ebinmaine 79,688 #1 Posted December 11, 2022 This cable housing is off my 1975 C160 Automatic. I can poke into each end with a long thin punch. How can I free up the whole thing and use it? Cables available from Lowell? Share this post Link to post Share on other sites
Digger 66 3,530 #2 Posted December 11, 2022 (edited) I would soak it if that spiral casing is not sealed and if it is sealed , I'd hang it and drizzle some penetrant in until it comes out the bottom . If you have an old piece of garden hose , cork one end and slide the whole she-bang into it and pour in some kerosene while it's hanging . Oops , I misread it . I thought the inner cable was frozen inside . You could always sacrifice an old small drill bit and weld it to a piece of thin rod and chuck it up in a drill ? Edited December 11, 2022 by Digger 66 3 Share this post Link to post Share on other sites
stevasaurus 23,742 #3 Posted December 11, 2022 A length of 12 gage wire cut at an angle and put into a drill and worked a little at a time may do it. 3 Share this post Link to post Share on other sites
RandyLittrell 3,944 #4 Posted December 11, 2022 I would start with hot water and dawn then I would do the bailing wire trick and see what comes out. Randy 3 Share this post Link to post Share on other sites
Moparfanforever 933 #5 Posted December 11, 2022 Maybe a piece of no.9 wire?? I would soak it first. 2 Share this post Link to post Share on other sites
ebinmaine 79,688 #6 Posted December 11, 2022 What's the wire that goes through it while it's on the tractor? Share this post Link to post Share on other sites
Moparfanforever 933 #7 Posted December 11, 2022 The lift cable goes thru it. I suggested the no.9 wire to clean it out. 1 Share this post Link to post Share on other sites
ebinmaine 79,688 #8 Posted December 11, 2022 Just now, Moparfanforever said: The lift cable goes thru it. I suggested the no.9 wire to clean it out. Oh yeah yeah... I'm wondering what lift cable to buy. Is there a specific thing to get? Share this post Link to post Share on other sites
Moparfanforever 933 #9 Posted December 11, 2022 Pretty sure Lowell has them. 1 1 Share this post Link to post Share on other sites
ri702bill 12,475 #10 Posted December 11, 2022 (edited) Surprised @Pullstart has not chimed in with his 5 gallon bucket of used motor oil method (maybe he's getting a Band-Aid or something....)!!! I do something similar, using a shallow pan and Marvel Mystery oil - leave one end up so it can "Burp" Edited December 11, 2022 by ri702bill 1 4 Share this post Link to post Share on other sites
peter lena 9,942 #11 Posted December 11, 2022 @ebinmaine agree with the hot soaking idea , held vertically , penetrating oil , get the rust moving , https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-150-iso-viscosity-85w-sae-51004/i/G5124506/? use this super lube oil in all my cables , h/w store , pete 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,718 #12 Posted December 11, 2022 (edited) Well... You could use your patented, world famous gas pressureizermabob technique... but please, no pictures... FWIW I've used an upside down pop bottle. Put small hole in cap, fill with your choice if rusterator oil, insert cable in hole and let drip over catch pan. Refill from drips and repeat... Or, you can refer again to picture above which, is really disturbing on many, many levels... Edited December 11, 2022 by SylvanLakeWH 2 6 Share this post Link to post Share on other sites
squonk 47,381 #13 Posted December 12, 2022 Just buy a new cable/ casing from Lowell and be done with it. You need to hydraulically crimp the end on the wire. Any other method won't be able to stand up to heavy lifting. I tried every way. Nothing worked. 1 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #14 Posted December 12, 2022 Lay it on a flat steel surface. Start smacking it with a hammer...don't crush it... to 'break-up' the junk inside. Then start flexing it back/forth. The junk will free up...maybe some carb cleaner/penetrant/ air pressure etc. It'll open up eventually. OR... I'll put one in your mailbox for $20 3 Share this post Link to post Share on other sites
Pullstart 70,695 #15 Posted December 12, 2022 I am pretty sure a while back, Lowell gave a certain % off if you sent him a casing. 1 Share this post Link to post Share on other sites
wallfish 20,219 #16 Posted December 12, 2022 Soak it in vinegar to eat the rust right out of it. Run a wire trough it on a drill as suggested, resoak , redrill wire and repeat until it's 100% clean and then lube of your choice. Wire rope is what the cable was. 3/16" ??? maybe 5 Share this post Link to post Share on other sites
Pullstart 70,695 #17 Posted December 12, 2022 2 hours ago, squonk said: Just buy a new cable/ casing from Lowell and be done with it. You need to hydraulically crimp the end on the wire. Any other method won't be able to stand up to heavy lifting. I tried every way. Nothing worked. I’m all for trying it any way, but Lowell’s is high quality stuff. One of the members all I remember was Indy WH (Steve?) maybe at Scott’s meet and greet told me he smashes two 1/4-20 nuts on the end of his cables with an anvil and heavy sledge hammer and hasn’t had one come apart yet. I’ve always wanted to try it. 2 1 Share this post Link to post Share on other sites
953 nut 67,392 #18 Posted December 12, 2022 11 hours ago, squonk said: Just buy a new cable/ casing from Lowell and be done with it. You need to hydraulically crimp the end on the wire. Any other method won't be able to stand up to heavy lifting. I tried every way. Nothing worked. $ 54.00 plus shipping and you can spend your time doing fun things. 5 1 1 Share this post Link to post Share on other sites
squonk 47,381 #19 Posted December 12, 2022 1 hour ago, 953 nut said: $ 54.00 plus shipping and you can spend your time doing fun things. Like cleaning the cobwebs off of another project tractor! 2 1 Share this post Link to post Share on other sites
Handy Don 16,944 #20 Posted December 12, 2022 I got a used one from A-to-Z but I know that K&B Horse Part also has NOS on these. 1 Share this post Link to post Share on other sites
stevasaurus 23,742 #21 Posted December 12, 2022 @Pullstart That sounds like something Indy would say. (Marshal Fife) 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #22 Posted December 12, 2022 (edited) I have the CONDUIT you want... a 1/8" cable easily passes thru all three of these. "A" is rusty/pitted...$30 shipped "B" is all good...Some original paint--- $40 shipped BOTH A and B are 13-3/4" LONG... Tip-to--Tip "C" is stretched out to 16-1/4" --otherwise good except for some pitting on one end....$35 shipepd Edited December 12, 2022 by daveoman1966 1 Share this post Link to post Share on other sites
ebinmaine 79,688 #23 Posted December 12, 2022 6 minutes ago, daveoman1966 said: cable Much appreciated Dave but I'm fairly sure I have another conduit anyway. What I really need to know is how to attach the cable. Fastening each end ? I'm fairly sure I have some garage door cable that would fit the bill quite well. Share this post Link to post Share on other sites
Pullstart 70,695 #24 Posted December 12, 2022 It is a super hydraulically pressed ferrule of types EB. 1 Share this post Link to post Share on other sites
wallfish 20,219 #25 Posted December 12, 2022 3 hours ago, ebinmaine said: What I really need to know is how to attach the cable. Fastening each end ? I ground the sharp edges off the tip of my bolt cutters to a ( ) shape for both edges and use that for crimping wire rope ferrules. Never cut anything with the tip of those things anyway. Never used yet for one of those lift cables though. There's quite a bit of force applied on those ends. It would definitely work and hold with a wire loop but not so sure about just a ferrule alone Search the wire rope ferrules and crimpers 1 1 Share this post Link to post Share on other sites
