Lane Ranger 12,133 #1 Posted June 1, 2023 I am replacing two oil seals on this 36 inch Wheel Horse tiller. Been a while since I worked on one of these. What type gear oil goes in the tiller? Share this post Link to post Share on other sites
peter lena 10,088 #2 Posted June 1, 2023 @Lane Ranger https://www.bing.com/search?q=tiller+gear+oil&PC=U316&FORM=CHROMN , would personally want a polyurea / climbing lubricant feature , insuring lubrication , staying on everything . might even do a flush first , after many years on that old oil , pete 1 Share this post Link to post Share on other sites
lynnmor 9,051 #3 Posted June 1, 2023 From the manual: 1 1 Share this post Link to post Share on other sites
squonk 48,215 #4 Posted June 1, 2023 I see them leak all the time. I'd almost would put 00 grease in like Ariens uses in it's snowblowers 1 Share this post Link to post Share on other sites
rick 321 #5 Posted June 1, 2023 They leak badly sometimes because the grease leaking from the seal combines with the dust from tilling and grinds a groove in the tine shaft. Once the tiller shaft seals start seeping, get right on the repair or you will be buying a shaft along with the seals. Outside seal goes in backwards, to keep the dirt out. 2 Share this post Link to post Share on other sites
mrc 1,119 #6 Posted June 2, 2023 i'm with squonk and lynnmor on this one. i think the heavy 00 semi-grease with a little 90-140 gear oil should work nicely. always amazed me that folks would till a garden with a very leaky tiller. they are going to eat from the garden right? hmmm Share this post Link to post Share on other sites
lynnmor 9,051 #7 Posted June 2, 2023 29 minutes ago, mrc said: i'm with squonk and lynnmor on this one. i think the heavy 00 semi-grease with a little 90-140 gear oil should work nicely. always amazed me that folks would till a garden with a very leaky tiller. they are going to eat from the garden right? hmmm Of course many gardeners and farmers apply a generous amount of manure and all kinds of chemicals. 🤮🤢 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,547 #8 Posted June 2, 2023 I put 80w90 gear oil in mine. Seems to work good. 1 Share this post Link to post Share on other sites
JoeM 10,317 #9 Posted June 2, 2023 (edited) John Deere corn head grease? Special-Purpose Corn Head Grease (AN102562, AH80490, TY24428) A John Deere Corn Head Grease video is now available. To view the video, please click here. Applications · Formulated for John Deere corn head and other slow-speed gear cases equal or less than 1000 rpm · Extra-soft grade of lubricating grease for older John Deere corn heads · -30 to 330°F (-34 to 165°C) Service ratings · NLGI grade 0 · JDMJ13A5, J13E6, and J25A Physical properties · Green color · Contains extreme-pressure additives · Excellent at high and low temperatures · Resists moisture and water washout · Polyurea thickened · Contains anti-rust properties AN102562 Test analysis Penetration @ 77°F (25°C), 60 strokes 355-385 mm/10 Dropping point, degrees F 450°F Timken OK load, minimum 40 lb (18.1 kg) Water washout @ 175°F, loss 10% Oxidation pressure drop @ 100 hours, maximum 10 psi Edited June 2, 2023 by JoeM 2 Share this post Link to post Share on other sites
squonk 48,215 #10 Posted June 2, 2023 (edited) Edited June 2, 2023 by squonk 1 Share this post Link to post Share on other sites
lynnmor 9,051 #11 Posted June 2, 2023 Since the tiller is little more than a chain drive with some bearings, I doubt that grease would be carried up to the bearings and penetrate the chain pins. I would stay with the recommended gear oil. Share this post Link to post Share on other sites
squonk 48,215 #12 Posted June 2, 2023 That's why I would go with the 00 "liquid" grease Share this post Link to post Share on other sites
mike avad 61 #13 Posted April 17, 2024 Where can you get that 90-140 at haven't seen any? Share this post Link to post Share on other sites
lynnmor 9,051 #14 Posted April 17, 2024 58 minutes ago, mike avad said: Where can you get that 90-140 at haven't seen any? Any auto parts store, TSC and other farm supply places have 85-140 that is close enough. Share this post Link to post Share on other sites
