RedPower47 111 #1 Posted January 5, 2023 Does anyone happen to make a pedal kit for the hydro's anymore? id like to put one on my 417A? A few years back there was a member MattD that I bought one from for my 520 but I haven't heard much from him and I don't think he's doing it anymore. 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #2 Posted January 5, 2023 Not sure.You could try posting on the wanted forum if it’s available it would be there. 2 Share this post Link to post Share on other sites
ebinmaine 78,353 #3 Posted January 5, 2023 Folks have been known to Fab their own setups. I've seen pictures of tractors with the right hand pedal added on where it never had one. Also using an aftermarket accelerator pedal as the actuator. Also seen set up that was home shop fabricated that used a large flat piece of Steel with the pivot point about a third of the way up so it would ride just forward of your heel. Push down with your toe is forward. Push down with your heel was reversed. Any of the above could have rods with heim joints running from the pedal of your choice up to the stock motion lever. @Ed Kennell was it you that built one with a default to reverse? 1 Share this post Link to post Share on other sites
Ed Kennell 45,796 #4 Posted January 5, 2023 29 minutes ago, ebinmaine said: @Ed Kennell was it you that built one with a default to reverse? Actually four....one on each of my hydros. 3 Share this post Link to post Share on other sites
case442 132 #5 Posted January 5, 2023 Hey all, this one of mine has a p.o. Home brew. works great 7 Share this post Link to post Share on other sites
RedPower47 111 #6 Posted January 5, 2023 Nice work Case! 1 Share this post Link to post Share on other sites
RedPower47 111 #7 Posted January 5, 2023 Ed would you mind showing me some pictures of how you did yours? Thanks 1 Share this post Link to post Share on other sites
Handy Don 16,286 #9 Posted January 5, 2023 3 hours ago, case442 said: Hey all, this one of mine has a p.o. Home brew. works great Looks good.Any pictures of how you handled the linkage inside? Neutral interlock? Motion centering? Thanks! Share this post Link to post Share on other sites
Bill D 2,776 #10 Posted January 5, 2023 I made my own. Still working on mods to the pedal design and I want to make an automatic return to neutral setup for it. My goal is a bolt on kit with minimal cutting or drilling required to install. 1 1 1 1 Share this post Link to post Share on other sites
ri702bill 11,886 #11 Posted January 5, 2023 13 minutes ago, Bill D said: My goal is a bolt on kit with minimal cutting or drilling required to install. Excellent approach there Bill. Can be removed at a later date if desired - no one knows the difference.... Bill Share this post Link to post Share on other sites
Handy Don 16,286 #12 Posted January 5, 2023 1 hour ago, Bill D said: Still working on mods to the pedal design and I want to make an automatic return to neutral setup for it. Wishing you good luck as I follow! I got a short stint on a tractor with separate forward and reverse pedals and I have to say I liked it. Wish I’d gotten to look under the tin to see how the mechanism worked! Share this post Link to post Share on other sites
Bill D 2,776 #13 Posted January 6, 2023 5 hours ago, ri702bill said: Excellent approach there Bill. Can be removed at a later date if desired - no one knows the difference.... Bill There will be a hole in the belt guard and I've drilled a hole above the linkage to reroute the fuel line. Those are the only major holes I have drilled so far. No major changes otherwise. 1 Share this post Link to post Share on other sites
Bill D 2,776 #14 Posted January 6, 2023 (edited) 20 hours ago, Handy Don said: Wishing you good luck as I follow! I got a short stint on a tractor with separate forward and reverse pedals and I have to say I liked it. Wish I’d gotten to look under the tin to see how the mechanism worked! Thank you. Lots of other more important things going on in my life. This isn't a priority project, and progress will be slow. Edited January 6, 2023 by Bill D Share this post Link to post Share on other sites
case442 132 #15 Posted January 6, 2023 (edited) 17 hours ago, RedPower47 said: Nice work Case! Previous owner did the fabbing. Works pretty well. Edited January 6, 2023 by case442 1 Share this post Link to post Share on other sites
pacer 3,179 #16 Posted January 7, 2023 Another home shop built pedal here too, really wasnt that difficult, 2-3 hrs with odds/ends laying around the shop. Didnt even try for neutral return, I run/use 'Big D's" mostly and WH didnt use that feature from factory. I had a 1980's Massey GT that had it built in, but it didnt work after those 40+ yrs. I tinkered with it, but didnt put much effort in it, the pedal worked just fine without out it. Share this post Link to post Share on other sites
