Mickwhitt 5,250 #101 Posted December 26, 2024 Boxing days is usually spent in front of the telly, we are watching Zulu which is a good old British story of military pluck. I managed to sneak some of the Landrover parts into the lounge and assembled the rear bodywork and cab floor so I can see what is going to be needed for detailing the whole structure. The panels are held together with a mixture of countersunk and button head screws, this is fine but it leaves you with a lot of bolt heads on show, which rather spoil the look. I'm going to clean all the panels and then glue them together with a high strength and flexible metal adhesive. That way I can ditch the bolts when the glue is cured and replace them with scale aluminium rivets. Still a long way to go but it's looking more like a landrover now. 1 4 Share this post Link to post Share on other sites
Mickwhitt 5,250 #102 Posted December 29, 2024 The front bulkhead supports the doors, screen, dash panel, bonnet, front wings etc etc. So I need to finish up any machining and modifying before I move forward with the rear bodywork and cab. Having changed the distance between centres of the static windscreen hinges I knew I had to move the hinges on the windscreen itself. So I decided to have a go at making a hinge that looks a bit more life like. It has to have a crank in it and it was a real head scratcher to get it bent up. I'm happy with the result so far and I'm playing with a new steering group wheel support now. 1 3 Share this post Link to post Share on other sites
ebinmaine 76,470 #103 Posted December 29, 2024 @Mickwhitt I'm really enjoying watching all the mini projects that are part of the whole assembly here. Excellent work and I appreciate you posting it. 1 Share this post Link to post Share on other sites
Wayne0 1,435 #104 Posted December 29, 2024 This is like watching the @cleat Work Horse restoration, only MORE detailed. Awesome build!! Great job, Mick. 3 Share this post Link to post Share on other sites
Mickwhitt 5,250 #105 Posted December 29, 2024 Thank you guys, it's nice to hear that my fumblings are appreciated lol. Curiously I've just been looking at a conversation on a model engineering forum over here. A member said he was leaving because the forum was a waste of time and he could find better ones. Part of the problem seems to be that no matter what you ask or show there are always negative comments or criticism. It's like there are a lot of members who rejoice in showing how clever they are and love to belittle the efforts of those they consider to be beneath them. For example I posted a photo of part of my Landrover build and all I got from one guy was "You do realise it should have hexagon head bolts, not allen head? It spoils the look of it" This was about a 2mm bolt which you hardly see. It's no wonder people don't want to get involved when they come up against that kind of attitude. When I went to join a model engineering club near me the first thing out of the secretaries mouth was how much the subs were and they had to be paid before I could attend, the second thing was could I grab a shovel and wheelbarrow to move tons of ballast around to repair their rail track bed. Nothing about model making, just provide muscle so they could drive their toy trains! Lol. I've never had that kind of comment or attitude from anyone on Red Square, only help, advice and encouragement, even when asking daft questions. Here we have a laugh and joke and also provide a great place to chat about anything from Wheelhorse to workshops. Thank you to all the guys and girls who make Red Square a safe and happy place to chill out and talk tractors. Mick. 7 Share this post Link to post Share on other sites
8ntruck 8,467 #106 Posted December 30, 2024 All very valid observations about clubs and forums. I agree completely with your conclusions. I spent the last half of my carreer as a press tooling engineer. I find metal forming facinating - 1/2 science, the other half art. I know how I'd put that crank in the fullsize windshield in a production tool. Just curious - how did you do it for your pieces- one right hand, one left hand? 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #107 Posted December 30, 2024 11 hours ago, 8ntruck said: Just curious - how did you do it for your pieces- one right hand, one left hand? Hi, Wow a press tool guy who knows the ropes! Great to hear from you. I looked at the original window hinges and saw the crank in the upper arms. I guess it was done primarily to make the upper hinge fit between the fixed lower hinges properly. But also it may have added some stiffness or strength to a part that would have just been a flat plate. I made a template in tin plate and practised bending it to get the left and right sorted in my head. Then made actual pieces from 2mm thick steel sheet. The bending was done by gripping the part in a plain jaw vice and using a blunt chisel to put the two bends in , very close together. To do it properly I'd have needed to make a press tool but for just a couple of pieces it wasn't worth doing. Thanks for showing such interest in my work. I enjoy sharing it as much as I enjoy doing it. Best regards, Mick 2 Share this post Link to post Share on other sites
Mickwhitt 5,250 #108 Posted January 9, 2025 Bit more work on the Landy, after a few bits of tool work. These are little parts dishes that I made, aluminium turned with a magnet let into the outside of the base so they retain small parts. Then I made new bolts for the windscreen hinges. Rather than use a set screw I made little shouldered bolts with castellated nuts. Just made in brass with some scrap steel sheet to see how they look. Mick 1 3 Share this post Link to post Share on other sites
