Share on other sites
peter lena 8,114 #6 Posted March 22 @johnnymag3 , think I might try , flipping that band over , looking at it , the outside hole point , would be on the INSIDE , for better alignment . just me , pete 2 Share this post Link to post Share on other sites
Handy Don 10,707 #7 Posted March 22 14 hours ago, rmaynard said: think you have the wrong band. Hole should be on the left. A double hole band is needed, or try drilling another hole. The “brakeman” speaks! 2 Share this post Link to post Share on other sites
rmaynard 14,934 #8 Posted March 22 2 hours ago, peter lena said: ...think I might try flipping that band over... Not sure how you would do that Pete. 4 Share this post Link to post Share on other sites
peter lena 8,114 #9 Posted March 22 @rmaynard brake rod is saposed to push straight back , correct ? so if you unhook the push rod , turn the bracket over , so the rod hole is inside , of band the push rod would , be pushing against the strength of the band , inside thrust would hold the band in place / without slid force angling it to outside . thats what I see , BTW , also use conveyor belting , for my brakes . just my view of the situation , pete Share this post Link to post Share on other sites
76c12091520h 3,312 #10 Posted March 23 Like the brake Dr. said : 5 2 1 Share this post Link to post Share on other sites
rmaynard 14,934 #11 Posted March 23 After watching the video again, the brake band never returns to a straight, untwisted condition, leading me to assume that the band is damaged. 1 Share this post Link to post Share on other sites
wallfish 15,988 #12 Posted March 23 (edited) Pull the band off and twist it back into shape. Drill a hole on the other side of the flange and adjust it properly then give it a try. The only cost is time. Edited March 23 by wallfish 4 Share this post Link to post Share on other sites
ebinmaine 63,395 #13 Posted March 23 44 minutes ago, wallfish said: Pull the band off and twist it back into shape. Drill a hole on the other side of the flange and adjust it properly then give it a try. The only cost is time. My thoughts exactly. I straightened the band while still on the tractor but it was too full of muck to leave it. That's grass dirt grease etc. While cleaning that all out the show fell out. Off to the parts shelf I went. Found an older C series piece that has two holes AND a good shoe. 3 Share this post Link to post Share on other sites
ebinmaine 63,395 #14 Posted March 23 Followup and solution: 3 2 Share this post Link to post Share on other sites
peter lena 8,114 #15 Posted March 24 @ebinmaine agree with you on the fix , typically it was a COMBINATION OF ISSUES THAT CREATED THAT , another thing that has really helped , related levers / linkage areas , is to firm up movement connections . regularly added washers , lube , have also gone to a HEIM JOINT , at awkward connections , like the male / female screw on , cut off original end , related DIE NUT , threading , put that on my clutch rod years ago , bombproof , don't tell any body , pete 1 Share this post Link to post Share on other sites
