RED-Z06 2,718 #1 Posted September 27, 2022 On my 93 416 the plastic plug that connects the engine to the harness has melted pins and now it randomly dies or won't start without fiddling with it. Short of individually pairing each plug or doing multiple 2pin Waterpak connects...is there a replacement with pins? Share this post Link to post Share on other sites
WHX?? 57,642 #2 Posted September 27, 2022 If we're talking the infamous nine pin yes Bob Maynard has or used to have them. He's in the vendor section. @rmaynard There are some other sources but he comes to mind first. Share this post Link to post Share on other sites
RED-Z06 2,718 #3 Posted September 27, 2022 24 minutes ago, RED-Z06 said: On my 93 416 the plastic plug that connects the engine to the harness has melted pins and now it randomly dies or won't start without fiddling with it. Short of individually pairing each plug or doing multiple 2pin Waterpak connects...is there a replacement with pins? Sounds right. I ordered a thing called a molex connector this morning but i dont know if it fits Share this post Link to post Share on other sites
953 nut 68,154 #4 Posted September 28, 2022 If you are talking about the 5 pin connector shown here you can get them on Ebay for $ 10.00. https://www.ebay.com/itm/352513156430?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=352513156430&targetid=1262779895209&device=c&mktype=&googleloc=9011362&poi=&campaignid=14859008593&mkgroupid=130497710760&rlsatarget=pla-1262779895209&abcId=9300678&merchantid=6578554&gclid=CjwKCAjwvsqZBhAlEiwAqAHElY86hoxkpGElczo1nrto3YykG5-OPDzqO0nwyVUW4zTqmJWU5bvE3BoCUAkQAvD_BwE Share this post Link to post Share on other sites
RED-Z06 2,718 #5 Posted September 28, 2022 This is what i ordered...hard to tell what mine used to look like Share this post Link to post Share on other sites
WHX?? 57,642 #6 Posted September 28, 2022 That will work. Share this post Link to post Share on other sites
rmaynard 17,494 #7 Posted September 28, 2022 1 hour ago, WHX?? said: If we're talking the infamous nine pin yes Bob Maynard has or used to have them. He's in the vendor section. @rmaynard There are some other sources but he comes to mind first. I have them. Mine are direct replacements for the OEM plug. Share this post Link to post Share on other sites
cleat 9,093 #8 Posted September 28, 2022 If you get the charge wire out of that connector it will see much less load. I run the center wire from the voltage regulator through an inline 30 amp fuse right to the battery cable at the starter solenoid. The 9 pin then only sees the current that the coil requires to run the engine and maybe the lights if you run at night. The early 520's came this way from the factory I don't know why Toro changed this. 2 Share this post Link to post Share on other sites
Handy Don 17,192 #9 Posted September 28, 2022 45 minutes ago, cleat said: The early 520's came this way from the factory I don't know why Toro changed this. Time and money. Faster at both the engine assembly and tractor assembly. Fewer parts to source, inventory, and deploy to the production line. 2 Share this post Link to post Share on other sites
WHX?? 57,642 #10 Posted September 28, 2022 9 hours ago, cleat said: If you get the charge wire out of that connector it will see much less load. Done that on more than one. Used a regular bullet connector and melted that too. Soldered and shrink wrapped but then problems cropped up at the fuse block so check that too Red. Share this post Link to post Share on other sites
RED-Z06 2,718 #11 Posted September 28, 2022 32 minutes ago, WHX?? said: Done that on more than one. Used a regular bullet connector and melted that too. Soldered and shrink wrapped but then problems cropped up at the fuse block so check that too Red. It has fuse block issues too...got to address that next...the charging system is a heck of a load. Share this post Link to post Share on other sites
peter lena 9,993 #12 Posted September 28, 2022 @RED-Z06 agree with others above on the redo of the connector , something I would ad is a REROUTE OF TIGHT PULLING , CHAFING WIRES , did that on every used to be problem area , also used cable wrap and stick on tye wrap mount points . adding wire strain / relief to problem spot , is very easy , once your connection is verified , eliminate tight strain connections . pete Share this post Link to post Share on other sites
Bill D 3,063 #13 Posted September 28, 2022 (edited) 15 hours ago, 953 nut said: If you are talking about the 5 pin connector shown here you can get them on Ebay for $ 10.00. https://www.ebay.com/itm/352513156430?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=352513156430&targetid=1262779895209&device=c&mktype=&googleloc=9011362&poi=&campaignid=14859008593&mkgroupid=130497710760&rlsatarget=pla-1262779895209&abcId=9300678&merchantid=6578554&gclid=CjwKCAjwvsqZBhAlEiwAqAHElY86hoxkpGElczo1nrto3YykG5-OPDzqO0nwyVUW4zTqmJWU5bvE3BoCUAkQAvD_BwE Change over to 5-pin and 4-pin Packard connectors like the ones shown. Also, add a wire from the rectifier to the battery positive terminal on the starter. Add a fuse when you do. This should solve your electrical issues once and for all. Edited September 28, 2022 by Bill D 1 Share this post Link to post Share on other sites
