Treepep 681 #1 Posted January 10, 2024 So, I got this old roto Spader with a mixed lot of Briggs parts I wanted. I am finally getting around to taking this apart. I have numbers from the tins but I am not finding parts. I believe it to be a craftsman/sears/maybe even David Bradley as well. Trans is DB I think. Any help would be greatly appreciated Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,460 #2 Posted January 10, 2024 What numbers do you have? 1 Share this post Link to post Share on other sites
Treepep 681 #3 Posted January 11, 2024 19 hours ago, gwest_ca said: What numbers do you have? Numbers on the motor are... 143177032 6284 05501 Share this post Link to post Share on other sites
Treepep 681 #4 Posted January 13, 2024 So... I am having difficulty removing the flywheel. No puller I own would come close to reaching. Any thoughts would be appreciated. Not an expert however all of the older sears roto spaders i have found are briggs. This is not. Odd... to me and my limited knowledge. A few websites I utilize for small engine parts come up with exploded diagrams and no available parts. The motor is a craftsman I think although a lot of the obsolete numbers cross over with Tecumseh parts so I do not know??? The tiller is a David Bradley I believe. seems to be solid. Just cast numbers I do not follow instead of the usual DB badge starting with 917. I may just re power down the road. I have several antique tillers that are awesome. Share this post Link to post Share on other sites
953 nut 59,876 #5 Posted January 13, 2024 A Harmonic Balancer puller is what you need for flywheel removal. You can borrow them from most auto parts stores. 1 Share this post Link to post Share on other sites
lynnmor 7,812 #6 Posted January 13, 2024 Till a few years ago I had a Sears tiller that looked the same. The Tecumseh engine died and I replaced it with a Briggs. The reverse was always troublesome so I removed it, the parts might still be around here. Share this post Link to post Share on other sites
Treepep 681 #7 Posted January 14, 2024 On 1/13/2024 at 9:47 AM, lynnmor said: Till a few years ago I had a Sears tiller that looked the same. The Tecumseh engine died and I replaced it with a Briggs. The reverse was always troublesome so I removed it, the parts might still be around here. Yeah. It may be just that. Straightforward however I have not seen a setup like this one. I removed the motor to continue with my repairs. Busted a fin on the flywheel in the process. Rewound the recoil starter without blood or cussing though so... Win I guess. I will keep looking for parts. Thank you! Share this post Link to post Share on other sites
