68CommandoGuy 0 #1 Posted February 20, 2024 Hi, guys. I have a 1969 Wheel Horse Raider with a Tecumseh HH100 engine. It has a Walbro LME 36 carburetor that I would like to replace. Can I replace with a Tecumseh carburetor? (If so, what number would the carb be, and will it need any modifications to linkage, etc.?) Share this post Link to post Share on other sites
ebinmaine 70,860 #2 Posted February 20, 2024 You might be able to use a carb from a Kohler 8. Share this post Link to post Share on other sites
ebinmaine 70,860 #3 Posted February 20, 2024 @Pullstart Thoughts? Share this post Link to post Share on other sites
Pullstart 64,699 #4 Posted February 20, 2024 1 hour ago, ebinmaine said: @Pullstart Thoughts? I have two of those. 1 if it were to fit, I’d try it! 2 the carb and engine don’t much care what brand they are. The engine will suck, squeeze, bang blow. The carb will supply the fuel and air to make the bang. 3 1 Share this post Link to post Share on other sites
wallfish 17,531 #5 Posted February 21, 2024 @squonk Mike will tell you all about Tecumseh carbs and engines if he doesn't fall asleep before the end of his long rant! LOL Not 100% but I remember seeing that LME designation on Teccy engines and think they switched to those Walbro carbs. So basically you might already have a Teccy carb for it. Is that carb rebuildable or what's the issue with the carb that it needs to be replaced ? Share this post Link to post Share on other sites