Mickwhitt 5,250 #109 Posted January 12, 2025 I managed to make the hinge bolts and nuts in steel. A bit more of a faffing than in soft brass. But it's worth it to improve on the kit. I cross drilled the bolt at 1mm to take a split pin. Talk about miniature work. I'm also building up the front wings and firewall as a unit so I can attach it to the chassis when it has been painted. It's about working out how to do the build so that I can paint the bodyshell without too much masking of the chassis. 1 2 Share this post Link to post Share on other sites
Mickwhitt 5,250 #110 Posted January 17, 2025 The steel windscreen supports are just plain steel so I sanded and lacquered them ready to fit. The bonnet latches are an issue, four of them needed: two for the bonnet and two to hold down the folded screen. I looked at ready made ones which are cast white metal. But I wasn't too keen on the look of them. So it was "Let's see how on earth I go about making these things" time. I thought about turning a button shape in brass and filing the shape, but that was a real faffing about job. So I used some soft brass plate to shape a flat version of the handle, then sliver soldered a 4mm shank onto it. I made a domed jig to bend the lobes and hook over. Then turn a steel body and drill for the hook end. Eh voilà: ----- Just the top and bottom bracket parts to fabricate now. 1 1 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #111 Posted January 18, 2025 I finished the prototype hood catch today, top and bottom brackets. I think it looks neat, apparently the catch is an American design from the Jeep. 1 3 Share this post Link to post Share on other sites
8ntruck 8,467 #112 Posted January 19, 2025 Yup. Used on Jeep CJ series well into the 80's. I think I read somewhere that the prototype Land Rover was built on a surplus WW 2 Jeep chassis. 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #113 Posted January 19, 2025 3 hours ago, 8ntruck said: Yup. Used on Jeep CJ series well into the 80's. I think I read somewhere that the prototype Land Rover was built on a surplus WW 2 Jeep chassis. You are right, just after WW2 Maurice Wilks (MCW), who was one of the managers of the Rover motor car company, bought a nice house with plenty of land and a long private driveway to the main road. In 1947 there was a severe winter and his drive was totally blocked by snow. He parked his private car on the road and borrowed his neighbours toy; a Jeep he had bought surplus after the war ended. This made light work of the rough, frozen track to his home. The Jeep went home and MCW faced a new problem for the owner of a country property. A storm that year brought down a load of large trees on the driveway, being middle class and pretty wealthy MCW came up with a novel solution, buying a a war surplus tracked vehicle to drag the trees from his drive I would have just loved to have lived back then! The bren carrier worked brilliantly but when the job was done it became a white elephant as it couldn't be driven on the roads. So MCW swapped it with his neighbour for the Jeep and a circular saw to cut up all the trees that had fallen on his land. So the owner of Rover cars now had a 4x4 Jeep To play with. His brother (also business partner) had a holiday home in Scotland and he had his Rover saloon car suspension raised to allow him to drive across the moors when shooting. His gamekeeper was not impressed seeing a huge saloon car trundle across his grousemoor, so he suggested that SC needed a proper Land Rover which would look more suitable. That's the first time those two words were sat together, and it started the most amazing development of a motor vehicle ever seen. The brothers used the MCWs Willys Jeep chassis to design a British 4x4 vehicle. Replacing the bodywork they wanted to build a truly versatile vehicle that would allow a farmer to plow his fields with it and then drive it into town to see the bank manager. Remember, it was just after the war and farms doubled in size to boost food production, so farmers were big business back then. The result of their first effort was a single seat, centre steer vehicle. Very much like the tractor they were trying to force into being a road vehicle. They built just the one, making things up as they went, the engineers at Rover building what they thought was right. But it wasn't practical so a rethink was needed. That's when the boxy, practical, powerful 4x4 Landrover was born. The most versatile vehicle in the world. With models that spanned every use, from fire fighting, to welding rigs, to crops spraying to carrying the Queen on official engagements, (as well as being her own private vehicle she drove on her country estates). Landrover is still with us 80 years later, very different to when Rover ran the show and owned by foreign companies. But the original vehicles are still going strong, including HUE 166 the first ever prototype model and JUE 477, the first ever production vehicle that was sold. The Jeep is still in there in spirit, it's ability to go anywhere and do anything, but the Landy is a British masterpiece of engineering and marketing. Made to be affordable and practical it was the Volkswagen of Britain, ok not affordable to everyone. But you get the idea. Hear endeth the lesson, lol. 2 1 Share this post Link to post Share on other sites
