matt monte 232 #1 Posted September 27, 2022 did a search, didn't find anything. gonna start messing with this next week, picked it up for my 312-8. 1st off i noticed slop in this bearing. Not sure pn. is there any manual on how to replace? the sticker is very worn-out so im at a loss on how to correctly identify Share this post Link to post Share on other sites
matt monte 232 #2 Posted September 27, 2022 also i know this sounds stupid but how do you spool the wire to the snow shoot? keeps binding up Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #3 Posted September 27, 2022 The model you have likely is on this list Snowthrower DNA All have 2 idler sprockets for the drive chain. Started out as 37" wide and the added wings make them 42" wide. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. Snowthrower rear frame mounts in the front of the tractor frame using 2 bushings and a long 3/8-16 x 8-1/2" bolt. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 One difference in models is what the cable is wound around - the crank or a spool on the crank. Does the chute turn in 4 grooved rollers? Share this post Link to post Share on other sites
Blasterdad 3,163 #4 Posted September 27, 2022 Tractor Supply usually stocks them, on shelf item, just bring old one with you & compare. Share this post Link to post Share on other sites
Pullstart 68,986 #5 Posted September 27, 2022 If you pul the pulley off the shaft, that bearing should be able to follow. Share this post Link to post Share on other sites
peter lena 9,782 #7 Posted September 27, 2022 @matt monte do yourself a favor , look up flange bearings , for a probable match up , with that solid base go to , you might even switch to a 4 bolt flange , critical to this is hi temp grease lubrication at every movement point . lucas red / or prefered green grease . make every rotating point easy / smooth to function , also detail in your chain drive auger set up , use specific , chain / cable lubricant , never let it dry out / rust , my 36x42 single stage spins up by hand , 12 hp runs that without effort , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #8 Posted September 27, 2022 I recall there being a problem finding a bearing with the correct OD and ID. The 3/4" ID bearings usually have a 7/8" OD. What they were doing is using the 7/8" ID bearing with a 7/8" x 3/4" bushing to fit the 3/4" shaft. 1 Share this post Link to post Share on other sites
peter lena 9,782 #9 Posted September 27, 2022 @gwest_ca agree with that , finding a matching bronze bushing is easy for fit assist , notice there is no mention of the grade or type of lubricant used in those bearings ? you assume that its the right stuff , with the continuous bearing failures / load dragging on attachments . ever wonder why so many members are burning out pto , drive clutches ? kind of like dragging a sled , you can make it better , pete Share this post Link to post Share on other sites
lynnmor 8,651 #10 Posted September 27, 2022 43 minutes ago, peter lena said: @matt monte critical to this is hi temp grease lubrication at every movement point . lucas red / or prefered green grease Since a snowblower operates in a cold environment with plenty of water and ice, I would think that a marine grease would be the best choice if one wants to open a sealed bearing for grease replacement. 1 Share this post Link to post Share on other sites
peter lena 9,782 #11 Posted September 27, 2022 @gwest_ca agree with that , finding a matching bronze bushing is easy for fit assist , notice there is no mention of the grade or type of lubricant used in those bearings ? you assume that its the right stuff , with the continuous bearing failures / load dragging on attachments . ever wonder why so many members are burning out pto , drive clutches ? kind of like dragging a sled , you can make it better , pete Share this post Link to post Share on other sites
peter lena 9,782 #12 Posted September 27, 2022 @matt monte agree with the marine grease , also has a very extended range of protection. temp amd durability , those needle point grease tips , are also very good in tight spots . when I fist installed my snowblower years ago , used , neglected . was amazed that it worked at all , their was so much collective drag on it . just broke it down for function , kept gaining on it , up for sale now , it easily spins by hand , no screaming shuddering attempt to function , it just works like it should , done that on all my related problems , go grease , pete Share this post Link to post Share on other sites
matt monte 232 #13 Posted September 27, 2022 thanks for all the responses. im gonna mock it up 1st then i will attempt to run it. ill post a better pic, using list i was able to figure out missing digit. 0642ST04. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #14 Posted September 27, 2022 Here are 5 files associated with 06-42ST04 https://www.wheelhorseforum.com/search/?q=06-42st04&quick=1&type=downloads_file Share this post Link to post Share on other sites
