Lane Ranger 12,068 #326 Posted June 13, 2024 One pair of used spindles. Been repaired with weld added. I think fit 702/854 type front. $20 Share this post Link to post Share on other sites
Lane Ranger 12,068 #327 Posted June 13, 2024 Kohler K-91 muffler new , primed. $10 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,637 #328 Posted June 13, 2024 3 minutes ago, Lane Ranger said: Mike this has some rough spots on top. My top pictures did not get posted! Still a good solid seat pan , you just need a seat cushion on it! That's fine! 2 Share this post Link to post Share on other sites
Lane Ranger 12,068 #329 Posted June 13, 2024 (edited) On 6/2/2024 at 11:09 PM, OoPEZoO said: I’ll be on the lookout for a usable set of front wheels for the RJ58 I picked up this spring. Not looking for show quality restored perfection….don’t even have to be “correct”, just looking for something that looks OKish. The originals were completely roached, and the only others I have are stock fronts off my 314 that are 6” wheels and too wide to look right. check out the set I am bring to the show! RJ wheels with Deestone tri-ribs for $125. Edited June 13, 2024 by Lane Ranger Share this post Link to post Share on other sites
squonk 47,544 #330 Posted June 13, 2024 19 minutes ago, Lane Ranger said: $35. And it’s a good one! I'll take it Lane 1 Share this post Link to post Share on other sites
Ed Kennell 46,711 #331 Posted June 13, 2024 (edited) More parts. Good Tecky tin $15 Fuel tankes $10 New small parts Kohler, B&S, Stens, Owen $1-$5 Filters $1-$5 New Solenoid $10 Used good solenoid $5 Tire chains some new and some used 4 link $20 2 link $30 New Ignition modules $20 New starter $40 Used fuel pump $5 Small used carbs $15 New coil with external resistor $30 New wheels 5X8 $20 pair Like new tires on wheels $40 I have short and long plow frames and 42 and 54" blades that I could bring. Buckets of gear, swing arm side drive and front drive deck parts. Axles, manual lift levers, pedals, link rods, dash plates, and much more. Too much to list and price...PM me for details of items you need. PM me for info Transmission pulley $40 Edited June 13, 2024 by Ed Kennell 1 Share this post Link to post Share on other sites
Bill D 3,024 #332 Posted June 13, 2024 1 hour ago, Ed Kennell said: More parts. Good Tecky tin $15 Fuel tankes $10 New small parts Kohler, B&S, Stens, Owen $1-$5 Filters $1-$5 New Solenoid $10 Used good solenoid $5 Tire chains some new and some used 4 link $20 2 link $30 New Ignition modules $20 New starter $40 Used fuel pump $5 Small used carbs $15 New coil with external resistor $30 New wheels 5X8 $20 pair Like new tires on wheels $40 I have short and long plow frames and 42 and 54" blades that I could bring. Buckets of gear, swing arm side drive and front drive deck parts. Axles, manual lift levers, pedals, link rods, dash plates, and much more. Too much to list and price...PM me for details of items you need. PM me for info Transmission pulley $40 Any idea what those Robin ignition coils fit? I have a 21" Snapper walk behind with a two Stroke Robin engine. I'd like to have a coil around if possible Share this post Link to post Share on other sites
Pullstart 70,930 #333 Posted June 13, 2024 @Ed Kennell If that Kohler air filter and pre filter will fit a 12 hp, I’ll take it! Share this post Link to post Share on other sites
Ed Kennell 46,711 #334 Posted June 13, 2024 8 minutes ago, Bill D said: Any idea what those Robin ignition coils fit? Not sure Bill. Can you research your engine to get a module # ? Share this post Link to post Share on other sites
Ed Kennell 46,711 #335 Posted June 13, 2024 8 minutes ago, Pullstart said: @Ed Kennell If that Kohler air filter and pre filter will fit a 12 hp, I’ll take it! 1 Share this post Link to post Share on other sites
Pullstart 70,930 #336 Posted June 13, 2024 I think that’s too big. I have one of those.. 1 Share this post Link to post Share on other sites
