Colby G 248 #51 Posted November 25, 2023 8 minutes ago, ebinmaine said: Looks like it might but did you check with our own vendors? Brian Badman. Lincoln at A to Z. I couldn't figure out how to get onto the store. Share this post Link to post Share on other sites
pfrederi 21,047 #52 Posted November 25, 2023 17 minutes ago, Colby G said: Would this work for a 1969 hydro charger 12? I ask this question because it says it for a 1970 hydro 12 It will work Share this post Link to post Share on other sites
pfrederi 21,047 #53 Posted November 25, 2023 17 minutes ago, Colby G said: Would this work for a 1969 hydro charger 12? I ask this question because it says it for a 1970 hydro 12 It will work Share this post Link to post Share on other sites
ebinmaine 80,281 #54 Posted November 25, 2023 16 minutes ago, Colby G said: I couldn't figure out how to get onto the store. For Brian Badman you can "mention" his handle @76c12091520h Or send him a PM. For Lincoln you want to look in the vendors section. Get his phone number. CALL him. Don't text. Don't email. Use your old fashioned voice function. 1 Share this post Link to post Share on other sites
Colby G 248 #55 Posted December 14, 2023 So after doing the transmission swap and buying a transaxle input pulley, I figured out the transmission isn't from a charger 12... Could someone tell me what tractor it came off of so I can get the right pulley? I'm thinking it's a gt-14 Share this post Link to post Share on other sites
Colby G 248 #56 Posted December 16, 2023 If the transmission I put in the charger 12 is from a gt-14, could a 13hp engine power the 14hp hydro? If not, could I fit a 16.5hp twin under the hood of the charger 12? Share this post Link to post Share on other sites
pfrederi 21,047 #57 Posted December 16, 2023 (edited) The Sunstrand hydro unit WH used was the same for 10 12 14 18 and 20 horsepower just some external linkage difference and later ones were piston to piston instead of Hydro gear but all could handle the various HPs. Edited December 16, 2023 by pfrederi Share this post Link to post Share on other sites
Colby G 248 #58 Posted December 16, 2023 49 minutes ago, pfrederi said: The Sunstrand hydro unit WH used was the same for 10 12 14 18 and 20 horsepower just some external linkage difference and later ones were piston to piston instead of Hydro gear but all could handle the various HPs. Thank you so much! I couldn't find this info anywhere! Share this post Link to post Share on other sites
daveoman1966 3,884 #59 Posted December 17, 2023 This pump shaft wants a pulley with a FLAT side...maybe even an older 'Double D' style pulley. I don't think the pulley shown above is right for this pump shaft....as it uses a Woodruff KEY WAY SLOT. To me, these are NOT compatible. Share this post Link to post Share on other sites
Colby G 248 #60 Posted December 17, 2023 8 hours ago, daveoman1966 said: This pump shaft wants a pulley with a FLAT side...maybe even an older 'Double D' style pulley. I don't think the pulley shown above is right for this pump shaft....as it uses a Woodruff KEY WAY SLOT. To me, these are NOT compatible. Could you give me any info on which tractor it came from originally? I did a transmission swap and I can't figure out what tractor it came from. I think it's off of a gt-14 tho... Share this post Link to post Share on other sites
daveoman1966 3,884 #61 Posted December 17, 2023 10 minutes ago, Colby G said: Could you give me any info on which tractor it came from originally? I did a transmission swap and I can't figure out what tractor it came from. I think it's off of a gt-14 tho... The pulley you show with the KEYWAY slot does appear to match part # 7446.... the Electro 12 1-7251. I can't find the pulley that would fit the flat-sided shaft of the pump you've posted. Share this post Link to post Share on other sites
pfrederi 21,047 #62 Posted December 17, 2023 21 minutes ago, daveoman1966 said: The pulley you show with the KEYWAY slot does appear to match part # 7446.... the Electro 12 1-7251. I can't find the pulley that would fit the flat-sided shaft of the pump you've posted. GT-14 used pulley #8144 but the only picture I could find showed a round bore with keyway 1 Share this post Link to post Share on other sites
gt14rider 1,278 #63 Posted December 18, 2023 The transmission 90 2062 was only used on the GT14. From what I've found there was three different pulleys,1st was round with keyway, 2nd double D and 3rd was splined i can only find 2 p/n# 1 Share this post Link to post Share on other sites
gt14rider 1,278 #64 Posted December 19, 2023 @Colby G there should be a tag on the finned housing. The tool box is in the way. If you can read the numbers you know what transmission you have. Share this post Link to post Share on other sites
gt14rider 1,278 #65 Posted December 19, 2023 There's one one ebay , 100244, double pulley Share this post Link to post Share on other sites
gt14rider 1,278 #66 Posted December 19, 2023 There is another # for a double D double pulley, 100434. 1 Share this post Link to post Share on other sites
pfrederi 21,047 #67 Posted December 19, 2023 44 minutes ago, gt14rider said: There is another # for a double D double pulley, 100434. This number appears to have a round shaft hole with key way Didn't realize WH used that many different pulleys on GT-14 Share this post Link to post Share on other sites
Colby G 248 #68 Posted December 19, 2023 That pulley is pricey, but if that's what I need I will defenetly buy it. Are you sure that's what I need? That's a transaxle input pulley, right? Looks like a dual pulley. Share this post Link to post Share on other sites
pfrederi 21,047 #69 Posted December 19, 2023 The outer smaller pulley was used to run the roto-tiller attachment Share this post Link to post Share on other sites
Colby G 248 #70 Posted December 19, 2023 13 minutes ago, pfrederi said: The outer smaller pulley was used to run the roto-tiller attachment So that's the one I need for sure? Share this post Link to post Share on other sites
rjg854 13,310 #71 Posted December 19, 2023 @daveoman1966 any comments for Colby Share this post Link to post Share on other sites
gt14rider 1,278 #72 Posted December 19, 2023 That pulley will fit a gt14. Share this post Link to post Share on other sites
Colby G 248 #73 Posted December 20, 2023 13 minutes ago, gt14rider said: That pulley will fit a gt14. But I'm not sure if it's a gt-14 tho. I have posted pictures for reference earlier in the conversation Share this post Link to post Share on other sites
gt14rider 1,278 #74 Posted December 20, 2023 There is a Id# on small cover, you may have to remove the tool box to read it.with out that # it's hard to tell. Are your axles 1 1/8 ? Take off hubs how big are the keyway in the axle. If thay are chance's are it's a gt14. Share this post Link to post Share on other sites
Colby G 248 #75 Posted December 20, 2023 Found an id# on small cover looks like the numbers read 90-2070 for model number serial number is 32089 Share this post Link to post Share on other sites
