Countdown To Christmas!
sjoemie himself
Case International 585 and implements
sjoemie himself
Aaand then a gust of wind took out one of the doors. Definetely NOT what I was planning to do this afternoon..
Note: yes the door, what's left of it anyway, is in horrible condition and I would love to replace it. Some hurdles to take before that can happen though.
  • Sad 3
sjoemie himself
First official upgrade to the Case International. It needed some front fenders badly. Took the tractor out in the rain a few times, last time together with one of my  nephews and we got plenty of water and mud flung onto our faces.. no bueno.. although my nephew did'nt seem to care :lol:
Gathered up some flat bar stock and started puzzeling. Turns out nothing is flat, square and/or plumb on a front axle like this so there were quite a few tricky angles to get right.
My dad rolled a hoop which I used to make part of the main frame with.
Looked at some pictures on the interwebs for inspiration and (imho) improved the design to my liking. Top bolts onto an exsisting bolt which I replaced with an longer one. The bottom wraps around the wheelhub with an exhaust bolt (if that even is a word in English).
Bolted the fenders to the brackets with some carriage bolts and self locking nuts.
Done! Don't know why but I always really like the look of front fenders on 2wd tractors.
Thanks for watching!
Edited by sjoemie himself
Added picture
  • Excellent 4
  • Heart 1
sjoemie himself
Have been busy the last couple of weeks. The Inter is running well until it did'nt.. fuel issue.. the tank was al plugged up with dirt and debris. I unclogged it and installed a see though pre-filter along with new fuelfilters. Runs much better now.
Still have to properly clean the tank though.
Also carried out maintenance on the entire machine, changed all the fluids and filters minus coolant.
Also fixed both leaky PTO seals.
Bearings are excellent, shafts do have some minimal wear but nothing a new shaft seal won't fix.
Now no more leakage detected.
After that it was time for the first 'real' test.. cleaning up years of accumulated dirt, grass, weeds and what not to uncover the concrete slabs that were hidden underneath.
I thoroughly enjoyed this little job and the tractor did excellent. I'm kinda getting why all you guys are always going on about 'seat time' :D
Added info
  • Excellent 4
sjoemie himself
Gave the Inter the 'ol greasy @peter lena oil rubdown treatment, shined her right up!
  • Excellent 4
peter lena
@sjoemie himself  as you know , a lubrification rub down / recovery  , is so simple  / easy to do , once its in  place , its steadily  gaining  / correcting  neglect .  usually do that first on , any  mechanical pick up . forget about it , get on with the serious stuff , then  rub it down , re apply  you're good . have to mention , obviousely  do not  personally know you , but back in the day , having you  as a solid work partner , would be my first choice  !  always thinking out of the box , adapting to any issue , think  i would turn those carriage fender bolts over,  have nuts top side , reduce nut crud pick up . thank you for your regular , idea sharing  , pete
sjoemie himself
Thank you for your kinds words Peter, much appreciated!
I agree with you that the bolts turned the other way around would pick up less junk but in this Case (pun intended) I chose form over function, I just like the shiny smooth side up better.
I will however, after you pointing this out, give the bolts a proper coppergrease/neversneeze coating when I definitifely install the fenders, still gotta get them painted or powdercoated after some final tweaks.
sjoemie himself
Played in the dirt today. The goal was to loosen the paddock so that it would dry quicker. Looking promising so far and had a BUNCH of fun ofcourse.
  • Excellent 4
sjoemie himself
After playing in the dirt last time I found that the cultivator/implement was a little long for my liking. Especially in the corners and near fence posts this is not ideal.
So I decided to shorten it and re-mount the tines on the two front rows of the cultivator.
Before, five rows of tines:
After, two (and a half) rows of tines:
Before:
After:
Also added some reinforcements on the upper lifting point since it was showing some cracks.
Still some room for improvements but I like it a lot better now. Much more nimble and less rear swing (don't know the right word) when working close to the fence.
Still want to add a roller of some sorts to 'crumble' the clumps a bit more.
