Pullstart 68,878 #1 Posted January 26, 2024 Has anyone rolled their tractor before? Just curious as to how it turned out… For a worker, I’d imagine a good ‘ole oil based paint like this guy used wouldn’t be too terrible. 3 1 Share this post Link to post Share on other sites
ri702bill 11,254 #2 Posted January 26, 2024 (edited) Might need to add another 20 feet to make it a "20 Footer"...... True story - A family up the street from my parent's house emmigrated from a mediterrainean country. The Dad bought his first used car, a 1962 Pontiac Tempest. One hot August Saturday afternoon, he decides to give the car a fresh coat of latex house paint with a roller. He is doing this at the curb, the house had no garage. Sky starts to darken, but he keeps on going. We get a gully-washer of a storm, all the horizontal surfaces are stripped of the new paint, We used to tease him telling him that you are supposed to wash the car before you paint it...... Edited January 27, 2024 by ri702bill 10 Share this post Link to post Share on other sites
Red-Bovine 337 #3 Posted January 26, 2024 Proper technique and properly thinned paint can result is really good paint jobs using a roller. I used a roller to paint boats with varnish and two part polyurethane with excellent results. the absence of overspray all over everything was well worth the effort. 6 9 Share this post Link to post Share on other sites
Pullstart 68,878 #4 Posted January 26, 2024 @Red-Bovine beautiful boats! 5 Share this post Link to post Share on other sites
kpinnc 17,149 #5 Posted January 26, 2024 26 minutes ago, Red-Bovine said: Proper technique and properly thinned paint can result is really good paint jobs using a roller. Agreed. Times two when wet sanding and buffing afterwards. 1 Share this post Link to post Share on other sites
8ntruck 8,601 #6 Posted January 26, 2024 Some time ago, Car Craft ran a couple of articles on painting a car with rollers and Rust Oleum. Thinned paint, multiple coats, and sanding in between were described along with a final polish. 4 Share this post Link to post Share on other sites
ebinmaine 77,323 #7 Posted January 26, 2024 20 minutes ago, 8ntruck said: Some time ago, Car Craft ran a couple of articles on painting a car with rollers and Rust Oleum. Thinned paint, multiple coats, and sanding in between were described along with a final polish. Seems I've read that one. I've considered rolling paint on the frame, front axle and transmission. Could be less wasteful provided the prep and post work was done right. 4 Share this post Link to post Share on other sites
Pullstart 68,878 #8 Posted January 26, 2024 I’m tempted to try this on my FEL project. The frame is already black, the goal color of the whole machine. Sheet metal, loader frame, everything. Gloss black. 5 Share this post Link to post Share on other sites
8ntruck 8,601 #9 Posted January 26, 2024 A couple of the project's I had during my careers were the design and build of some new industrial equipment. The framework on these things was typically square steel tubing of various sizes. Those got painted by roller using industrial enamel. Then again, the appearance of those paint jobs was not of primary concern. 2 Share this post Link to post Share on other sites
ri702bill 11,254 #10 Posted January 26, 2024 1 hour ago, 8ntruck said: A couple of the project's I had during my careers were the design and build of some new industrial equipment. The framework on these things was typically square steel tubing of various sizes. Those got painted by roller using industrial enamel. A project that does not function is merely a doorstop. 2 Share this post Link to post Share on other sites
Sailman 1,306 #11 Posted January 26, 2024 I have used a similar process painting a boat with either Awl Grip or other 2 part polyurethane paint. Key was to use a third thinning additive to adjust for temp and humidity, a foam roller or china bristle brush for application followed by foam brush to lightly "tip" the paint as it began to dry. Done right its honestly hard to tell the difference between that and a sprayed application. 3 Share this post Link to post Share on other sites
wallfish 19,284 #12 Posted January 27, 2024 7 hours ago, Pullstart said: Gloss black. Probably not an issue with most of it but black will always show the most imperfections and especially so on the sheet metal. It's a worker tractor and not a collectors antique car either 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #13 Posted January 27, 2024 @Pullstart Instead of paint why don't you use some Flex seal black tape it comes in different widths, and it will seal all the moisture from the tractor and you could use the spray cans of liquid rubber for the hard-to-reach areas. 3 Share this post Link to post Share on other sites
953 nut 64,108 #14 Posted January 27, 2024 On 1/26/2024 at 7:45 AM, Pullstart said: anyone rolled their tractor Well yes I did roll a tractor over when I was a wild and reckless kid! OH, nevermind, you were talking about rolling paint ON a tractor not rolling a tractor. 2 4 Share this post Link to post Share on other sites
JoeM 9,617 #15 Posted January 27, 2024 15 hours ago, wallfish said: with most of it but black will always show the most imperfections Or scuff it up with 220 and spray with some cheap bed liner paint. Hides all of those imperfections. And really you can have all the body parts off of an xi in half and hour and painted in no time. 2 Share this post Link to post Share on other sites
