kpinnc
My 701 saga
AlexR
52 minutes ago, kpinnc said:
This bleeping hood is gonna drive me to drinking. But I think it's almost ready to paint.
...Almost. :rolleyes:
Little dings and stuff all over it. Two holes drilled for headlights by somebody and the bottom of the tombstone had to be completely rebuilt.
Almost... :lol:
As long as I had spent on my hood, after I painted it, I wished I had spent just a little more time on it.
  • Like 5
ebinmaine
Seconded
kpinnc
Posted (edited)
14 hours ago, ebinmaine said:
Seconded
Well this hood has been primer coated about 5 times, each after finding another ding to tap out and fix. Actually got another coat today. But it looks pretty good right now. I'll go over it tomorrow with 800 grit and scope it over once more.
And I've made up my mind on the fuel pump. Now I have to figure out where to put the thing. Not alot of room on a 701 to hide an electric pump...
Edited by kpinnc
  • Like 5
  • Excellent 4
WHX??
Then don't I'll send you a orginal.
Signed
The Purist.
  • Haha 6
kpinnc
Signed
The Purist.
I would stick with original if I could get a rebuild kit. My luck must be bad and I got tired of waiting. :rolleyes:
WHX??
What kind is the orginal? Vacuum? The style with the off set lever? I hoard them i can look see what I have.
sqrlgtr
kp, I rebuilt the one on my 701 with a kit from thenandnow, it was the vacuum style (no Lever). BTW I didn't go back and reread whole thread so I may have already mentioned this before.
kpinnc
Posted (edited)
This is what came off of it. I'm not opposed to a pulse style either. I've just not had any luck with the then and now vendor for a kit.
Edited by kpinnc
kpinnc
3 hours ago, sqrlgtr said:
thenandnow
Spoke with someone first time I called, emailed pics with no response. Called back for two weeks and got voicemail. Left messages and emailed again several times. No response.
  • Sad 1
sqrlgtr
Posted (edited)
wow never had any trouble getting a hold of anyone. I talked to a female a couple times and she was very knowledgeable and help full, I hate that you are having so much trouble. Here is a pic of the kit I got from them for the Vacuum style pump. I couldnt find a pic of pump after repair but it did have the priming lever on it like the one you have pictured.
Edited by sqrlgtr
sqrlgtr
Posted (edited)
ya know I may have my pumps mixed up and the vacuum may have came off the 856. I rebuilt 3 in a row ( 701,856, and c160)and every one of them where a different style :D.
Edited by sqrlgtr
Handy Don
36 minutes ago, kpinnc said:
I'll be happy to take that piece of junk (with the quite desirable priming lever) off your hands! Send it on by mail (I’ll reimburse the postage) or to the Show with @953 nut!
WHX??
I rebuilt a lot of them and never had to order a then now. Diaphragm in the jungle is about it. Always thought the then ones were a little pricey for what you get and yes I can be a cheap bastage.
They gotta be really bad not to be able to save.
https://www.amazon.com/dp/B0F1XYDS4B?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5
Yours looks excellent Ken.
kpinnc
I ordered one. We'll see how it goes. Mine has all kinds of internal shenanigans with that primer lever.
Yeah it's already cleaned up. :lol:
Big blog of gunk when I removed it.
WHX??
Posted (edited)
Lemme know you need help. Did I mention I hoard them... :lol:
I got one or three of them but none with
the offset cam lever. I bet the bodies interchange.
I gotta get off my @$$ and do that pump tutorial one of these days. :D
Edited by WHX??
  • Excellent 2
sqrlgtr
Big J is right if all u need is diaphragm go with jungle but thenandnow is only place I know u can get everything else. The ones I rebuilt were full of trash and was causing me problems with keeping carbs clean even after new fuel lines and cleaning tanks out. It was like half of old fuel lines was in there, little black granuals of junk.:angry-banghead::angry-cussingblack:.
kpinnc
All those parts are in mine as well.
For two or three weeks they were only taking calls on Monday and Friday, and instructed buyers to email.
I may try again at some point but it was holding everything up and I got tired of waiting.
  • Sad 1
kpinnc
Signed
The Purist.
Ok, I got a jungle site kit from your link and installed it. The fit was pretty awful but once all closed up it does pump pretty strong. I'll install it once the paint dries. Once completed, I can finally test run the rebuilt K161. Fingers crossed, prayers sent. :rolleyes:
And though I am definitely NOT a purist (got nothing against it, but nothing down here isn't butchered), I am happy with this particular machine being at least close to what it should be.
I'll save the electric for the Vanguard that goes on the black hood...
  • Excellent 2
kpinnc
This tiny product of unmarried parents better work and not leak. What a pain!
  • Haha 6
ebinmaine
:ROTF::ROTF::ROTF:
ineedanother
Many years ago I restored and worked tractors of another color from the '60s with steel fuel tanks and those same parts. I dreaded seeing debris or water in that sediment bowl and having to decide whether or not I wanted to poke that bear.
  • Haha 3
kpinnc
If mine clogs or leaks, it will simply go away in favor of an inline filter. I figured I'd give it a run and see what happens.
I just figured this tractor should be restored as close as I can to original. Lots of stuff already has been changed. Hopefully it won't stand out too much.
Tomorrow is final engine assembly. Electrical is pretty much done. Secondary tins are painted and ready to go. I'm hoping to see if all the time and money I've put in this engine was worth it... Governor and fuel pump and a few odds and ends are all that is left.
We shall see! :rolleyes:
  • Excellent 2
rmaynard
On 4/13/2025 at 12:19 AM, kpinnc said:
Eastwood also has a 2K clear with the hardener release on the bottom of the can. It would be interesting to get a can of both and compare ingredients...
So many products nowadays are just re-badged from one company to the other. Might be worth a look...
Sorry that I am a little late to the dance, but I have spoken with the area technical rep for SprayMax. They make the Eastwood clear coat.
squonk
Sediment Bowl in French is "Gas Leak"
If I had a dollar for every sediment bowl gasket I sold at Napa, I could buy @WHX?? about 5 gallons of diesel fuel!
  • Haha 4
kpinnc
Went ahead and applied the first coat on the hood... probably gonna do about 3 coats.
  • Excellent 3
