Donavon
What is the heaviest model wheel horse?
Donavon
Just curious what is the heaviest for a future project.
8ntruck
I'd guess it is one of the D series.  Those were sort of a precursor to the current mini tractors.
c-series don
The D-250 I’d say.
Rick3478
22 minutes ago, c-series don said:
The D-250 I’d say.
That was my first thought, but then I wondered what about the 520 aircraft tug?
kpinnc
My response to the question may ruffle feathers, but it's not my intention to offend. I'm also not a purist, but this is how my tiny brain works. :rolleyes:
The heaviest were (unless the senior owners can give bigger numbers) the DXI series, at just over 1100lbs. The GT-14 follows at nearly 900lbs.The D-250 was a rebadged German manufactured Gutbrod.
And... the D series machines were completely different from the traditional line of tractors that began with the RJ and ended with the last run of Classics in 2007. That entire line of tractors are similar from the ground up, and more of an evolution of a core design.
So- while D series tractors wore the name, at best they were offshoots that were intended to penetrate a different market while leveraging the WH reputation. The D-160, 180, and 200 were released after Wheel Horse sold to AMC. How much design work of them originating from Wheel Horse is not clearly defined. The transmission was about the only thing they had in common with other tractors of the period. The XI series machines are excellent tractors, while also almost 100 percent Toro creations. New Holland also sold rebadged XI models.
Almost no implement made for D series would work with the classic line. The same was true for the GT-14 and many XI series.
So MY "way too long" answer would be the heaviest Wheel Horse was the GT-14 at over 900lbs, then the C-195 at 740lbs, followed by the 520-H (also heavily influenced by Toro) at around 650lbs. Toro designed the later model 60 inch deck as well, so I can't include that if going by my own exclusions. If so, it would be an additional 300lbs. Maybe if the two stage snowblower was attached?
Edited by kpinnc
  • Excellent 2
ebinmaine
Along the lines of thinking about a heavy Wheelhorse my first question is,
For what?
What project?
What purpose?
ANY Wheelhorse can be made Heavy.
Add steel. Add fluid.
It's very easy to make a 70s C Series tip the scales at over 1000 lbs before any implements are installed.
ri702bill
Is that with or without The Bear....???  :laughing-rofl:
ebinmaine
No Bears included.
Add 260+.
BairleaFarm
10 hours ago, c-series don said:
The D-250 I’d say.
Wasnt the D250 not really a Wheel Horse but a GT made my renault that was branded Wheel horse?
953 nut
image.png.86e36702e2f438aebc1bc5040ea759d5.pngTake a GT-14, add a  front end loader with weight box, a York rake, WW93 wheel weights and liquid filled tires and you are up to about 1,800 pounds without the operator. Have @ebinmaine gat in the seat and you are over a ton of Wheel Horse fun.    :handgestures-thumbupright:
Edited by 953 nut
  • Haha 5
  • Heart 1
Rick3478
Speaking of AMC, wasn't there a WH branded Jeep?  Where did I see that?  Maybe it was just a one-off paint job for advertising.  My brain sometimes regurgitates useless information, too. :lol:
kpinnc
Add ME! :lol:
Yes you can nearly double the weight of these machines. Weights, fluids, heavy implements.
That's what I was concerned with my earlier post- often times reported weights come from a machine with an implement attached, rather than what I would call a "dry weight" with nothing added.
Lee1977
Then there are the electric battery powered tractors. Originally design and built by GE, Elec Trak E20 the largest having 3.5 electric motor ( equivalent to 14, later model clamed 16 gas HP ) 36 volts  85 amps with 6 -6 volt batters
850 lbs.
Edited by Lee1977
Thor27
Got me curious, so looked up some of the bigger horse weights on tractordata.
D-250  1160#
523dxi. 1150#
D-200.  1025#
C-185.   894#
GT-14.   875#
E-141.    825#
C-195.    740#
evanloock
As the D-series were based off the 18-Automatic introduced in 1973, I would say they are a Wheel Horse design.  As with every other new design I am sure it was on the engineer's drawing board a year or more before the production 18-Automatic was offered for sale.  The D-250 is definitely not a "true" Wheel Horse.  RS-83/Senior flyer states that it weighed 810 pounds without ballast in the tires.
Edited by evanloock
Donavon
For what?
What project?
What purpose?
I'm wanting to make a custom wheel horse tandem axle tilt bed
ebinmaine
THAT would be neat.
If you're not looking for any particular shape or model,
IMHO...
Your best bet would be something quite common with great parts availability that isn't yet to the collectible stage.
The 300, 400 series are plentiful and just as rugged as any other past models.
19richie66
14 hours ago, ebinmaine said:
THAT would be neat.
IMHO...
Agreed. I would stay away from a D series if you plan to stretch it any without doing a serious drivetrain change. Don’t ask me how I know.:hide:
Edited by 19richie66
pfrederi
:text-yeahthat:
D 200 are not very nimble to start with... longer wheelbase will only make it worse....
kpinnc
10 hours ago, 19richie66 said:
The heaviest Wheelhorse ever made was the one that won’t start that you have to push by yourself so you can get to something in the back of the shed.
Don't forget the one with a flat tire when you have no way to pump it up! :P
  • Haha 2
Donavon
I am planning to stretch it, the biggest thing I would possibly haul on it would be my Dixie chopper
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