  • Excellent 2
ebinmaine
That's a perfectly fine word assortment to me. Nice work on that implement.
bds1984
On 3/15/2024 at 9:33 AM, sjoemie himself said:
Seeing this makes me remember the headaches from sanding, all the dust, and the smell even with a mask on!  I hope your vacuum attached to that is able to keep up!
sjoemie himself
The itching and the headaches from the smell were something else, I might have lost a few braincells in the process :scratchead:
One of my el-cheapo shop vacs gave up the ghost during sanding, kinda says something about the nasty dust. To be honest though it was on it's way out before this job..
sjoemie himself
So since I've got a 3 week break from work I got some time to do some hobbying again.
One of the things I did last week was to install a side plow on the cultivator used to clean up the horse paddock. This side plow allows me to get a nice crisp edge on the sides of the paddock. The horseriders get up to the fence and ride on what's called the "hoefslag" in Dutch.. don't now the right word for it. This creates a kind of trench which is undesireable for the riders.
The plow acts as a small dozer or grader and the cultivator teeth take care of the rest.
It raises out of the way when I don't need to use it.
Height or depth is fully adjustable.
It sticks out about 20cm/8" past the tire.
Simple but effective. Thinking about maybe welding up the leading edge with an abrasive resistant material like Stellite or Hardox.
Stay tuned. More updates to come.
Greetings from the Netherlands, Mark
  • Excellent 4
Handy Don
Very slick!
I would call the place they ride, that you are leveling out with your new gadget, the “hoof path"
Edited by Handy Don
ebinmaine
11 hours ago, Handy Don said:
Very slick!
Absolutely agreed!
peter lena
@sjoemie himself  as usual , good  insight into a problem , nothing  sarcastic , those rusty  hitch mounts , need some lubricant , for easier  movement / follow , like the  idea of leading edge enhancement , might even  think of an angular change , for  easier release .like  this face set up   https://www.amazon.com/Respirator-Reusable-Polishing-Woodworking-  for  questionable clean up , might even add a multi holed flange , on the top of that bottom plow , allowing you to easily , enhance slide off , think the build strength of that , would show you what it likes in discharge , regularly look for effects on any mod I  make ,  thank you for the insight , pete
sjoemie himself
Notmally I'm all for lubrication but in this case I would have to politely disagree with you. This is a semi permanent connection which has lots of play (pin to the swivel ball thingy) in it from factory. Any grease here would attract dust and dirt and would probably do more harm than good.
On the angle adjustment on the plow however I totally agree. I thought about several ways to incorporate that but could'nt find a solution that was stupid simple so I made it like it is now.
The angle could be a bit sharper (or less shallow) so the dirt slides off better but for now I'm reasonably pleased with how it works.
Another thing I might do is polish the inside of the plow because it's pretty rusty at the moment. I think this might help in evacuating the dirt aswell.
sjoemie himself
Keen eyed viewers may have already noticed that besides adding the 'hoof path' plow I also made some changes to the rear of the cultivator.
Originally it had two guide wheels in the back to (help) set the working depth on the machine.
Since the cultivator is used to maintain a horseriding arena I was looking for a way to break up the soil a bit more after the cultivating tines did their job.
So I started searching for a crumble roller or tube roller but found out that these were highly sought after and about $300-400,- used. You know me.. better make something myself then..
Since I have a CNC-plasma machine why not use it? Made a design in CAD and started cutting.
Some time later I had four disks on my workbench and started assembly. 8mm/~1/4" rebar was used to make the "crumbler".
Welding everything up. The main challenge is to keep everything square and true. With use of the CNC-plasma track and some Fireball Tools this went fairly well.
Bearing blocks were added on each side.
Eyeballing what the attachment of the roller to the cultivator should look like.
Almost done here. I cut off the wheels and used the now leftover round stock to extend the original depth setting axle. The roller is wider than the old guidewheels.
Some flat stock leftover from shortening the original cultivator was used to make the new arms to which the roller attaches.
Not pictured here but I added a gusset from the arm to the depth setting axle for more ridgidity.
