Hampton 95 #1 Posted September 20, 2022 Attached my first ever tiller on my first ever Wheel Horse. What an adventure. I now understand why some of you have a tractor for each attachment. lol Watched a video that had what might be a lift assist spring on a tiller. I don't have one. Thinking I should get one. 1 1 1 Share this post Link to post Share on other sites
Skwerl58 770 #2 Posted September 20, 2022 Attaching a tiller can be a task for sure. I have a 414-8 and I align the tiller with the rear mounts and attach those then attach the lift cable. I put a 4x4 block under the tiller before I hook up the lift cable. It takes me about 15 minutes to get everything ready to go if all goes well. I have a spring but only use it probably half the time, depending on the tilling job. 1 Share this post Link to post Share on other sites
Goldnboy 1,067 #3 Posted September 20, 2022 I took a picture so that I remember how to align things up the belt guard also adds trickery. Once in position just lift up. Hydraulic lift does work in your favor when tilling with a 8 speed. 2 Share this post Link to post Share on other sites
Pullstart 68,524 #4 Posted September 20, 2022 @Hampton that’s one right of passage to ! Pulling hubs and steering wheels are others, along with seized hitch pin removal! @Goldnboy I’ve never seen a belt guard on one! Must be why! 1 Share this post Link to post Share on other sites
clueless 3,331 #5 Posted September 24, 2022 If you have a Harbor Freight close buy one of those cheap wood four wheel dollies $15.00, the larger one work even better. Set the tiller on it, it will raise it just about the right height so you can just roll it up to the hitch while lay on the floor and with very little effort to connect it. Same when disconnecting it, just raise the tiller and roll the dolly under it and disconnect it and the best part is you can now roll the tiller wherever you want to store it till next time. "Work smarter not harder". 2 Share this post Link to post Share on other sites
peter lena 9,557 #6 Posted September 24, 2022 @Hampton @clueless , agree with clueless , on making things easier , would also do an oil change on that unit , often suggest on making any attachment , linkage / lever , etc easier to function make sense ? typically go over its intended function , make the rust run out , as some of us get older , you just cannot crawl around and do things easily , thats where I am . my 2 cents , pete Share this post Link to post Share on other sites
Wheelie1277 2 #7 Posted October 9, 2022 I have to ask you guys about a 175 36" tiller I picked up this week for a steal! It came with the original manual and it's telling me I can't put it on my 1277. Please tell me that's incorrect? 1 Share this post Link to post Share on other sites
Lee1977 7,456 #8 Posted October 10, 2022 On 10/9/2022 at 2:58 PM, Wheelie1277 said: I have to ask you guys about a 175 36" tiller I picked up this week for a steal! It came with the original manual and it's telling me I can't put it on my 1277. Please tell me that's incorrect? The tiller wasn't designed to fit that older tractor, I'm not saying it can't be used with that tractor. I may be more trouble to make the changes then it's worth.The good news is you need another Wheel Horse it will fit ( no mame 1973 , C-series , 300, 400, or 500. 1 Share this post Link to post Share on other sites
Wheelie1277 2 #9 Posted October 11, 2022 Just an update on my tiller install, I got it to work! Took everything off for the mower deck and the original belt he gave me works on the large pulley! 1 Share this post Link to post Share on other sites
peter lena 9,557 #10 Posted October 11, 2022 @Hampton glad you got it going , next time you use it , or just checking out its function , you might consider dropping and changing the gear oil , chances are it might have moisture in it , ,milky color . pete Share this post Link to post Share on other sites
mrc 1,015 #11 Posted October 11, 2022 hampton, if tilling with an 8 speed do yourself a favor and get the lift assist spring. much easier to lift. i tried it both ways myself and spring is better. Share this post Link to post Share on other sites
