Sparky-(Admin) 24,617 #1 Posted November 26, 2022 So on my 308 when you yank the lift lever back it locks in and all is good…or so it seems…then a few seconds later or while going over a bump it just suddenly releases and drops the plow. What are the common causes of this? Never had one do this before. 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #2 Posted November 26, 2022 (edited) I've been having the same issue with my C-125. I can't seem to determine why it doesn't fully lock in as it should. I think from what I can see that the detent slot and perhaps the rod are both worn and 'rounded over' a bit. When I get a round tuit I plan to tear into it and see if I can improve it. It holds most of the time... I've gotten into the habit of pulling back the handle and wiggling it and that seems to help some. From what I can see on mine, the 'nub' on this plate seems to be worn down quite a bit. I'm wondering if there might be some play in the mounting bolts for that plate that would allow some adjustment and let the end of the rod drop deeper into the detent. Edited November 26, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,834 #3 Posted November 26, 2022 This has happened to me when the chain adjustment was too tight, take a turn or 2 off the chain and see if that helps? 6 1 1 Share this post Link to post Share on other sites
bds1984 1,506 #4 Posted November 26, 2022 I had the same happen on a 312-8. Turns out that the C-clip and bushing were missing from the rock shaft, allowing it to move enough that the up position would drop. Everything else was just fine. 2 1 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #5 Posted November 26, 2022 Just now, nylyon said: This has happened to me when the chain adjustment was too tight, take a turn or 2 off the chain and see if that helps? I actually tried that myself. It did help a little, but the rod still pops out of the detent from time to time. Probably a combination of worn parts. 2 Share this post Link to post Share on other sites
Pullstart 68,848 #6 Posted November 26, 2022 9 minutes ago, nylyon said: This has happened to me when the chain adjustment was too tight, take a turn or 2 off the chain and see if that helps? My thoughts as well. @Sparky do you have a solid lift link, or a chain? Share this post Link to post Share on other sites
Sparky-(Admin) 24,617 #7 Posted November 26, 2022 10 minutes ago, Pullstart said: My thoughts as well. @Sparky do you have a solid lift link, or a chain? Chain. When I lift the plow the plow frame isn’t hitting the front axle. 3 Share this post Link to post Share on other sites
squonk 45,488 #8 Posted November 26, 2022 (edited) Check the spring inside the lift arm. It's the spring that keeps the thing in the slot Part # 3624 in your program! https://www.partstree.com/models/21-08k802-308-8-toro-lawn-tractor-1986/manual-lift-linkage-17/ Edited November 26, 2022 by squonk 3 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,617 #9 Posted November 26, 2022 40 minutes ago, squonk said: Check the spring inside the lift arm. It's the spring that keeps the thing in the slot Part # 3624 in your program! https://www.partstree.com/models/21-08k802-308-8-toro-lawn-tractor-1986/manual-lift-linkage-17/ How hard is that to swap out?? 1 Share this post Link to post Share on other sites
squonk 45,488 #10 Posted November 26, 2022 Never done it but I've heard of them failing and the lock rod doesn't stay up Share this post Link to post Share on other sites
daveoman1966 3,882 #11 Posted November 26, 2022 Slip off the plastic grip handle and squirt in some 90w gear lube...or any oil for that matter. No doubt, there is some rust in there that precludes mechanism from workng right. . 5 Share this post Link to post Share on other sites
peter lena 9,760 #12 Posted November 26, 2022 @daveoman1966 that entire set up is often neglected ,( frequently refer to make the rust run out ), agree with you on the lubrication , another vital part of that is the cross chassis width end bushings related linkage points . every time I see a reference to the belt drive idler pulley , the end shaft bushing area for that lift arm is right there , bone dry . regularly , touch up my movement spots , pete 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 30,570 #13 Posted November 26, 2022 Same issue... lubed the innards up and spring worked like a charm... 3 Share this post Link to post Share on other sites
Sparky-(Admin) 24,617 #14 Posted November 26, 2022 5 hours ago, squonk said: Check the spring inside the lift arm. It's the spring that keeps the thing in the slot Part # 3624 in your program! https://www.partstree.com/models/21-08k802-308-8-toro-lawn-tractor-1986/manual-lift-linkage-17/ Ok…I sliced off the plastic grip on a couple junker parts machines to try to learn about the spring and its replacement. Looking at that diagram you linked it seems like it would be right there under the grip. Sliced off two grips and neither had a spring that I could see. I managed to pry up that inner sleeve looking thing but wasn’t able to actually get one out of the handles tube. 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,570 #15 Posted November 26, 2022 Never had one apart but i just oiled the crap out of it and worked it repeatedly and it freed up and worked as it should. I would also play with the adjuster knob and maybe go up or down a link on the chain...? Might be in the adjustment... 4 Share this post Link to post Share on other sites
nylyon-(Admin) 8,834 #16 Posted November 26, 2022 Put a new plow on the new 416-8 today and same thing happened. 1½ turn on the Chan and all good, and no the frame of the plow was not hitting the axle either. 2 Share this post Link to post Share on other sites
peter lena 9,760 #17 Posted November 26, 2022 @SylvanLakeWH anything you oil the crap out of is ok with me , mind if I use that phrase ? kinda like grease the crap out of it , make the rust run out , pete 1 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #18 Posted November 26, 2022 2 minutes ago, peter lena said: grease the crap out of it That's my kind of language... Don 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,442 #19 Posted November 27, 2022 Wow good post never thought to lube them. Will do this today. Share this post Link to post Share on other sites
peter lena 9,760 #20 Posted November 27, 2022 @Retired Wrencher imagine most guys think I bathe my horses in lubricant , not exactly , but pretty close . if its rusty / neglected , chances are it does not work / survive like it could . thats another reason I suggest , using lubricant to use on your horse paint finishes , no rust / rot , save patina , very simple . just freeing up a dry rusty area , makes it start to move , usually give it a grease / lubricant transfusion . that aerosol penetrating oil first , makes it move and rust run out , then aerosol red grease , will retain that movement , pete 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,617 #21 Posted November 27, 2022 Question: Middle hole correct?? 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,834 #22 Posted November 27, 2022 You can do the top as well for added lift page 8 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,617 #23 Posted November 27, 2022 So I tried all three lift holes with no change. Backed off on the eyebolt chain thingy, it might have been a bit better after that. It just seems that everything is sloppy and worn out (dang thing isn’t really all that old being a 1987 ). I ended up adding thin washers under this piece (see picture) and saw improvement. Took it apart and added a thicker washer and it improved even more. Still drops but not as much. 1 Share this post Link to post Share on other sites
squonk 45,488 #24 Posted November 27, 2022 10 minutes ago, Sparky said: It just seems that everything is sloppy and worn out (dang thing isn’t really all that old being a 1987 ). Exact reason I prefer pre-1980 tractors. Don't know why but I have run into crappy lift components on the 80 and up models more than once and never have on the older units. I find the clips bent, Eye bolts bent and general rust and rot. Plus that lift arm hole is tougher to get to. Share this post Link to post Share on other sites
Jeff-C175 7,207 #25 Posted November 27, 2022 31 minutes ago, Sparky said: added Leads me to believe that detent is rounded over. Can you see where the rod drops into the detent? Share this post Link to post Share on other sites
