tractorboy79
Gt14 dash and control panel plastic
tractorboy79
I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
gwest_ca
This one?
tractorboy79
Yes, thank you.
Edit* i can't download the file for some reason
Edited by tractorboy79
Handy Don
49 minutes ago, tractorboy79 said:
Yes, thank you.
I just tested the download and it worked fine.
953 nut
:WRS:
Glad you found us.  Please take a moment to introduce yourself and tell us about your Wheel Horse (s) and how you became addicted to them.
The GT-14 plates can be purchased already made if that is better for your needs'
tractorboy79
Wheel Horse 3D
4 hours ago, tractorboy79 said:
Must be a supporter to download stl files.
wh315-8
Perhaps you found them by now but if not, go to Etsy and search Greystone3d. They have the GT14 plates. I have bought WH items from them on Etsy and they are reliable and trustworthy.
tractorboy79
I could not find them, perhaps you could send me a link if they show up for you, thank you for your input.
953 nut
I think @Wheel Horse 3D moved his sales off Etsy.  Hope he will chime in or you could send him a PM.
wh315-8
I don’t know why they aren’t on Etsy anymore but they are here under vendors still.
Edited by wh315-8
Missing word
Wheel Horse 3D
5 hours ago, wh315-8 said:
I don’t why they aren’t on Etsy anymore but they are here under vendors still.
Yep, we're still here! I'll have those added to the new site tonight, and update the vendors section links sometime this week.
Https://greystone-3d.square.site
Wheel Horse 3D
@tractorboy79@953 nut@wh315-8 Thanks everyone for getting this to my attention! The GT14 dash and tunnel cover plates are now up in the new store and the link is now correct in the vendor section!
https://greystone-3d.square.site/product/wheelhorse-gt-14-dash-and-tunnel-cover-plates/19?cp=true&sa=true&sbp=true&q=false
  • Excellent 2
  • Similar Content
    • Rob R
      By Rob R
      I finally broke something serious on my GT14 the Lift arm that is attach (by chain) to the plow snapped off at the receiver arm top which is attached to the Hydro cylinder on the bottom. It appears the broken arm was welded there (see pics) my big question is how do get the "H" arm which is mounted on each side of the tractor by the steel plates the go up from the tractor frame out. I took off the four mounting bolts for it but it is tightly fit in aforementioned side plates I can move it up and down but cannot get it out. Is it relatively easy to remove one of the side plates and if yes which side is the easiest the pedal side left side (from the back) or the right side (from the back). Has anyone from the square experienced this problem, does anyone have this lift assembly. Any and all comments welcomed. p.s. I have used this beast for 10 years with zero major issues guess the stress of the lifting finally got to the arm which obviously is under tremendous pressure......Rob
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
