Handy Don 17,474 #26 Posted December 24, 2025 Does it make more sense to brace against any possible impact or would hinges and springs be an alternative? Share this post Link to post Share on other sites
ebinmaine 80,717 #27 Posted December 24, 2025 1 hour ago, Handy Don said: Does it make more sense to brace against any possible impact or would hinges and springs be an alternative? TBH it could go either way. I like the idea of movability. How would we set up springs? They'd have to be VERY stout to hold the sides against the center while in use. The springs may (must?) be used as corner braces as well. Share this post Link to post Share on other sites
peter lena 10,065 #28 Posted December 25, 2025 @ebinmaine MERRY CHRISTMAS ! was thinking about your set up , commonality ? 4 wheels , just the ideas and possabilites , might help you out , pete 2 Share this post Link to post Share on other sites
peter lena 10,065 #29 Posted December 25, 2025 @ebinmaine MERRY CHRISTMAS ! was thinking about your set up , commonality ? 4 wheels , just the ideas and possabilites , might help you out , pete Share this post Link to post Share on other sites
peter lena 10,065 #30 Posted December 25, 2025 @Handy Don , MERRY CHRISTMAS ! rarely if ever look at a repetitive problem , with a single view , basically giving the failure point / area a chance to show it self , thats what I want in any failure point , what's amazing to me and a commonality in wheel horse , is that the original intent was only partially finished , experiment with every stage , it will show itself , then enhance that function . if you paint it red / black , it disappears , regularly respond to what I did , and have been using for years without issue , isn't that what you want ? that fuel issue , consistent debris , for me is years gone , as is related choke / throttle function , just a couple of regulars that show up . have a good day / family , pete 1 Share this post Link to post Share on other sites
Handy Don 17,474 #31 Posted December 25, 2025 17 hours ago, ebinmaine said: How would we set up springs? They'd have to be VERY stout to hold the sides against the center while in use. The springs may (must?) be used as corner braces as well. Half-baked thoughts (with a nod to our spit-ball friend @wallfish) To wit (and you can tell that my career involved setting the requirements for system designs that others had to build ) - Ultimately, for use on uneven terrain, either: * the plow with sides must be free to pitch forward or back (with a mechanism to prevent “droop” when the plow is lifted) and strong enough to withstand such movement, or * each side must be strong enough to lift the plow vertically over a impediment without damage * each side must be strong enough to withstand significant lateral force without damage or have some sort of hinged “release" If sides are sprung: - Sprung sides’ action must be stiff enough to prevent normal snow load from causing movement (adjustable tension?) - Spring action must work for inward movement (is outward movement optional or necessary?) - Should there be hard limits to motion in either direction and/or a “fail safe” break away mode? - The mechanism mustn’t accumulate snow easily that would impede its operation or affect plowing - The mechanism should not extend beyond the ends of the plow by more than a couple of inches - The mechanism, once tripped, should return to its normal operating configuration without manual intervention Sprung would be pretty complicated! 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,524 #32 Posted December 25, 2025 Maybe use an old plow blade cut to desired wing size and welded to main blade... put a ski style skid on the bottom and let it float... no durability worries with an old WH blade... Share this post Link to post Share on other sites
ebinmaine 80,717 #33 Posted December 25, 2025 2 hours ago, SylvanLakeWH said: Maybe use an old plow blade cut to desired wing size and welded to main blade... put a ski style skid on the bottom and let it float... no durability worries with an old WH blade... Can you please elaborate on that ? Share this post Link to post Share on other sites
ebinmaine 80,717 #34 Posted December 25, 2025 3 hours ago, Handy Don said: Half-baked thoughts (with a nod to our spit-ball friend @wallfish) To wit (and you can tell that my career involved setting the requirements for system designs that others had to build ) - Ultimately, for use on uneven terrain, either: * the plow with sides must be free to pitch forward or back (with a mechanism to prevent “droop” when the plow is lifted) and strong enough to withstand such movement, or * each side must be strong enough to lift the plow vertically over a impediment without damage * each side must be strong enough to withstand significant lateral force without damage or have some sort of hinged “release" If sides are sprung: - Sprung sides’ action must be stiff enough to prevent normal snow load from causing movement (adjustable tension?) - Spring action must work for inward movement (is outward movement optional or necessary?) - Should there be hard limits to motion in either direction and/or a “fail