kpinnc
My 701 saga
kpinnc
Posted (edited)
20 minutes ago, WHX?? said:
have no idea why :wh: went this route. It's been said this same solenoid was used on some truck sno plow set ups.
Pretty sure my solenoid is operated by +12VDC. No biggie. Just looked wrong. I learned something new! :thumbs:
So can I run the wire from the middle tab (GEN) directly back to the positive side of the battery?
The pic below is a Kohler manual. Just has a meter in series between the center tab and positive terminal.
Edited by kpinnc
WHX??
Yep if your not going to have a ammeter.
Double check what solenoid you have. Hate to see you let any magic smoke out.
kpinnc
Yep me too.
ebinmaine
5 hours ago, 702854boy said:
Mine already looks like that because every wire except the 6 gauge positive battery cables are black
I am NOT a fan of that.
Wheelhorse originally used all one color to save money on the build.
I understand that. And I thoroughly disagree with the idea. Just adding one color would have added minimal cost and made future diagnostics and repairs much easier.
In the world of 12 volt negative ground, red is hot, black is ground. ...to start with. Then other hot colors for other circuits can be added.
I use a section of  7 conductor trailer wire to begin making my harnesses.
ebinmaine
That's interesting. I never knew that having a solenoid was an OE idea.
ebinmaine
I've read & been told that most older jeep and ford 3 terminal solenoids work.
I'm not prone to using light weight modern stuff so I use a very heavy duty Cole Hersee industrial type solenoid.
A little more money ....  but worth it.
squonk
6 hours ago, WHX?? said:
I have no idea why :wh: went this route. It's been said this same solenoid was used on some truck sno plow set ups.
That style solenoid was mainly used to keep amp draw on the activating control to a minimum for continuous duty applications like snow plows and electric actuators.
ebinmaine
When did they start going this route?
squonk
Way back when.  Saw them on my 60's Jeeps
WHX??
Posted (edited)
I see ... I think ... so the amp draw is only on the internal connection between the large post and the small one on the solenoid. Not thru the start button.
Be care when working with the dash plate KP. use mounting screws with small heads. They can break the plate at the corners on the bottom if too big. I used the original ammeter just for old skool look.
Tom @Shynon was playing with making aluminum plates on his milling machine. Don't know if he perfected that yet or not.
Edited by WHX??
  • Like 4
squonk
Yup. The switch is just carrying the amperage for the solenoid coil which is probably around half an amp
kpinnc
Cracked mine months ago. Already glued. We will see what happens. Thinking of using allen head cap screws if I can find them.
Handy Don
Posted (edited)
3 hours ago, WHX?? said:
Possible blasphemy here, but coating the plastic dash with a suitable paint would go a long way toward reducing deterioration from UV.
Edited by Handy Don
Shynon
3d printed and aluminum.
  • Excellent 5
ebinmaine
Contact Bolt Depot in Hingham MA
WHX??
Better than what I coulda done. :thumbs2:
  • Like 5
kpinnc
Trust me everything looks better on the internet... :lol:
  • Haha 5
ebinmaine
:text-yeahthat:
Mebbe so but it looks great from Maine.
  • Like 6
MainelyWheelhorse
If it’s going to be a worker and not a showpiece I’d run it as is. Then, if it gets bumped or banged it won’t spike your blood pressure. 🙂
kpinnc
Well all the repairs line up and it all fits. Rear fenders and main beltguard to go and then paint.
  • Excellent 5
ebinmaine
9 hours ago, kpinnc said:
I have looked for several days for my generator belt brackets. So I just made a set.
:handgestures-thumbupright:
Nice!
electric fuel pump.
I'd recommend it.
Given that a quality rebuild kit is nearly the price of an electric pump, I might not rebuild another mechanical.
I would use a known good brand like:
Facet 60245 or 60304.
Mr. Gasket 42s.
Carter P4070.
Aircraft Spruce Company sells the Facet pumps, good quality pop in and screw type tank valves, and grommets.
kpinnc
Posted (edited)
This bleeping hood is gonna drive me to drinking. But I think it's almost ready to paint.
...Almost. :rolleyes:
Little dings and stuff all over it. Two holes drilled for headlights by somebody and the bottom of the tombstone had to be completely rebuilt.
Almost... :lol:
Edited by kpinnc
  • Excellent 3
squonk
Tractors are supposed to have dents and dings in the hood. :twocents-twocents:
  • Haha 1
