saminmn 17 #1 Posted April 18, 2023 I have K341s that I need to hone. It has a bore of .375. what size hone? 4 in ? Share this post Link to post Share on other sites
Achto 32,347 #2 Posted April 18, 2023 3 3/4" would be what I would recommend. https://www.amazon.com/Research-FLEX-HONE-Cylinder-Abrasive-Diameter/dp/B002XUL1LC/ref=asc_df_B002XUL1LC/?tag=hyprod-20&linkCode=df0&hvadid=475736995561&hvpos=&hvnetw=g&hvrand=18208215491071034020&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1016813&hvtargid=pla-1040709616015&th=1 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #3 Posted April 18, 2023 Achto is absolutely correct, ball hones are made to be ordered in the size they are used in, if the size is between 2 hone sizes, go to the next larger size. 3¾hole, 3¾ hone. 1 Share this post Link to post Share on other sites
pacer 3,180 #4 Posted April 18, 2023 Why, oh Why, are the "dingleberry" hones so expensive?? -----Hmmmm, maybe its cuz they do such a good job?? Share this post Link to post Share on other sites
RED-Z06 2,720 #5 Posted April 18, 2023 Ive never liked ball hones myself, i use a 3 stone, crank up the tension and use brake cleaner for lube. Cuts fast, hard on the stones, but leaves a nice pattern quickly. 4 1 Share this post Link to post Share on other sites
oliver2-44 11,694 #6 Posted April 19, 2023 @RED-Z06 @pacer @Achto What grit do yall like/recommend to use? Share this post Link to post Share on other sites
Achto 32,347 #7 Posted April 19, 2023 9 minutes ago, oliver2-44 said: What grit do yall like/recommend to use? 180 grit is my choice. 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #8 Posted April 19, 2023 56 minutes ago, oliver2-44 said: @RED-Z06 @pacer @Achto What grit do yall like/recommend to use? Alot depends on the material and how bad it is, as well as my ring composition. A K/M is just a cast iron bore, not quite as hard as a steel sleeve like a modern engine, if you're using normal iron rings, 180 or 220 is good, if you're using chro-moly faced rings a little finer grit, if available is better, like a 280 or a 320. You have to make sure you set the cross hatch right on the last few passes, i like to use my cordless drill, low range, and slow my stroke rate down to set the cross hatch. Biggest thing is cleaning, hot soapy water, you can't get it clean enough. 1 1 Share this post Link to post Share on other sites
Achto 32,347 #9 Posted April 19, 2023 7 hours ago, RED-Z06 said: Biggest thing is cleaning, hot soapy water, you can't get it clean enough. I follow this by putting clean oil on a paper towel and scrubbing the cylinder. Repeat using a new towel each time until the towel comes out clean (no black residue on the paper towel) 3 Share this post Link to post Share on other sites
953 nut 68,511 #10 Posted April 19, 2023 My go to is in a spray can. Cylinders clean up well with liberal amount of break cleaner sprayed in all directions followed by clean lint free cloth to be sure you got everything. Once you are sure its clean a liberal coating of Deep Creep penetrating oil of your choice will keep the surface from accumulating dust and dirt prior to assembly. 2 Share this post Link to post Share on other sites
