Similar Content
By Rob R
So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock. You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
Appreciate all your advice as this one has me stumped......
By Truckedup1
I have a very recently restored 1989 wheel horse 520-HC tractor with 60” deck. Family owned for over 10 years but now it’s time for another project. Please contact me with any questions I have the original 60” deck but it was rough so I sourced the current deck off this site, it really is in excellent condition for not being restored.
By lodestonefarm
Selling my trusty WH520H. ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking. 20HP Onan, hydro transmission and hydraulic lift. Has Matt's foot-pedal conversion for forward/reverse. Included in the sale is a tall-chute snow blower and 60" mowing deck. The blower is in excellent condition and is on the tractor currently. The mowing deck has been a workhorse over the years. No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo). Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it). Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front. The seat (with arm rests) isn't in great shape. I've got a cover for the seat, never used. It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
I've owed this machine about 8 year and put ~350 hours on her. She's not a show piece but could be restored. Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn. The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster. My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast. They don't make them like this anymore.
