pfrederi 21,051 #1 Posted November 12, 2023 I have a C-175 that has a gray series 2 KT-17. The spec # is 24336 which was made for WH. I assume for dealers to use as replacements for failed Series 1. Has anyone here run across one?? Share this post Link to post Share on other sites
RED-Z06 2,720 #2 Posted November 13, 2023 Most K long blocks and complete replacement engines ive seen were grey, makes sense the KT would be also. Its rare to see KTs anymore, of either series. Share this post Link to post Share on other sites
Bill D 3,101 #3 Posted November 13, 2023 @Brockport Bill has one in one of his C-175's. Share this post Link to post Share on other sites
Brockport Bill 2,455 #4 Posted November 13, 2023 13 hours ago, pfrederi said: I have a C-175 that has a gray series 2 KT-17. The spec # is 24336 which was made for WH. I assume for dealers to use as replacements for failed Series 1. Has anyone here run across one?? i have a C175h with a Series 1 engine that's 1983 model #01-17ke03 # 26795 with black engine KT17s # 24223 ---- Also have a C175h with Series 2 Gray engine that's 1984 model 11-17ke01 #28385 #3299 .... However, the Series 2 engine did not have tins on it when I acquired it therefore no engine I.D. number -- I believe the Series 2 engine spec is #24323... I have notes in my file that Series 2 are spec # 24300 or higher so that would include your # 24336 ???????????? the photo below has design that apparently indicates Series 2 -- Also note the Gray engine color ------- Bill 2 Share this post Link to post Share on other sites
johnnymag3 2,647 #5 Posted November 13, 2023 I also have a KT17 on my 417 A. Its a series 2, but it is black, and original.. The Series 2 is sort of a M18,,,,, No points or coil. I have had Zero isuues with mine. Very strong, sounds very distinct as a twin. John Share this post Link to post Share on other sites
Brockport Bill 2,455 #6 Posted November 13, 2023 7 hours ago, johnnymag3 said: I also have a KT17 on my 417 A. Its a series 2, but it is black, and original.. The Series 2 is sort of a M18,,,,, No points or coil. I have had Zero isuues with mine. Very strong, sounds very distinct as a twin. John love that sound of the Kohler twin Share this post Link to post Share on other sites
Bill D 3,101 #7 Posted November 13, 2023 I kinda miss mine, but something had to go. Onans are nice, but the sound just isn't the same. Share this post Link to post Share on other sites
pfrederi 21,051 #8 Posted November 14, 2023 I think by the time of 417s they used new spec Series 2 1 Share this post Link to post Share on other sites
bds1984 1,516 #9 Posted November 15, 2023 I had one. Here is the thread for it where I installed an oil filter and pressure gauge. The engine had crazy oil pressure and started insanely quick. That machine was the second machine I wish I wouldn't have sold (first was a 1984 C195). With all the good of the engine, the fuel pump was weak so I installed a vacuum pump like newer engines had. Great engine and a snarly exhaust note. Share this post Link to post Share on other sites
c-series don 12,363 #10 Posted November 16, 2023 I have a series 2 on my 417-A, with a 2 stage snow blower on it. It deep snow under a load it sounds awesome! 1 Share this post Link to post Share on other sites
Brockport Bill 2,455 #11 Posted November 16, 2023 3 hours ago, c-series don said: I have a series 2 on my 417-A, with a 2 stage snow blower on it. It deep snow under a load it sounds awesome! Yikes Don - I didn't think Long Island got that many snow storms that deep? That looks nasty!! 1 Share this post Link to post Share on other sites
Bill D 3,101 #12 Posted November 16, 2023 13 hours ago, bds1984 said: I had one. Here is the thread for it where I installed an oil filter and pressure gauge. The engine had crazy oil pressure and started insanely quick. That machine was the second machine I wish I wouldn't have sold (first was a 1984 C195). With all the good of the engine, the fuel pump was weak so I installed a vacuum pump like newer engines had. Great engine and a snarly exhaust note. Perfect description of the KT 17. I made the same fuel pump mod. Best mod you can do to that engine in my opinion. Share this post Link to post Share on other sites