Bill D 3,024 #337 Posted June 13, 2024 (edited) 2 hours ago, Ed Kennell said: Not sure Bill. Can you research your engine to get a module # ? I'll look it up over the next couple of days. Could you please take a picture of them out of the box? That'll help me figure out if they're even close to what I'm looking for. Thanks. Edited June 13, 2024 by Bill D Share this post Link to post Share on other sites
Ed Kennell 46,711 #338 Posted June 13, 2024 1 hour ago, Bill D said: Could you please take a picture of them out of the box? Share this post Link to post Share on other sites
WHX?? 57,593 #339 Posted June 13, 2024 8 hours ago, Mike'sHorseBarn said: Lane, I'll hunt you up Thursday for the square seat! Looks better than the other one Mike... Share this post Link to post Share on other sites
Mike'sHorseBarn 3,637 #340 Posted June 13, 2024 14 minutes ago, WHX?? said: Looks better than the other one Mike... Yea but I'm still gonna fix that one up because something tells me m not done buying tractors.......... 2 2 Share this post Link to post Share on other sites
WHX?? 57,593 #341 Posted June 13, 2024 8 minutes ago, Mike'sHorseBarn said: Yea but I'm still gonna fix that one up because something tells me m not done buying tractors.......... Good plan heard tell they don't make square pans any more... 2 Share this post Link to post Share on other sites
ebinmaine 79,891 #342 Posted June 13, 2024 (edited) GOT ONE!!! I'm figuring this is a wicked longshot... I'd like to have a correct model number plate for a 1974 C160-8 with a Tecumseh engine. Model number 1- 0385 Edited June 19, 2024 by ebinmaine Share this post Link to post Share on other sites
Bill D 3,024 #343 Posted June 13, 2024 I'm looking for some Onan specific PTO clutch parts. I need the upper bracket that bits to the engine just above the PTO and the clutch hoop. Anything off a 416H or 516H should work. I know the 520H used a different part number, not sure what the difference is. I can't make the show but Handy Don had agreed to pick them up for me. Anybody have these parts? Thanks. Share this post Link to post Share on other sites
Sailman 1,307 #344 Posted June 13, 2024 20 hours ago, 19richie66 said: Where are you in Georgia? I have a hood and steering wheel. I’m in east North Carolina south of greenville. Hood is decent. I’ll get pics tomorrow. I’ll be going to Florida at the end of July. I could meet you somewhere on the way. @19richie66 Thanks! I think that would be great. Just sent a you a private message, send pictures and prices through there. Share this post Link to post Share on other sites
Sailman 1,307 #345 Posted June 13, 2024 20 hours ago, WHX?? said: I may have a belt guard. Yours for shipping if I do. Let me know if you have one and we can work something out. If not wonder if welding it is an option?? Share this post Link to post Share on other sites
19richie66 17,930 #346 Posted June 13, 2024 3 minutes ago, Sailman said: Let me know if you have one and we can work something out. If not wonder if welding it is an option?? May have one of these too. I Need a picture of a belt guard like you need if you can send me one. I sent you my number. 1 Share this post Link to post Share on other sites
Sailman 1,307 #347 Posted June 13, 2024 Still in need of C-120 hood and steering wheel if anyone going to the Big Show might be passing through the Atlanta GA area. Share this post Link to post Share on other sites
19richie66 17,930 #348 Posted June 13, 2024 2 minutes ago, Sailman said: Still in need of C-120 hood and steering wheel if anyone going to the Big Show might be passing through the Atlanta GA area. I can bring them to the show if you can find someone to get them to you. Get pictures tomorrow. 1 Share this post Link to post Share on other sites
kthack657 335 #349 Posted June 14, 2024 (edited) SOLD! 953/1054/GT14 rear wheel weights $250 OBO Edited June 14, 2024 by kthack657 2 1 Share this post Link to post Share on other sites
WH1618speed 543 #350 Posted June 14, 2024 (edited) Wheel Horse C-100 Runs extremely well, has Walbro carb Rear lift assembly with a clevis No knocks, slight smoke on cold start Has the factory leather seat with embossed WH logo It charges and lights work. Can deliver to big show in PA $350 obo Running Edited June 14, 2024 by WH1618speed Share this post Link to post Share on other sites
