Gregor 4,848 #1 Posted October 18, 2022 When you install chains, do you want them tight, or a little loose? Thanks Greg Share this post Link to post Share on other sites
wallfish 20,159 #2 Posted October 18, 2022 I like'm tight. Installed tight with no air it the tires then air them up for a nice tight fit without the need for any tension springs, bungee cords or anything else. Yes it's a little bit of a pain to get them on that tight but they don't move rattle or roll 5 3 Share this post Link to post Share on other sites
ebinmaine 79,550 #3 Posted October 18, 2022 I put mine on tight as a drum. I want ZERO movement of my tire chains. I'll be curious to see if there's any counter opinions to that, and why. 4 Share this post Link to post Share on other sites
ri702bill 12,415 #4 Posted October 18, 2022 (edited) I agree that you want them tight. I have dedicated filled winter tires that the chains stay on all year. I do exactly as John said when installing new chains and then add the air. Even then, it seems that the first time you use freshly mounted chains, there can be a little slack after the cross links find their happy spots in the tread. That is why you need the spring or O-ring tensioner device too. If the slack is not all taken up with the tensioner, it's time to revisit the installation process and shorten up the side chain(s). Also - be sure to install the chains with the cross link connectors hooks facing the right way - flat side to the tire.... Edited October 18, 2022 by ri702bill 2 Share this post Link to post Share on other sites
Racinbob 13,022 #5 Posted October 18, 2022 Tight for me too with tires deflated during the install. Never needed or used tension springs. 1 Share this post Link to post Share on other sites
Pullstart 70,482 #6 Posted October 18, 2022 Tight enough to not fall off works for me! Most of mine, I lay ‘em out, roll the tractor over them, and wrestle ‘em up over the tire. Run for a while, tighten another link or two and call it good. One time ever has a chain come off, or better yet run crooked. My theory on loose vs tight is that I can easily toss a chain under my truck tires and the instant the chain becomes stuck between the earth and the tire, forward progress happens. Like a Wheel Horse drive belt, the chain isn’t being pushed into that gap, it’s being pulled from the back of the tire. I do agree, a tight tire chain all evenly spaced out does look nice though! 3 Share this post Link to post Share on other sites
WHX?? 57,308 #7 Posted October 18, 2022 Tight... I jack one side up and lay it over the top on a deflated tire then connect at the bottoms. Makes it easy to roll through tire to get it to lay just right. These nifty keepers @dclarke had on but those rubber tie downs work too. 1 2 Share this post Link to post Share on other sites
JoeM 10,076 #8 Posted October 18, 2022 A little loose on AG's so they find their place in the tread. Snug on turfs if I run a mower deck. I know on cars the wheel speed and low fender clearance needs them tight. I think weight makes a big difference. Since I went to ATV rear tires, I have not used chains. Plowed up the steep snow cover drive with no issues. It is a good proving ground, pretty steep. 2 2 Share this post Link to post Share on other sites
Pullstart 70,482 #9 Posted October 18, 2022 3 minutes ago, JoeM said: pretty steep. Understatement of the year Joe! 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #10 Posted October 18, 2022 Tight as I can gettem. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #11 Posted October 18, 2022 7 hours ago, Gregor said: do you want them tight, or a little loose? 1 hour ago, Jeff-C175 said: Tight as I can gettem. I made my own custom springs to keep mine tensioned. I may make more tensioning springs to go on the back side, once I get spacers on the machine and have more room to work with... I really think... with a gravel driveway, having the chaines loose would certainly destroy chains (just my thought though)... Don 2 Share this post Link to post Share on other sites
Pullstart 70,482 #12 Posted October 20, 2022 On 10/18/2022 at 7:24 AM, Pullstart said: Tight enough to not fall off works for me! well after a few years of use, they weren’t tight enough! 1 Share this post Link to post Share on other sites
