formariz 12,381 #26 Posted January 19, 2023 7 minutes ago, squonk said: But there is always the chance someone turns the faucet to hot and lets it run to get it hot and forgets to turn on the cold. Most sensible people stick their finger under it for a second to test it. But then some people stick their tongues to a frozen metal pole. 4 3 Share this post Link to post Share on other sites
squonk 48,141 #27 Posted January 20, 2023 Yup. You never know. A small child or an older person are vulnerable. Keep it at 120. On a side note, I got a call from a Dr. one afternoon. He said steam was coming out of the faucet. I found one the 80 gal. water heaters at 250 degrees with a stuck thermostat. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,594 #28 Posted January 20, 2023 (edited) 13 minutes ago, formariz said: Most sensible people stick their finger under it for a second to test it. Oh that's just crazy talk...!!! What? be responsible for my own actions??? Not... Appreciate the comment @formariz... Edited January 20, 2023 by SylvanLakeWH 2 Share this post Link to post Share on other sites
formariz 12,381 #29 Posted January 20, 2023 4 hours ago, squonk said: I found one the 80 gal. water heaters at 250 degrees with a stuck thermostat. That water was good for chicken plucking! 2 Share this post Link to post Share on other sites
oliver2-44 11,758 #30 Posted January 20, 2023 15 minutes ago, formariz said: That water was good for chicken plucking! Well this thread has strayed slightly from parts cleaners. But then again someday I may need to write some stories about my college job working the night cleanup crew at a commercial turkey processing plant. I can tell you first hand what “meat products” means on the label. Back to the dish washer. I’m going to see if I can do a simple temporary setup and run some old greasy parts. I watched a couple of YouTube videos on this but not a lot of good details given. Keep the comments coming. 1 Share this post Link to post Share on other sites
squonk 48,141 #31 Posted January 20, 2023 For small parts Simple Green HD degreaser and a Harbor freight ultrasonic cleaner works pretty well. 1 Share this post Link to post Share on other sites
ebinmaine 80,759 #32 Posted January 20, 2023 1 hour ago, squonk said: For small parts Simple Green HD degreaser and a Harbor freight ultrasonic cleaner works pretty well. Been mulling over an ultrasonic... Share this post Link to post Share on other sites
squonk 48,141 #33 Posted January 20, 2023 This is what I use for degreaser: Horror Fright ultrasonic cleaner. The only thing I don't like about it is the ultra sonic part is on a 4 min max timer. So you have to keep resetting it if you want a longer clean. The heat is turned on with just a button and it stays on until you turn it off. It can get quite hot. 2.5 litre capacity. The sell a different 6 litre one also. do not know how well that one works 1 Share this post Link to post Share on other sites
peter lena 10,076 #34 Posted January 20, 2023 @ebinmaine https://www.bing.com/shop/product?oid=93815610811&offerid=IAsHWZzlvuCGTHfeWi4UCjRxuq&storeid=770&blid=7627884214240&q=stainless pot cleaner%2F , like the stainless scrub pad , combined with any clean up detail , makes quick work of baked on areas . depending on what I am cleaning , something like kroil ,as the cutter / really cuts thru baked on areas , also a hot soak , helps out , pete 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #35 Posted January 20, 2023 (edited) 1 hour ago, squonk said: what I use for degreaser Some of those cleaner / degreasers will turn aluminum a dark gray color and it can't easily be brought back to shiny again. It won't happen immediately, so if you are cleaning and immediately rinsing, probably OK, it takes a bit of time. Make sure to read the labels if it's something that you are concerned about the appearance! I don't think it actually 'hurts' the part though, just alters the surface finish. I think it was the purple stuff, can't remember the name, but it totally wrecked the appearance of an aluminum air plenum on a Chevy engine I was working on. I soaked it in a tub for about an hour. Then I read the label... That said, if it's aluminum that you want to PAINT, it probably makes an excellent etch for paint adhesion. Simple Green does make a solution that they say is "Aluminum Safe" by the way. It ain't cheap!!! Edited January 20, 2023 by Jeff-C175 Share this post Link to post Share on other sites
squonk 48,141 #36 Posted January 20, 2023 1 hour ago, Jeff-C175 said: Some of those cleaner / degreasers will turn aluminum a dark gray color and it can't easily be brought back to shiny again. It won't happen immediately, so if you are cleaning and immediately rinsing, probably OK, it takes a bit of time. Make sure to read the labels if it's something that you are concerned about the appearance! I don't think it actually 'hurts' the part though, just alters the surface finish. I think it was the purple stuff, can't remember the name, but it totally wrecked the appearance of an aluminum air plenum on a Chevy engine I was working on. I soaked it in a tub for about an hour. Then I read the label... That said, if it's aluminum that you want to PAINT, it probably makes an excellent etch for paint adhesion. Simple Green does make a solution that they say is "Aluminum Safe" by the way. It ain't cheap!!! This carb was first soaked in Berrymans carb cleaner for a couple of hours then about an hour in the Ultrasonic with the Simple green and heat for about a half hour. Immediately rinsed after removing from cleaner. No scrubbing or coating applied. 1 2 Share this post Link to post Share on other sites
953 nut 69,476 #37 Posted January 21, 2023 On 1/19/2023 at 7:02 PM, squonk said: steam was coming out of the faucet. I found one the 80 gal. water heaters at 250 degrees with a stuck thermostat Must have had a gag on the safety valve too, should have lifted about 210 degrees. 2 Share this post Link to post Share on other sites
oliver2-44 11,758 #38 Posted January 21, 2023 I have a Ultrasonic cleaner I bought through Walmart for small parts. It is slightly bigger and longer run time than the HF one. I use Simple Green in it 1 Share this post Link to post Share on other sites
