dkg520 531 #1 Posted November 22, 2022 (edited) I have a NOS steering shaft part #106177. I’m looking for help determining which steering wheel will fit it. Any help is appropriate. Edited November 22, 2022 by dkg520 Error in part number Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #2 Posted November 22, 2022 106177 replaced by 92-4987 used on 300-series 1993-1997 and 416-8 1993-1995. 106177 likely used 1985-1992 on 300-series 2 Share this post Link to post Share on other sites
Racinbob 13,040 #3 Posted November 22, 2022 I'm thinking the steering wheel of your choice. There's probably some but I can't think of any that weren't 3/4" smooth bore. 2 Share this post Link to post Share on other sites
peter lena 9,939 #4 Posted November 22, 2022 @dkg520 thinking while you are there , the opportunity to upgrade and enhance that column is https://thebigbearingstore.com/3-4-two-bolt-flange-bearing-ucfl204-12/ , have this style / type on my horses , shop around for pricing , also use its strength to enhance dash area bracing , make that your go to bolt on area . having done this and related dash area improvements , like pto lever start , added battery ground cable , from ground rail to engine / chassis corner , battery tender , plug in point note corner of flange bearing , on left , elastic lock nut , note washers added to start of , sloppy pto lever action , related heim joint end , you are right there , only a suggestion , pete Share this post Link to post Share on other sites
