RED-Z06 2,720 #1 Posted March 14, 2024 Ive seen them in a few different models, my M12S will eventually need to be replaced, ive found a good running electric start 16hp Vanguard, 1" shaft which I can sleeve to 1⅛ for the pulley. Exhaust I can figure out, even if I have to run dual stacks, but...will it clear the hood with the oil filter housing up front, is the crank height the same? Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted March 14, 2024 @kpinnc @Lee1977 @davem1111 2 Share this post Link to post Share on other sites
JoeM 10,318 #3 Posted March 14, 2024 I did one for my son a few years ago Excellent choice. Had one on an FEL also Homemade muffler on this one. 1 2 Share this post Link to post Share on other sites
Cody 285 #4 Posted March 14, 2024 I did one a few years ago in a 416-8. I used an engine plate from a gt1100 which adapted the engine bolt pattern and gave the correct crankshaft height. Used a engine pulley from a c-85 which had a 1" crank, an easy swap that you'll be very pleased with! 2 Share this post Link to post Share on other sites
Lee1977 7,813 #6 Posted March 14, 2024 (edited) An 18 Vanguard in a C-120, and a 16 Vanguard in a 312-8. The back side of the PTO hole is the center line of the crank shaft. I raised the engine mount plate 3/4". Edited March 14, 2024 by Lee1977 3 1 Share this post Link to post Share on other sites
Lee1977 7,813 #7 Posted March 14, 2024 (edited) I think I used a 3/16" spacer to get the pulley away from the engine. Edited March 14, 2024 by Lee1977 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #8 Posted March 14, 2024 So, raise the engine 3/4" and space the pulley out 3/16", that's not terrible 1 Share this post Link to post Share on other sites
Lee1977 7,813 #9 Posted March 14, 2024 (edited) 58 minutes ago, RED-Z06 said: So, raise the engine 3/4" and space the pulley out 3/16", that's not terrible I wasn't happy with how close the pulley was to the engine. I frist used a hydro pulley on my 312-8, it was too fast with the 25" tires So I changed iy back to the stock pulley. I had to put a spacer on the C-120 as the PTO would push the pulley back. Edited March 14, 2024 by Lee1977 Share this post Link to post Share on other sites
RED-Z06 2,720 #10 Posted March 14, 2024 4 minutes ago, Lee1977 said: I wasn't happy with how close the pulley was to the engine. I frist used a hydro pulley on my 312-8, it was too fast with the 25" tires So I changed iy back to the stock pulley. I had to put a spacer on the C-120 as the PTO would push the pulley back. I wont be running any attachments or a pto, just using a dirt blade 1 Share this post Link to post Share on other sites
kpinnc 19,107 #11 Posted March 15, 2024 8 hours ago, RED-Z06 said: wont be running any attachments or a pto, just using a dirt blade My only suggestion is to use a good quality 1-2psi electric fuel pump. All of my Vanguards developed pulse pump problems (say that really fast five times ), and it mimicks carb issues. Supposedly a known issue with the oil pan gasket. Head gaskets have some very thin spots too, so definitely inspect them when setting it up. Never had another problem after losing the pulse fuel pumps. Stay away from cheap gaskets too. 1 Share this post Link to post Share on other sites