Time to test. I'm happy to report everything went about as good as I had hoped.
The cultivator now leaves an even and almost fluffy bed for the horses to ride on.
Added info
  • Excellent 2
sjoemie himself
Do you know that song from Britney Spears which was quite the hit..? What's it called again.. "Oops I did something or other" I think it was :P
Anywayyy.. I present to you not one, but TWO new old projects :confusion-helpsos:
I could'nt help myself when I came across these two puppies for $375,- Went down to take a look and made a deal at $350,-
Put the 'ol Volvo to work with a (rented) trailer and picked them up one at a time. They were about a 35 minute drive (one way) away so no biggie.
The man I bought them from loaded them with a FEL on his New Holland tractor which worked like a charm. Unloading them was a bit of an adventure but with the help of my SO went pretty smooth.
As you can probably tell they need some TLC although one tipper trailer is in better shape than the other. Both are identical so I'm probably going to pick and choose the best parts to make one good base and restore that one and sell the other as is. Or I might restore both and sell one fully restored.. or keep 'em both maybe? Decisions, decisions..
Oh right, almost forgot.. the idea is to use these to haul manure with these instead of the hitch mounted "dirt bucket" I'm currently using. Since we now keep four and a half horses at the stable the pile of crêpe is rapidly filling up the dirt bucket. It has to be emptied about every two to three days. Which is fine in summertime but now with winter approaching it's no fun doing it in the wet, cold and dark. Hopefully the tipping trailer can get us through the week so it can be emptied during daylight on the weekends.
The dirt bucket is about 1.8m/6ft wide and 0.8m/2.5ft deep and high.
The tipper trailers beds are 2m/6.5ft wide, 3m/10ft long and 0.6m/2ft high so a lot more volume. Should be good for about 4 metric tonne of manure.
ebinmaine
1 hour ago, sjoemie himself said:
Since we now keep four and a HALF horses
Half a horses??!!??
  • Haha 1
sjoemie himself
19 hours ago, ebinmaine said:
Half
Pun intended ofcourse.. there's four 'horse' horses or 'real' horses and one Shetland pony. All depends on if your animal is taller than a certain measurement.
In the horse community this is a VERY delicate subject so ofcourse I always lump together every animal with manes slightly bigger than a full grown Danish dog and call that a horse. Fun times guaranteed! :icecream:
  • Haha 2
  • Heart 1
sjoemie himself
Posted (edited)
Update anyone?
Life has been pretty busy but I managed to squeeze in a little bit of hobby time. Some might remember I purchased two of these. The plan was to restore both and sell one to have one 'free' tipper. Well plans changed and I've since sold one of them to my (not so) little nephew. He was looking for a dumper/tipper for a while and this was exactly what he wanted.
Anyhow..
Disassembled, cleaned, painted and greased the support leg (?) on my little tipper. Makes coupling a lot easier. Might add a thrust washer later to make it even smoother but this will do for now.
Next I tested and installed the cylinder which came with the tipper but wasn't installed when I bought it. I also reinforced the cradle in which the cylinder sits since it bowed a bit in the life it's had so far. Not too alarming but enough to make me want to stop further bowing.
Next I made new hoses for the cylinder end, new hardline for the frame and another hose for hooking up to the tractor.
Also started work on putting some lights on this thing because it only had reflectors on it 'from factory' so to say. Apparently in ye olde times it wasn't mandatory for slow moving (agricultural) equipment to have lights.
The complete kit with lights, cables and a plug was about $40,- so for that kind of money I don't want to run the risk of getting a fine.
  • Excellent 2
6wheeler
Posted (edited)
You do some very nice work. I don't know if you got the fuel tank fixed up yet. What I do with an older tractor like that. When the tank is empty, I take the sediment bowl off of the tank. Then when you look into the inlet hole, clean all the debris/rust out of it. Then take a piece of steel or brass window screen about 3 inches (7.62 cm.) wide. And, just long enough so that you can roll it up to fit snugly into the inlet on the sediment bowl. Fold over a bit on the top so rubbish can't get inside. Re-install the sediment bowl. That way it cannot plug the sediment bowl inlet while still allowing tiny particle to get trapped in the bowl as it should. All of our older tractors whether Gas or Diesel get that treatment. Nice work on those fenders.