safe” break away mode? - The mechanism mustn’t accumulate snow easily that would impede its operation or affect plowing - The mechanism should not extend beyond the ends of the plow by more than a couple of inches - The mechanism, once tripped, should return to its normal operating configuration without manual intervention Sprung would be pretty complicated! A lot of good points there. I think the spring(s) would create too much complication. To the points... * the plow with sides must be free to pitch forward or back (with a mechanism to prevent “droop” when the plow is lifted) and strong enough to withstand such movement Agreed. I believe the stock Wheelhorse trip springs should be removed. * each side must be strong enough to lift the plow vertically over a impediment without damage I believe it will be once reinforced * each side must be strong enough to withstand significant lateral force without damage This is the most needed change. Overall twisting stability and angular side wing to plow blade anchoring is - at best - weak. Share this post Link to post Share on other sites
SylvanLakeWH 32,524 #35 Posted December 25, 2025 2 hours ago, ebinmaine said: Can you please elaborate on that ? Cut a WH blade into two 12-16" lengths. Weld as wings to standard blade 90 degrees out. The curved blade should be much more sturdy... 1 Share this post Link to post Share on other sites
ebinmaine 80,717 #36 Posted December 25, 2025 4 minutes ago, SylvanLakeWH said: Cut a WH blade into two 12-16" lengths. Weld as wings to standard blade 90 degrees out. The curved blade should be much more sturdy... Gotcha. Sound idea but unnecessary. The wings I have are quite sturdy. It's the attachment points that failed. And besides..... I'm saving a couple plow blades for a possible V ......... 1 Share this post Link to post Share on other sites
wallfish 20,618 #37 Posted December 26, 2025 8 hours ago, Handy Don said: Half-baked thoughts (with a nod to our spit-ball friend @wallfish) Ugh, thanks. ( I think) ) LOL Might as well spit ball one then! Personally I would do the wings on a 45 deg angle from the main blade and made with pieces of an old blade. Welded on with additional supports. This way the blade could still be used on an angle to move snow to one side or the other and also be used as a pusher to collect larger amounts vs a straight blade. Or even more complicated by making them adjust from flat to a 45 angle. 3 Share this post Link to post Share on other sites
JoeM 10,268 #38 Posted January 4 Not much help but check out the pusher blade on the skid steer at the end of this short. Ultimate set up ? 4 Share this post Link to post Share on other sites
ebinmaine 80,717 #39 Posted January 4 1 hour ago, JoeM said: out the pusher blade That'd be neat. Share this post Link to post Share on other sites
ebinmaine 80,717 #40 Posted January 7 More "testing" today. Really like this setup. A. Thank you @JoeM for sending the side scoops here! B. I'm thinking seriously about expanding the width of the straight plow. Maybe as much as 60". 1 3 Share this post Link to post Share on other sites
JCM 11,415 #41 Posted January 7 Hard to beat a Hydro for plowing / pushing snow or blowing for that matter. 1 Share this post Link to post Share on other sites
JoeM 10,268 #42 Posted January 7 10 minutes ago, ebinmaine said: thinking seriously about Me building another set up. That is working so good. 1 Share this post Link to post Share on other sites
ebinmaine 80,717 #43 Posted January 7 3 minutes ago, JoeM said: Me building another set up. That is working so good. As stated above - this is a 42" plow. I have another one that has a broken lower mounting tab. When @wallfish built the 60" plow I now have, I believe he used a pair of 42"... This video is me plowing on ICE 🧊 Imagine better traction. What a beast. 1 Share this post Link to post Share on other sites
ebinmaine 80,717 #44 Posted January 18 After a fair amount of experimentation and deliberation the BBT and I have decided that this current width at 42" is about right. There are places in the yard that a 60" plow gets in the way. A 48" wouldn't add enough to be worth the effort. The reason for adding width is efficiency and saving time. Adding too much would decrease efficiency and create different issues. 1 Share this post Link to post Share on other sites
peter lena 10,065 #45 Posted January 18 @ebinmaine https://earthandturfattachments.com/product-category/snow-blades-pushers/ , what you need are ideas that will fit your issue , their snow pusher might help you out . pete 1 1 Share this post Link to post Share on other sites
ebinmaine 80,717 #46 Posted January 18 2 hours ago, peter lena said: @ebinmaine https://earthandturfattachments.com/product-category/snow-blades-pushers/ , what you need are ideas that will fit your issue , their snow pusher might help you out . pete Appreciate that link. Some interesting pics of smaller sized snow pushers there. Share this post Link to post Share on other sites
peter lena 10,065 #47 Posted January 18 @ebinmaine was just checking smaller ATV plows , probably closer to your , idea , pete Share this post Link to post Share on other sites