oliver2-44 11,758 #39 Posted February 11, 2023 Well I tried the dish washer on some greasy parts with simple green. I used cold water and had hoped the DWHeater would get it hot enough to cut oil and grease. Water didn’t get very hot and it didn’t touch the grease or oil. Well it was worth a no cost try. 1 1 1 Share this post Link to post Share on other sites
wallfish 20,619 #40 Posted February 11, 2023 7 hours ago, oliver2-44 said: Well I tried the dish washer on some greasy parts with simple green. I used cold water and had hoped the DWHeater would get it hot enough to cut oil and grease. Water didn’t get very hot and it didn’t touch the grease or oil. Well it was worth a no cost try. Do you think hot water would make a big difference? What about a solvent soak and then the dishwasher rinse? https://www.amazon.com/2-6Gallon-Electric-Water-Heater-Mini-Tank/dp/B091YH8H4H/ref=asc_df_B091YH8H4H/?tag=hyprod-20&linkCode=df0&hvadid=507755841810&hvpos=&hvnetw=g&hvrand=12133752562724480305&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9001808&hvtargid=pla-1265050456286&psc=1 1 Share this post Link to post Share on other sites
ebinmaine 80,759 #41 Posted February 11, 2023 7 hours ago, oliver2-44 said: simple green. I used cold water For a fair amount of Trina's past working career she was a professional cleaner in houses and Hospital, ER and many other environments. In her professional experience, Simple Green is less than effective. There are "purple products" in various brands, along with Greased Lightning that would be FAR more productive. She advises great caution if the machine is in an area that would be affected by an overflow of suds which could be a possibility during experiments. As to the water temperature, I like @wallfish's idea of feeding the dishwasher water that's already hot. There's a HUGE DIFFERENCE in grease cutting in the temperature range between 110⁰ and 125⁰. Many dishwashers are designed to intake water that's already standard house hot temp (120⁰, 125⁰, even 140⁰) THEN heat it even more. Ours here makes the water hot enough that I can just about handle the dishes after an input temp of 120⁰. Another thought by Trina, if the parts could be pre-sprayed or soaked and/or most of the muck removed then obviously the work would be lessened. 8 hours ago, oliver2-44 said: didn’t touch the grease or oil. I do believe further experimentation is warranted. Share this post Link to post Share on other sites
lynnmor 9,042 #42 Posted February 11, 2023 Perhaps you could try a double dose of dishwasher detergent, it cuts cooking grease fine. 4 Share this post Link to post Share on other sites
ebinmaine 80,759 #43 Posted February 11, 2023 11 minutes ago, lynnmor said: Perhaps you could try a double dose of dishwasher detergent, it cuts cooking grease fine. We've used two "pods" to clean out a radiator. Works Excellent. 1 Share this post Link to post Share on other sites
oliver2-44 11,758 #44 Posted February 12, 2023 I also tried the dishwashing pods and Purple Power. Not much improvement with cold water. I don’t have an easy way to tap into my houses hot water. Even with my current work to recipe the house with PEX. I can’t get down any outside walls near the shop with a hot water line. I use Purple Power as a pre soak when I use my pressure washer, I guess I stick with the pressure washer. 3 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #45 Posted February 12, 2023 On 1/19/2023 at 4:52 PM, formariz said: But then some people stick their tongues to a frozen metal pole. i may have tried that before out of curiosity i did not have a good sleep but hey i learned that the movies aren't always lying to us but i aint ever gonna try that again. Kollin 4 Share this post Link to post Share on other sites
squonk 48,141 #46 Posted February 13, 2023 (edited) Your standard home dishwasher heater will probably only raise the water temp maybe 30° if you're lucky, so if you're pumping only 60° water into it you might squeak out 90°. Commercial dishwater booster heaters only raise the temp about 40 ° and cost about 3 grand so unless you start out at 120-130° water temp you're not gonna clean squat. Steam on steam cleaners don't really clean. But the high temp softens the grease so the water pressure and detergent can clean it. Edited February 13, 2023 by squonk 2 Share this post Link to post Share on other sites
pfrederi 21,172 #47 Posted February 17, 2023 I used this cleaner in an ultra sonic unit. The Tecky carb came out a dull dark gray and would leave residue on you hand when you picked it up. Tried a bit of buffing just made the wheel very dirty and not much improvement.... Share this post Link to post Share on other sites
2drxploder 127 #48 Posted May 31, 2023 I use oil-eater in parts washer its water based. I Bought one of those submersible heaters from tractor supply for horse tank I think. It heated the solution up to about 100 in 40 degree weather in a canvas garage-in-a-box. Worked great. A residential dishwasher does heat the water, but not designed to do it all the way, only raise the tempature. Foaming may be an issue if you re-circulate. But I'm liking the idea! Share this post Link to post Share on other sites
ranger 1,862 #49 Posted May 31, 2023 On 1/19/2023 at 6:32 PM, formariz said: Correlation of water temperature in heater to the development of the Legionary disease bacteria. Nothing to fool with. A few years ago, I read a report claiming that the greatest cause of legionnaires disease has been attributed to automobile windshield washers. Apparently if plain water is used in the bottle, the under hood temps create an ideal environment for the bacterial growth? Any contamination to this water, by adding screen washer fluid, prevents this growth from occurring! I suppose using the washers to clean squashed bugs, etc, of the screen could result in contaminated water being drawn into the vehicle via the heater/air-con inlets, then driver/passengers are sitting in a compartment of recycling contaminated air? Urgh!!! Share this post Link to post Share on other sites
