Tonytoro416 1,387 #1 Posted April 1, 2023 Looking to get new choke and throttle cables for our 68 raider build. Obviously takes the round knob pull style with throttle lock. I see several online in various price ranges. Price doesn’t necessarily concern me as much as quality. I saw some posts on here from several years ago and the consensus was most aftermarket ones weren’t worth messing with. Are they still this way today and if so what brand do you all recommend ? Share this post Link to post Share on other sites
Pullstart 71,259 #2 Posted April 1, 2023 @Achto @WHX??? Psep.biz or something? Share this post Link to post Share on other sites
Tonytoro416 1,387 #3 Posted April 1, 2023 1 hour ago, Pullstart said: @Achto @WHX??? Psep.biz or something? ?? Share this post Link to post Share on other sites
ri702bill 13,068 #4 Posted April 1, 2023 (edited) One option, although not an exact copy, is to use repro choke & throttle cables for a WWII Jeep. They look the same, the throttle does not lock unfortunately. Edited April 1, 2023 by ri702bill 1 Share this post Link to post Share on other sites
Thegearhead0324 1,844 #5 Posted April 1, 2023 I bought mine from eBay for my 1257. Works good so far. Usually come longer so you cut to length. 1 Share this post Link to post Share on other sites
squonk 48,129 #6 Posted April 1, 2023 (edited) I get replacement cables at the show. Not cheap and you may have to trim them but they work great. I think you can still get them from Toro. Part #'s Throttle 102119 choke 102118. Vendor is Dave's Small engine Pottsville Pa 717 544 8320 Edited April 1, 2023 by squonk 3 1 Share this post Link to post Share on other sites
ebinmaine 80,743 #7 Posted April 1, 2023 8 hours ago, Pullstart said: @Achto @WHX??? Psep.biz or something? Pat's Small Engine Plus. http://psep.biz/ I ordered 4 throttle cables from them recently. Pricing is excellent. They seem good. Time will tell. Trina's tractors aren't restorations that need to look correct so I ordered less expensive black knobbed pull cables for the chokes from a different place. 2 1 Share this post Link to post Share on other sites
squonk 48,129 #8 Posted April 1, 2023 I also make my cables a tad long. They seem to work better when they have a little give to them. 4 Share this post Link to post Share on other sites
ebinmaine 80,743 #9 Posted April 1, 2023 4 minutes ago, squonk said: I also make my cables a tad long. They seem to work better when they have a little give to them. I do the same. There's a fair difference in ease of operation when you take a little sharpness of the arc out of the cable. 2 Share this post Link to post Share on other sites
ri702bill 13,068 #10 Posted April 1, 2023 44 minutes ago, squonk said: I also make my cables a tad long. They seem to work better when they have a little give to them. Mike - define "tad" - 1" longer, or so?? Share this post Link to post Share on other sites
squonk 48,129 #11 Posted April 1, 2023 (edited) 14 minutes ago, ri702bill said: Mike - define "tad" - 1" longer, or so?? The lengths are in this thread. I tuck the extra conduit under the hood. Edited April 1, 2023 by squonk 2 Share this post Link to post Share on other sites
peter lena 10,070 #12 Posted April 1, 2023 @Tonytoro416 https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-150-iso-viscosity-85w-sae-51004/i/G5124506/? use this in all my cabling , hanging vertical feed , note temp range , also let cable be where it wants to be , so that it works seamlessly . also a dielectric grease . on electrical and very good on gas tank rubber valve seat . for easy installation. just a suggestion , pete 2 Share this post Link to post Share on other sites
WHX?? 58,154 #13 Posted April 1, 2023 Not for what you need Tony but while we're on the subject. @Achto scored some sheath and inner cable off fleabay or the jungle for his 953 resto. This stuff is the cats meow. The sheath has a plastic or nylon inner core that lets the wire slide slicker than snot on a door knob! The 1054 I just picked up from @Shynon had orginals on it that were terrible so i replaced and rerouted with it. Wow what a difference. It should work on any lever style that you can open up the clamp on at the lever. Sheath cuts easy with a cut off wheel & wire forms nice with z bend pliers. It came in a 50 ft roll of sheath and 100 ft roof of wire so enough to do the whole herd. 5 Share this post Link to post Share on other sites
ri702bill 13,068 #14 Posted April 1, 2023 Mike - that's a mighty big tad - more like a tadpole!!! Share this post Link to post Share on other sites
Achto 32,739 #15 Posted April 1, 2023 4 hours ago, WHX?? said: It came in a 50 ft roll of sheath and 100 ft roof of wire so enough to do the whole herd Save me some for my 953. 1 1 Share this post Link to post Share on other sites
Tonytoro416 1,387 #16 Posted April 1, 2023 Thanks guys I appreciate you all 1 Share this post Link to post Share on other sites
WHX?? 58,154 #17 Posted April 1, 2023 4 hours ago, Achto said: Save me some for my 953. Plenty for many more... I told Joel to say he didn't bring it over so I have no idea where it went... I'd like to finger out how one could use it on knob style cables. 2 Share this post Link to post Share on other sites
WHX?? 58,154 #18 Posted April 1, 2023 BTW @Tonytoro416 I have used the ones from pats and the ones off fleabay and they were all the same quality & by Stens. The big thing is lube the inner wire before you put the z bend on. Maybe the stuff suggested by greasy pete. Don't use anti seize like I did. I thought it would be the answer but it interferes with the locking system on the throttle. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #19 Posted March 1, 2025 Good tread here. I have to do one on the 856 this week. 2nd time around first on did not go well. And thanks Skquonk AKA Mike for the tread. 1 Share this post Link to post Share on other sites
kpinnc 18,969 #20 Posted March 2, 2025 On 4/1/2023 at 9:12 AM, WHX?? said: This stuff is the cats meow. The sheath has a plastic or nylon inner core that lets the wire slide slicker than snot on a door knob! That's alot like the high end mountain bike cables. Teflon lined and very durable! 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #21 Posted March 3, 2025 I started changing out the old yesterday, and in with the new. Will finish up today. I drilled a small hole on the Governor arm for better action on cable.. 2 Share this post Link to post Share on other sites
WHX?? 58,154 #22 Posted March 3, 2025 Something don't look right on that second Pic Wrencher. Unless you don't have it cut to length yet? On eights I found a spring with the link wire gov to throttle helps smooth things out. 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #23 Posted March 4, 2025 On 3/3/2025 at 8:06 AM, WHX?? said: Something don't look right on that second Pic Wrencher. Unless you don't have it cut to length yet? On eights I found a spring with the link wire gov to throttle helps smooth things out. Just showing the gentle ark. For smooth function. 1 Share this post Link to post Share on other sites
WHX?? 58,154 #24 Posted March 4, 2025 2 hours ago, Retired Wrencher said: For smooth function. Greasy Pete will like that... 1 1 Share this post Link to post Share on other sites
peter lena 10,070 #25 Posted March 5, 2025 @WHX?? take advantage of any tiny holes in related areas , like cable pull point to , movement cam shaped spot , all my cables have a light extension spring pull , on return , experiment with function / reaction . combo of lube and spring pull is a no brainer . think about it , every time you pull the cable , the spring is enhancing , its function , lube insures it . do your own testing on a problem spot , thats how I started , cables make no dragging noise , verify every change , have to warn you , once you correct a chronic issue , you might try similar detailing , on another spot , my pto lever engage ments are ridiculously , smooth silent / easy , none of related clutch facings are burned out , pete Share this post Link to post Share on other sites