Edited by 6wheeler
sjoemie himself
Posted (edited)
Not yet but I've figured out that keeping the tank filled up helps a lot with the issues I'm having.
When the time is right I'm going to remove the tank all together and fill it up with gravel and make it spin in some way. Then give the inside a good clean and apply a anti-rust coating. Should sort things out.
In other news.. since we've moved houses it's been pretty busy around here with all kinds of small and big(ger) jobs.
One of the more fun jobs which was on my wishlist for a while I completed yesterday.
I installed some quick couplings on the three-point hitch of my IH 585.
This way I can open the couplers up, back up to the implement of choice, raise the liftarms and hitch it right up.
Saves a lot of back and forth, pushing, pulling and other shenanigans..
Old situation. Did'nt look too bad until I took it off the tractor. The ball end that connected to the tractor was so far gone it literally fell out of it's socket.20250628_103845.jpg.471255a090c7821edefa75f3c3172269.jpg
Both ball ends will be replaced.
All welded up and gave them a lick of black paint. Nothing fancy, just rattlebombed them.
I'm not sure if these couplers are common in the US of A. You can pull the eye up or back to lock them in the open position. That way when you hitch it up to the implement a spring mechanism automatically closes them when you're hitched up correctly.
grammer
  • Excellent 2
Handy Don
Posted (edited)
I've not seen them on any tractors (but my experience here is very limited). Bobcat and other brands of skid steers have a similar mechanism for quick-changing front-mount implements like buckets, blades, forks, etc.
Edited by Handy Don
sjoemie himself
I'm still kickin' about. Been busy as a Bee doing all kinds of stuff on and around the house.
Besides that I've spent some free time on the 585 again. Trying to work out the lighting on it and tidy it up a bit.
Old headlight fixture, pretty good condition considering it's 40 years old, but I only have this one and they are NLA..
So I copied the design (a bit) and made two new ones.
Not too shabby.
The two tabs sticking out get bent in front of the light to "fix" it in place. The fixture attaches to the front grille with two springs a foam/rubber sealing ring and a few adjusting screws. I have yet to figure out exactly how to copy that!
Next up on the list is fixing the front grille.. they are available aftermarket but pretty pricey.. about $350-$400,- shipping and import/tax not included :cry:
So I'm going to attempt to repair it myself. After my roof I said I would'nt do that fibreglass stuff again but here we are :wacko:
Current (very sad) state.. tips and tricks are very much welcome!
P.s. I'm looking for a piece of material as shown below. Anybody what this specific pattern/style of plate is called?
P.p.s.. Also looking for a drill and tap set for standard American/English threads. What sizes should I be looking for?
At home I've got a set with drills and taps for M3-M12. Is there something similar available in the non-metric flavour?
Thanks for reading/viewing!
  • Similar Content
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • PWL216
      By PWL216
      I have for sale a 1984 C-105 with deck and Snowblower. I got this as part of a package. There’s no battery and I haven’t tried to start it. I’m selling it as a project. The deck has one spindle out, but with it, as prior owner claims bearing was replaced. The snowblower has the flag and looks to be in very good condition. All but 1 tire holds air. The mower is complete. Includes mule drive. The extra hood (c-175) you see in the picture can go with the tractor for an additional $50. Thx for looking.
    • OldWorkHorse
      By OldWorkHorse
      Working on a custom light bar for the recently restored 314-8
    • JZilla024
      By JZilla024
      Hello everyone!
      I recently inherited my grandpa's
      Wheel Horse 753. I remember it running before his health declined about 15 years ago. My intentions are just to get it running and do a mild restoration, it'll stay in the family.
      Without further ado, here it is!
      Having a hard time with pictures due to no phone service at my shop. I'll be sure to update soon.