Wayne0 1,435 #114 Posted January 19, 2025 Great story! 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #115 Posted January 19, 2025 Bought some new needle files today. Lots of filing work on the Landy so I need some new ones. Chap in Greece is selling off some jewellery tools and had brand new boxed sets of vallorbe files which were very cheap, even with postage. I started prepping the materials for the bonnet catches, making up four identical kits of parts so they look right. The prototype I will use to show how they were developed if I enter any competitions. Mick. 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #116 Posted January 25, 2025 (edited) So a day in the shop saw me make a full set of four new hood catches. I leaned a lot from making the prototype and was able to speed up the process. I made them a bit smaller too and they look good, well they all look similar which is what I needed. Painting the finished model is my main worry at this stage. I've never looked at such a complicated project in detail so I'm going to do some research. I bought an excellent book called How (not) to paint a locomotive. It's a model engineers bible for how to approach painting. The guy who wrote it spent six years making and building a working steam loco before tackling the paint job. He had to strip it down completely to paint and rebuild it as he went. It took him two more years to do that! He let's you in on all the pitfalls and errors he encountered along the way. I've only scan read it so far but it's really opened my eyes. More reading and a lot more work to do before I need to start spraying. Mick Edited January 25, 2025 by Mickwhitt Forgot pickchas 2 2 Share this post Link to post Share on other sites
ebinmaine 76,470 #117 Posted January 26, 2025 13 hours ago, Mickwhitt said: More reading and a lot more work to do before I need to start spraying. A good body shop tech told me decades ago that "painting" is approximately 95 to 99% NOT painting. IE, prep work is nearly everything. They used to practice and teach on bent crashed ruined body panels. Another good tool is a paint can. That round surface can be tough to master for some. 2 Share this post Link to post Share on other sites
Mickwhitt 5,250 #118 Posted January 30, 2025 Lots of shop tidying but managed to make a spare wheel mount for the bonnet. Originally the spare was in the back taking up room in the load bay. When that room was needed for payload or other body shapes they stuck the spare on the bonnet. The wheel rim clamps down onto three thin wooden packing pieces riveted to the bonnet. 1 Share this post Link to post Share on other sites
stvski80085 278 #119 Posted January 30, 2025 Very cool. I am also into rc planes, buggy's, and tanks. Just not this level of detail. I break and fix basically. Awesome hobby though. Steve 2 Share this post Link to post Share on other sites
Mickwhitt 5,250 #120 Posted February 2, 2025 May have mentioned this elsewhere, but it bears repeating. I learned that tinned paint can form a skin if its left standing, even with the lid on. If you can keep it moving then the skin doesn't form and the paint stays mixed and ready to use. So some kind of machine to tumble paint cans was needed. The guy in my new paint book gave me an idea for the basic design. Today I machined something that seems to work. It will handle tins from 50ml to 5 litres. 20250202_183153.mp4 1 1 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #121 Posted February 6, 2025 Back to the actual build instead of messing about making paint mixers etc. The tailgate is too simple to look realistic so I'm trying to increase the detail. The hinges are wrong and so I started out fashioning new strap hinges from 1mm thick steel. There were no stiffening ribs at each side of the tailgate so I made some from brass bar and next come some thin strips of steel to mimic the section of steel on these ribs. The work so far... 2 Share this post Link to post Share on other sites
oliver2-44 11,136 #122 Posted February 7, 2025 Amazing. How are you cutting/ shearing these small metal strips? Share this post Link to post Share on other sites
Mickwhitt 5,250 #123 Posted February 7, 2025 I have a small bench mounted shear for straight cuts. The L shaped hinges were cut out and filed to shape, my fingers are raw lol. Sheet metal is not my forte but needs to be done on this model. I've just found the price details for the newly released Challenger tank model... All up with sound, motion, recoil etc you are looking at almost $10,000! Plus consumable and batteries. That makes it too rich for a hobby project for me, just can't justify that level of investment. Especially now that our government seem intent on crashing the economy and we are headed for financial armageddon. Share this post Link to post Share on other sites
Mickwhitt 5,250 #124 Posted February 11, 2025 So, despite a possible global meltdown, the build continues lol. I made progress on the hinges and got the fitted to the chassis. They actually work now and the tailgate detaches in the same way as the full size landrover, drop it fully down and slide to the left. I'm just messing around filling the holes that are no longer needed and sorting some of the rivets. Hardest part is letting the adhesives dry in between jobs, I'm not that patient lol. I'm loving the project so far, I knew it would take me a long time and I'm comfortable with the build time. I've not put full working days in and had quite a few other bits and bobs to do as well. So it's not been too bad. 1 Share this post Link to post Share on other sites
Mickwhitt 5,250 #125 Posted February 15, 2025 While fittingbthe cab floor I got sidetracked again. There are foot pedals, gear levers, but no handbrake. So I decided to add one. It was going to be a fixed rod but I got distracted and ended up building a working lever with a sprung detent to allow the lever to hold in the up or down position. And I just had to make the little release button work, didn't I? The unit bolts onto the kick plate beneath the drivers seat. It looks pretty neat but will probably never be moved. 1 1 Share this post Link to post Share on other sites
